[GRASS-SVN] r70394 - grass/branches/releasebranch_7_2/raster/r.stats.quantile
svn_grass at osgeo.org
Wed Jan 18 07:56:07 PST 2017
Author: mmetz
Date: 2017-01-18 07:56:07 -0800 (Wed, 18 Jan 2017)
New Revision: 70394
grass/branches/releasebranch_7_2/raster/r.stats.quantile/main.c
grass/branches/releasebranch_7_2/raster/r.stats.quantile/r.stats.quantile.html
r.stats.quantile: backport from trunk r69776, 69777, 69782
Modified: grass/branches/releasebranch_7_2/raster/r.stats.quantile/main.c
--- grass/branches/releasebranch_7_2/raster/r.stats.quantile/main.c 2017-01-17 22:32:30 UTC (rev 70393)
+++ grass/branches/releasebranch_7_2/raster/r.stats.quantile/main.c 2017-01-18 15:56:07 UTC (rev 70394)
@@ -2,7 +2,8 @@
* MODULE: r.stats.quantile
- * AUTHOR(S): Glynn Clements <glynn gclements.plus.com> (original contributor),
+ * AUTHOR(S): Glynn Clements <glynn gclements.plus.com> (original contributor)
+ * Markus Metz: dynamic bins to reduce memory consumptions
* PURPOSE: Compute category or object oriented quantiles using two passes
* This program is free software under the GNU General Public
@@ -18,12 +19,9 @@
#include <grass/glocale.h>
#include <grass/spawn.h>
-#define MAX_CATS 1000
struct bin
unsigned long origin;
- DCELL min, max;
int base, count;
@@ -32,6 +30,8 @@
unsigned int *slots;
unsigned long total;
int num_values;
+ DCELL min, max, slot_size;
+ int num_slots;
unsigned char *slot_bins;
int num_bins;
struct bin *bins;
@@ -43,7 +43,6 @@
static DCELL *quants;
static DCELL min, max;
static int num_slots;
-static DCELL slot_size;
static int rows, cols;
@@ -51,19 +50,27 @@
static int num_cats;
static struct basecat *basecats;
-static inline int get_slot(DCELL c)
+static inline int get_slot(struct basecat *bc, DCELL c)
- int i = (int)floor((c - min) / slot_size);
+ int i;
+ if (bc->num_slots == 0)
+ return -1;
+ i = (int)floor((c - bc->min) / bc->slot_size);
if (i < 0)
i = 0;
- if (i > num_slots - 1)
- i = num_slots - 1;
+ if (i > bc->num_slots - 1)
+ i = bc->num_slots - 1;
return i;
static inline double get_quantile(struct basecat *bc, int n)
+ if (n >= num_quants)
+ return (double)bc->total + bc->total;
return (double)bc->total * quants[n];
@@ -71,35 +78,91 @@
CELL *basebuf = Rast_allocate_c_buf();
DCELL *coverbuf = Rast_allocate_d_buf();
+ struct basecat *bc;
int row, col;
+ int i;
+ int allnull;
G_message(_("Computing histograms"));
+ for (i = 0; i < num_cats; i++) {
+ bc = &basecats[i];
+ bc->min = max;
+ bc->max = min;
+ allnull = 1;
for (row = 0; row < rows; row++) {
+ G_percent(row, rows, 2);
Rast_get_c_row(basefile, basebuf, row);
Rast_get_d_row(coverfile, coverbuf, row);
for (col = 0; col < cols; col++) {
- struct basecat *bc;
- int i;
if (Rast_is_c_null_value(&basebuf[col]))
continue;
if (Rast_is_d_null_value(&coverbuf[col]))
continue;
- i = get_slot(coverbuf[col]);
+ allnull = 0;
bc = &basecats[basebuf[col] - cmin];
- bc->slots[i]++;
bc->total++;
+ if (bc->min > coverbuf[col])
+ bc->min = coverbuf[col];
+ if (bc->max < coverbuf[col])
+ bc->max = coverbuf[col];
+ G_percent(rows, rows, 2);
+ if (allnull)
+ G_fatal_error(_("No cells found where both base and cover are not NULL"));
+ bc->num_slots = 0;
+ bc->slot_size = 0;
+ if (bc->max <= bc->min)
+ continue;
+ bc->num_slots = 1;
+ if (bc->total * 10 > (unsigned long) num_slots)
+ bc->num_slots = num_slots;
+ bc->slots = G_calloc(bc->num_slots, sizeof(unsigned int));
+ bc->slot_size = (bc->max - bc->min) / bc->num_slots;
+ for (row = 0; row < rows; row++) {
+ Rast_get_c_row(basefile, basebuf, row);
+ Rast_get_d_row(coverfile, coverbuf, row);
+ for (col = 0; col < cols; col++) {
+ if (Rast_is_c_null_value(&basebuf[col]))
+ continue;
+ if (Rast_is_d_null_value(&coverbuf[col]))
+ continue;
+ bc = &basecats[basebuf[col] - cmin];
+ continue;
+ i = get_slot(bc, coverbuf[col]);
+ bc->slots[i]++;
- G_percent(rows, rows, 2);
G_free(basebuf);
G_free(coverbuf);
@@ -119,16 +182,20 @@
unsigned long accum = 0;
int quant = 0;
+ continue;
bc->bins = G_calloc(num_quants, sizeof(struct bin));
- bc->slot_bins = G_calloc(num_slots, sizeof(unsigned char));
+ bc->slot_bins = G_calloc(bc->num_slots, sizeof(unsigned char));
next = get_quantile(bc, quant);
- for (slot = 0; slot < num_slots; slot++) {
+ for (slot = 0; slot < bc->num_slots; slot++) {
unsigned int count = bc->slots[slot];
unsigned long accum2 = accum + count;
- if (accum2 > next) {
+ if (accum2 > next ||
+ (slot == bc->num_slots - 1 && accum2 == next)) {
struct bin *b = &bc->bins[bin];
bc->slot_bins[slot] = ++bin;
@@ -136,8 +203,6 @@
b->origin = accum;
b->base = num_values;
b->count = 0;
- b->min = min + slot_size * slot;
- b->max = min + slot_size * (slot + 1);
while (accum2 > next)
next = get_quantile(bc, ++quant);
@@ -180,8 +245,12 @@
continue;
+ continue;
if (!bc->slot_bins[i])
continue;
@@ -193,8 +262,8 @@
G_free(basebuf);
G_free(coverbuf);
@@ -221,6 +290,9 @@
struct basecat *bc = &basecats[cat];
int bin;
+ continue;
G_free(bc->slot_bins);
for (bin = 0; bin < bc->num_bins; bin++) {
@@ -235,19 +307,50 @@
G_percent(cat, num_cats, 2);
-static void print_quantiles(void)
+static void print_quantiles(char *fs, char *name, int table_frmt)
- int cat;
+ int cat, quant;
G_message(_("Printing quantiles"));
- for (cat = 0; cat < num_cats; cat++) {
- struct basecat *bc = &basecats[cat];
- int quant;
+ if (name != NULL && strcmp(name, "-") != 0) {
+ if (NULL == freopen(name, "w", stdout)) {
+ G_fatal_error(_("Unable to open file <%s> for writing"), name);
+ if (!table_frmt) {
+ for (cat = 0; cat < num_cats; cat++) {
+ bc = &basecats[cat];
+ if (bc->total == 0)
+ continue;
+ for (quant = 0; quant < num_quants; quant++)
+ fprintf(stdout, "%d%s%d%s%f%s%f\n", cmin + cat, fs, quant, fs,
+ 100 * quants[quant], fs, bc->quants[quant]);
+ else {
+ fprintf(stdout, "cat");
- printf("%d:%d:%f:%f\n", cmin + cat, quant, 100 * quants[quant], bc->quants[quant]);
+ fprintf(stdout, "%s%f", fs, 100 * quants[quant]);
+ fprintf(stdout, "\n");
+ continue;
+ fprintf(stdout, "%d", cmin + cat);
+ fprintf(stdout, "%s%f", fs, bc->quants[quant]);
static void compute_quantiles(void)
@@ -258,31 +361,43 @@
- struct bin *b = &bc->bins[0];
int quant;
+ if (bc->max < bc->min)
+ continue;
bc->quants = G_malloc(num_quants * sizeof(DCELL));
- for (quant = 0; quant < num_quants; quant++) {
- double next = get_quantile(bc, quant);
- double k, v;
- int i0, i1;
+ if (bc->max == bc->min) {
+ bc->quants[quant] = bc->min;
+ else {
+ struct bin *b = &bc->bins[0];
- while (b->origin + b->count < next)
- b++;
+ for (quant = 0; quant < num_quants; quant++) {
+ double next = get_quantile(bc, quant);
+ double k, v;
+ int i0, i1;
- k = next - b->origin;
- i0 = (int)floor(k);
- i1 = (int)ceil(k);
+ while (b->origin + b->count < next)
+ b++;
- if (i1 > b->count - 1)
- i1 = b->count - 1;
+ k = next - b->origin;
+ i0 = (int)floor(k);
+ i1 = (int)ceil(k);
- v = (i0 == i1)
- ? bc->values[b->base + i0]
- : bc->values[b->base + i0] * (i1 - k) + bc->values[b->base + i1] * (k - i0);
+ if (i0 > b->count - 1)
+ i0 = b->count - 1;
+ if (i1 > b->count - 1)
+ i1 = b->count - 1;
- bc->quants[quant] = v;
+ v = (i0 == i1)
+ ? bc->values[b->base + i0]
+ : bc->values[b->base + i0] * (i1 - k) + bc->values[b->base + i1] * (k - i0);
+ bc->quants[quant] = v;
@@ -311,8 +426,10 @@
if (!fp)
G_fatal_error(_("Unable to open temporary file"));
- fprintf(fp, "%d = %d %f\n", cmin + cat, cmin + cat, basecats[cat].quants[quant]);
+ if (basecats[cat].total > 0)
+ fprintf(fp, "%d = %d %f\n", cmin + cat, cmin + cat, basecats[cat].quants[quant]);
fclose(fp);
@@ -351,6 +468,8 @@
if (Rast_is_c_null_value(&base_buf[col]))
Rast_set_d_null_value(&out_buf[col], 1);
+ else if (basecats[base_buf[col] - cmin].total == 0)
+ Rast_set_d_null_value(&out_buf[col], 1);
else
out_buf[col] = basecats[base_buf[col] - cmin].quants[quant];
@@ -377,13 +496,14 @@
struct GModule *module;
struct
- struct Option *quant, *perc, *slots, *basemap, *covermap, *output;
+ struct Option *quant, *perc, *slots, *basemap, *covermap,
+ *output, *file, *fs;
} opt;
struct {
- struct Flag *r, *p;
+ struct Flag *r, *p, *t;
} flag;
const char *basemap, *covermap;
- char **outputs;
+ char **outputs, *fs;
int reclass, print;
int cover_fd, base_fd;
struct Range range;
@@ -428,6 +548,16 @@
opt.output->required = NO;
opt.output->multiple = YES;
+ opt.file = G_define_standard_option(G_OPT_F_OUTPUT);
+ opt.file->key = "file";
+ opt.file->required = NO;
+ opt.file->description =
+ _("Name for output file (if omitted or \"-\" output to stdout)");
+ opt.fs = G_define_standard_option(G_OPT_F_SEP);
+ opt.fs->answer = ":";
+ opt.fs->guisection = _("Formatting");
flag.r = G_define_flag();
flag.r->key = 'r';
flag.r->description =
@@ -438,6 +568,11 @@
flag.p->description =
_("Do not create output maps; just print statistics");
+ flag.t = G_define_flag();
+ flag.t->key = 't';
+ flag.t->description =
+ _("Print statistics in table format");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -445,7 +580,7 @@
covermap = opt.covermap->answer;
outputs = opt.output->answers;
reclass = flag.r->answer;
- print = flag.p->answer;
+ print = flag.p->answer || flag.t->answer;
if (!print && !opt.output->answers)
G_fatal_error(_("Either -%c or %s= must be given"),
@@ -493,33 +628,29 @@
Rast_get_range_min_max(&range, &cmin, &cmax);
num_cats = cmax - cmin + 1;
- if (num_cats > MAX_CATS)
- G_fatal_error(_("Base map <%s> has too many categories (max: %d)"),
- basemap, MAX_CATS);
+ if (num_cats > 100000)
+ G_warning(_("Base map <%s> has many categories (%d), computation might be slow and might need a lot of memory"),
+ basemap, num_cats);
Rast_read_fp_range(covermap, "", &fprange);
Rast_get_fp_range_min_max(&fprange, &min, &max);
- slot_size = (max - min) / num_slots;
basecats = G_calloc(num_cats, sizeof(struct basecat));
- for (i = 0; i < num_cats; i++)
- basecats[i].slots = G_calloc(num_slots, sizeof(unsigned int));
rows = Rast_window_rows();
cols = Rast_window_cols();
get_slot_counts(base_fd, cover_fd);
initialize_bins();
fill_bins(base_fd, cover_fd);
sort_bins();
compute_quantiles();
- if (print)
- print_quantiles();
+ if (print) {
+ /* get field separator */
+ fs = G_option_to_separator(opt.fs);
+ print_quantiles(fs, opt.file->answer, flag.t->answer);
else if (reclass)
do_reclass(basemap, outputs);
else
Modified: grass/branches/releasebranch_7_2/raster/r.stats.quantile/r.stats.quantile.html
--- grass/branches/releasebranch_7_2/raster/r.stats.quantile/r.stats.quantile.html 2017-01-17 22:32:30 UTC (rev 70393)
+++ grass/branches/releasebranch_7_2/raster/r.stats.quantile/r.stats.quantile.html 2017-01-18 15:56:07 UTC (rev 70394)
@@ -24,7 +24,8 @@
<h2>AUTHOR</h2>
-Glynn Clements
+Glynn Clements<br>
+Markus Metz
<p>
<i>Last changed: $Date$</i>
