[GRASS-SVN] r70408 - grass/branches/releasebranch_7_0/vector/v.db.select
svn_grass at osgeo.org
Sat Jan 21 13:20:31 PST 2017
Author: mmetz
Date: 2017-01-21 13:20:31 -0800 (Sat, 21 Jan 2017)
New Revision: 70408
grass/branches/releasebranch_7_0/vector/v.db.select/main.c
v.db.select: fix #3236 (backport from trunk r70406)
Modified: grass/branches/releasebranch_7_0/vector/v.db.select/main.c
--- grass/branches/releasebranch_7_0/vector/v.db.select/main.c 2017-01-21 21:20:06 UTC (rev 70407)
+++ grass/branches/releasebranch_7_0/vector/v.db.select/main.c 2017-01-21 21:20:31 UTC (rev 70408)
@@ -229,7 +229,7 @@
continue;
if (f_flag->answer) {
- Vect_cidx_find_all(&Map, field_number, -1, cat, list_lines);
+ Vect_cidx_find_all(&Map, field_number, ~GV_AREA, cat, list_lines);
/* if no features are found for this category, don't print
* anything. */
if (list_lines->n_values == 0)
@@ -258,7 +258,7 @@
if (r_flag->answer) {
/* get minimal region extent */
for (i = 0; i < list_lines->n_values; i++) {
line = list_lines->value[i];
if (Vect_get_line_type(&Map, line) == GV_CENTROID) {
