[GRASS-SVN] r70409 - grass-addons/grass7/vector/v.profile
svn_grass at osgeo.org
Sun Jan 22 01:36:47 PST 2017
Author: marisn
Date: 2017-01-22 01:36:47 -0800 (Sun, 22 Jan 2017)
New Revision: 70409
Added:
grass-addons/grass7/vector/v.profile/local_proto.h
grass-addons/grass7/vector/v.profile/processors.c
grass-addons/grass7/vector/v.profile/main.c
grass-addons/grass7/vector/v.profile/v.profile.html
Fix ignoring layer parameter in output;
Fix compilation warnings for strings;
Code cleanup and reindent.
Added: grass-addons/grass7/vector/v.profile/local_proto.h
--- grass-addons/grass7/vector/v.profile/local_proto.h (rev 0)
+++ grass-addons/grass7/vector/v.profile/local_proto.h 2017-01-22 09:36:47 UTC (rev 70409)
@@ -0,0 +1,22 @@
+/* main.c */
+typedef struct
+ double distance;
+ int cat;
+ double z;
+} Result;
+/* Here are stored all profile line matching points */
+extern Result *resultset;
+/* processors.c */
+/* Add point to result data set */
+void add_point(const int, const double, const double, size_t *, const int);
+/* Check if point is on profile line (inside buffer) and calculate distance to it */
+void proc_point(struct line_pnts *, struct line_pnts *,
+ struct line_pnts *, const int, size_t *, const int);
+/* Process all two line intersection points */
+void proc_line(struct line_pnts *, struct line_pnts *,
+ const int, size_t *, const int);
Modified: grass-addons/grass7/vector/v.profile/main.c
--- grass-addons/grass7/vector/v.profile/main.c 2017-01-21 21:20:31 UTC (rev 70408)
+++ grass-addons/grass7/vector/v.profile/main.c 2017-01-22 09:36:47 UTC (rev 70409)
@@ -9,7 +9,7 @@
* PURPOSE: Output vector point/line values along sampling line
- * COPYRIGHT: (C) 2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2008, 2017 by the GRASS Development Team
* This program is free software under the
* GNU General Public License (>=v2).
@@ -20,7 +20,6 @@
* Ability to have "interrupted" profiling line - with holes,
* that are not counted into whole profile length;
* Implement area sampling by printing out boundary crossing place?
- * There is no way how to get CAT values;
* String quoting is unoptimal:
* * What if delimiter equals string quote character?
* * Quotes within strings are not escaped
@@ -36,31 +35,12 @@
#include <grass/dbmi.h>
#include <grass/glocale.h>
-typedef struct
- double distance;
- int cat;
- double z;
-} Result;
+#include "local_proto.h"
-/* Here are stored all profile line matching points */
-static Result *resultset;
-/* Qsort distance comparison function */
static int compdist(const void *, const void *);
-/* Add point to result data set */
-void add_point(struct line_cats *, const double,
- const double, size_t *, const int);
+Result *resultset;
-/* Check if point is on profile line (inside buffer) and calculate distance to it */
-void proc_point(struct line_pnts *, struct line_pnts *,
- struct line_pnts *, struct line_cats *, size_t *, const int);
-/* Process all two line intersection points */
-void proc_line(struct line_pnts *, struct line_pnts *,
- struct line_cats *, size_t *, const int);
int main(int argc, char *argv[])
struct Map_info In, Out, Pro;
@@ -70,7 +50,7 @@
FILE *ascii;
int i, dp, type, otype, id, ncols, nrows, ncats, col, more, open3d,
- layer, pro_layer, *cats, c, field_index;
+ layer, pro_layer, *cats, c, field_index, cat;
size_t rescount;
double xval, yval, bufsize;
const char *mapset, *pro_mapset;
@@ -78,8 +58,8 @@
struct GModule *module;
struct Option *old_map, *new_map, *coords_opt, *buffer_opt, *delim_opt,
- *dp_opt, *layer_opt, *where_opt, *inline_map, *inline_where,
- *inline_layer, *type_opt, *file_opt;
+ *dp_opt, *layer_opt, *where_opt, *inline_map, *inline_where,
+ *inline_layer, *type_opt, *file_opt;
struct Flag *no_column_flag, *no_z_flag;
struct field_info *Fi, *Fpro;
@@ -100,32 +80,24 @@
G_add_keyword(_("transect"));
module->description = _("Vector map profiling tool");
+ /* Map to be profiled */
old_map = G_define_standard_option(G_OPT_V_INPUT);
- old_map->guisection = _("Required");
+ old_map->required = YES;
type_opt = G_define_standard_option(G_OPT_V_TYPE);
type_opt->options = "point,line";
type_opt->answer = "point,line";
type_opt->guisection = _("Selection");
- coords_opt = G_define_option();
- coords_opt->key = "east_north";
- coords_opt->type = TYPE_DOUBLE;
- coords_opt->key_desc = "east,north";
- coords_opt->required = NO;
- coords_opt->multiple = YES;
- coords_opt->label = _("Coordinates for profiling line nodes");
- coords_opt->description = _("Specify profiling line vertexes and nodes");
- coords_opt->guisection = _("Profiling line");
+ where_opt = G_define_standard_option(G_OPT_DB_WHERE);
+ where_opt->guisection = _("Selection");
- buffer_opt = G_define_option();
- buffer_opt->key = "buffer";
- buffer_opt->type = TYPE_DOUBLE;
- buffer_opt->required = YES;
- buffer_opt->answer = "10";
- buffer_opt->label = _("Buffer (tolerance) for points in map units");
- buffer_opt->description = _("How far points can be from sampling line");
+ layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+ layer_opt->answer = "1";
+ layer_opt->description = _("Use features only from specified layer");
+ layer_opt->guisection = _("Selection");
+ /* Text output details */
file_opt = G_define_option();
file_opt->key = "output";
file_opt->type = TYPE_STRING;
@@ -148,14 +120,16 @@
dp_opt->description = _("Number of significant digits");
dp_opt->guisection = _("Format");
- where_opt = G_define_standard_option(G_OPT_DB_WHERE);
- where_opt->guisection = _("Selection");
+ /* Profiling tolerance */
+ buffer_opt = G_define_option();
+ buffer_opt->key = "buffer";
+ buffer_opt->type = TYPE_DOUBLE;
+ buffer_opt->required = YES;
+ buffer_opt->answer = "10";
+ buffer_opt->label = _("Buffer (tolerance) for points in map units");
+ buffer_opt->description = _("How far points can be from sampling line");
- layer_opt = G_define_standard_option(G_OPT_V_FIELD);
- layer_opt->answer = "1";
- layer_opt->description = _("Use features only from specified layer");
- layer_opt->guisection = _("Selection");
+ /* Storing tolerance area (buffer) is useful to examine which points match */
new_map = G_define_option();
new_map->key = "map_output";
new_map->type = TYPE_STRING;
@@ -165,7 +139,7 @@
new_map->gisprompt = "new,vector,vector";
new_map->label = _("Name for profile line and buffer output map");
new_map->description =
- _("Profile line and buffer around it will be written");
+ _("Profile line and buffer around it will be written");
new_map->guisection = _("Output");
no_column_flag = G_define_flag();
@@ -179,7 +153,15 @@
no_z_flag->description = _("Only affects 3D vectors");
no_z_flag->guisection = _("Output");
- /* Options that allow to input profiling line from vector map */
+ /* Two ways of defining profiling line:
+ * - by list of coordinates */
+ coords_opt = G_define_standard_option(G_OPT_M_COORDS);
+ coords_opt->multiple = YES;
+ coords_opt->label = _("Coordinates for profiling line nodes");
+ coords_opt->description = _("Specify profiling line vertexes and nodes");
+ coords_opt->guisection = _("Profiling line");
+ /* - or profiling line can be taken form other vector map */
inline_map = G_define_option();
inline_map->key = "profile_map";
inline_map->type = TYPE_STRING;
@@ -199,7 +181,7 @@
inline_where->multiple = NO;
inline_where->label = _("WHERE conditions for input profile line map");
inline_where->description =
- _("Use to select only one line from profiling line map");
+ _("Use to select only one line from profiling line map");
inline_where->guisection = _("Profiling line");
inline_layer = G_define_option();
@@ -211,60 +193,60 @@
inline_layer->guisection = _("Profiling line");
if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
+ exit(EXIT_FAILURE);
/* Start with simple input validation and then move to more complex ones */
otype = Vect_option_to_types(type_opt);
layer = atoi(layer_opt->answer);
pro_layer = atoi(inline_layer->answer);
if (layer < 1 || pro_layer < 1)
- G_fatal_error(_("Layer 0 not supported"));
+ G_fatal_error(_("Layer 0 not supported"));
/* The precision of the output */
if (dp_opt->answer) {
- if (sscanf(dp_opt->answer, "%d", &dp) != 1)
- G_fatal_error(_("Failed to interpreter 'dp' parameter as an integer"));
+ if (sscanf(dp_opt->answer, "%d", &dp) != 1)
+ G_fatal_error(_("Failed to interpreter 'dp' parameter as an integer"));
/* Get buffer size */
bufsize = fabs(atof(buffer_opt->answer));
if (bufsize < 0)
- G_fatal_error(_("Tolerance value can not be less than 0"));
+ G_fatal_error(_("Tolerance value can not be less than 0"));
/* If new map name is provided, it has to be useable */
if (new_map->answer != NULL)
- if (Vect_legal_filename(new_map->answer) < 1)
- G_fatal_error(_("<%s> is not a valid vector map name"),
- new_map->answer);
+ if (Vect_legal_filename(new_map->answer) < 1)
+ G_fatal_error(_("<%s> is not a valid vector map name"),
+ new_map->answer);
/* inline_where has no use if inline_map has been not provided */
if (inline_where->answer != NULL && inline_map->answer == NULL)
- G_fatal_error(_("No input profile map name provided, but WHERE conditions for it have been set"));
+ G_fatal_error(_("No input profile map name provided, but WHERE conditions for it have been set"));
/* Currently only one profile input method is supported */
if (inline_map->answer != NULL && coords_opt->answer != NULL)
- G_fatal_error(_("Profile input coordinates and vector map are provided. "
- "Please provide only one of them"));
+ G_fatal_error(_("Profile input coordinates and vector map are provided. "
+ "Please provide only one of them"));
if (inline_map->answer == NULL && coords_opt->answer == NULL)
- G_fatal_error(_("No profile input coordinates nor vector map are provided. "
- "Please provide one of them"));
+ G_fatal_error(_("No profile input coordinates nor vector map are provided. "
+ "Please provide one of them"));
/* Where to put module output */
if (file_opt->answer) {
- if (strcmp(file_opt->answer, "-") == 0) {
- ascii = stdout;
- else {
- ascii = fopen(file_opt->answer, "w");
+ if (strcmp(file_opt->answer, "-") == 0) {
+ ascii = stdout;
+ else {
+ ascii = fopen(file_opt->answer, "w");
- if (ascii == NULL) {
- G_fatal_error(_("Unable to open file <%s>"), file_opt->answer);
+ if (ascii == NULL) {
+ G_fatal_error(_("Unable to open file <%s>"), file_opt->answer);
else {
- ascii = stdout;
+ ascii = stdout;
/* Create and initialize struct's where to store points/lines and categories */
@@ -276,37 +258,37 @@
/* Construct profile line from user supplied points */
if (inline_map->answer == NULL) {
- for (i = 0; coords_opt->answers[i] != NULL; i += 2) {
- xval = atof(coords_opt->answers[i]);
- yval = atof(coords_opt->answers[i + 1]);
- Vect_append_point(Profil, xval, yval, 0);
+ for (i = 0; coords_opt->answers[i] != NULL; i += 2) {
+ xval = atof(coords_opt->answers[i]);
+ yval = atof(coords_opt->answers[i + 1]);
+ Vect_append_point(Profil, xval, yval, 0);
- /* Line is built from two coordinates */
- if (i == 2)
- G_fatal_error(_("At least profile start and end coordinates are required!"));
+ /* Line is built from two coordinates */
+ if (i == 2)
+ G_fatal_error(_("At least profile start and end coordinates are required!"));
else {
- /* Check provided profile map name validity */
- if ((pro_mapset = G_find_vector2(inline_map->answer, "")) == NULL)
- G_fatal_error(_("Vector map <%s> not found"), inline_map->answer);
+ /* Check provided profile map name validity */
+ if ((pro_mapset = G_find_vector2(inline_map->answer, "")) == NULL)
+ G_fatal_error(_("Vector map <%s> not found"), inline_map->answer);
if ((mapset = G_find_vector2(old_map->answer, "")) == NULL)
- G_fatal_error(_("Vector map <%s> not found"), old_map->answer);
+ G_fatal_error(_("Vector map <%s> not found"), old_map->answer);
if (Vect_set_open_level(2))
- G_fatal_error(_("Unable to set predetermined vector open level"));
+ G_fatal_error(_("Unable to set predetermined vector open level"));
- /* Open existing vector for reading */
- if (1 > Vect_open_old(&In, old_map->answer, mapset))
- G_fatal_error(_("Unable to open vector map <%s>"), old_map->answer);
+ /* Open existing vector map for reading */
+ if (Vect_open_old(&In, old_map->answer, mapset) < 1)
+ G_fatal_error(_("Unable to open vector map <%s>"), old_map->answer);
/* Process input as 3D only if it's required */
if (!no_z_flag->answer && Vect_is_3d(&In))
- open3d = WITH_Z;
+ open3d = WITH_Z;
else
- open3d = WITHOUT_Z;
+ open3d = WITHOUT_Z;
/* the field separator */
fs = G_option_to_separator(delim_opt);
@@ -314,310 +296,327 @@
/* Let's get vector layers db connections information */
Fi = Vect_get_field(&In, layer);
if (!Fi && where_opt->answer != NULL) {
- Vect_close(&In);
- G_fatal_error(_("No database connection defined for map <%s> layer %d, "
- "but WHERE condition is provided"), old_map->answer,
- layer);
+ Vect_close(&In);
+ G_fatal_error(_("No database connection defined for map <%s> layer %d, "
+ "but WHERE condition is provided"), old_map->answer,
+ layer);
- /* Get profile line from existing vector map */
+ /* Get profile line from an existing vector map */
if (inline_map->answer != NULL) {
- if (1 > Vect_open_old(&Pro, inline_map->answer, pro_mapset))
- inline_map->answer);
- if (inline_where->answer != NULL) {
- Fpro = Vect_get_field(&Pro, pro_layer);
- if (!Fpro) {
- Vect_close(&In);
- Vect_close(&Pro);
- inline_map->answer, pro_layer);
- /* Prepeare strings for use in db_* calls */
- db_init_string(&dbsql);
- db_init_string(&valstr);
- db_init_string(&table_name);
- db_init_handle(&handle);
- G_debug(1,
- "Field number:%d; Name:<%s>; Driver:<%s>; Database:<%s>; Table:<%s>; Key:<%s>",
- Fpro->number, Fpro->name, Fpro->driver, Fpro->database,
- Fpro->table, Fpro->key);
+ /* If we get here, pro_mapset is inicialized */
+ if (1 > Vect_open_old(&Pro, inline_map->answer, pro_mapset))
+ inline_map->answer);
+ if (inline_where->answer != NULL) {
+ Fpro = Vect_get_field(&Pro, pro_layer);
+ if (!Fpro) {
+ Vect_close(&In);
+ Vect_close(&Pro);
+ inline_map->answer, pro_layer);
+ /* Prepeare strings for use in db_* calls */
+ db_init_string(&dbsql);
+ db_init_string(&valstr);
+ db_init_string(&table_name);
+ db_init_handle(&handle);
+ G_debug(1,
+ "Field number:%d; Name:<%s>; Driver:<%s>; Database:<%s>; Table:<%s>; Key:<%s>",
+ Fpro->number, Fpro->name, Fpro->driver, Fpro->database,
+ Fpro->table, Fpro->key);
- /* Prepearing database for use */
- driver = db_start_driver(Fpro->driver);
- if (driver == NULL) {
- Vect_close(&In);
- Vect_close(&Pro);
- G_fatal_error(_("Unable to start driver <%s>"), Fpro->driver);
- db_set_handle(&handle, Fpro->database, NULL);
- if (db_open_database(driver, &handle) != DB_OK) {
- Vect_close(&In);
- Vect_close(&Pro);
- G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
- Fpro->database, driver);
- db_set_string(&table_name, Fpro->table);
- if (db_describe_table(driver, &table_name, &table) != DB_OK) {
- Vect_close(&In);
- Vect_close(&Pro);
- G_fatal_error(_("Unable to describe table <%s>"),
- Fpro->table);
- ncols = db_get_table_number_of_columns(table);
+ /* Prepearing database for use */
+ driver = db_start_driver(Fpro->driver);
+ if (driver == NULL) {
+ Vect_close(&In);
+ Vect_close(&Pro);
+ G_fatal_error(_("Unable to start driver <%s>"), Fpro->driver);
+ db_set_handle(&handle, Fpro->database, NULL);
+ if (db_open_database(driver, &handle) != DB_OK) {
+ Vect_close(&In);
+ Vect_close(&Pro);
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Fpro->database, Fpro->driver);
+ db_set_string(&table_name, Fpro->table);
+ if (db_describe_table(driver, &table_name, &table) != DB_OK) {
+ Vect_close(&In);
+ Vect_close(&Pro);
+ G_fatal_error(_("Unable to describe table <%s>"),
+ Fpro->table);
+ ncols = db_get_table_number_of_columns(table);
- ncats =
- db_select_int(driver, Fpro->table, Fpro->key,
- inline_where->answer, &cats);
- if (ncats < 1) {
- Vect_close(&In);
- Vect_close(&Pro);
- G_fatal_error(_("No features match Your query"));
- if (ncats > 1) {
- Vect_close(&In);
- Vect_close(&Pro);
- G_fatal_error(_("Your query matches more than one record in input profiling map. "
- "Currently it's not supported. Enhance WHERE conditions to get only one line."));
- if (!(Catlist = Vect_new_list())) {
- Vect_close(&In);
- Vect_close(&Pro);
- G_fatal_error(_("Error while initialising line list"));
- /* Get all features matching specified CAT value */
- Vect_cidx_find_all(&Pro, pro_layer, GV_LINE, cats[0], Catlist);
- if (Catlist->n_values > 1) {
- Vect_close(&In);
- Vect_close(&Pro);
- if (Vect_read_line(&Pro, Profil, NULL, Catlist->value[0]) !=
- GV_LINE) {
- G_fatal_error(_("Error while reading vector feature from profile line map"));
- else {
- /* WHERE not provided -> assuming profiling line map contains only one line */
- c = 0;
- while ((type = Vect_read_next_line(&Pro, Profil, NULL)) > 0) {
- if (type & GV_LINE)
- c++;
- /* Currently we support only one SINGLE input line */
- if (c > 1) {
- Vect_close(&In);
- Vect_close(&Pro);
- G_fatal_error(_("Your input profile map contains more than one line. "
- "Currently it's not supported. Provide WHERE conditions to get only one line."));
+ ncats =
+ db_select_int(driver, Fpro->table, Fpro->key,
+ inline_where->answer, &cats);
+ if (ncats < 1) {
+ Vect_close(&In);
+ Vect_close(&Pro);
+ G_fatal_error(_("No features match Your query"));
+ if (ncats > 1) {
+ Vect_close(&In);
+ Vect_close(&Pro);
+ G_fatal_error(_("Your query matches more than one record in input profiling map. "
+ "Currently it's not supported. Enhance WHERE conditions to get only one line."));
+ if (!(Catlist = Vect_new_list())) {
+ Vect_close(&In);
+ Vect_close(&Pro);
+ G_fatal_error(_("Error while initialising line list"));
+ /* Get all features matching specified CAT value */
+ Vect_cidx_find_all(&Pro, pro_layer, GV_LINE, cats[0], Catlist);
+ if (Catlist->n_values > 1) {
+ Vect_close(&In);
+ Vect_close(&Pro);
+ if (Vect_read_line(&Pro, Profil, NULL, Catlist->value[0]) !=
+ GV_LINE) {
+ G_fatal_error(_("Error while reading vector feature from profile line map"));
+ else {
+ /* WHERE not provided -> assuming profiling line map contains only one line */
+ c = 0;
+ while ((type = Vect_read_next_line(&Pro, Profil, NULL)) > 0) {
+ if (type & GV_LINE)
+ c++;
+ /* Currently we support only one SINGLE input line */
+ if (c > 1) {
+ Vect_close(&In);
+ Vect_close(&Pro);
+ G_fatal_error(_("Your input profile map contains more than one line. "
+ "Currently it's not supported. Provide WHERE conditions to get only one line."));
/* Create a buffer around profile line for point sampling
Tolerance is calculated in such way that buffer will have flat end and no cap. */
Vect_line_buffer(Profil, bufsize, 1 - (bufsize * cos((2 * M_PI) / 2)),
- Buffer);
+ Buffer);
Vect_cat_set(Cats, 1, 1);
+ /* Should we store used buffer for later examination? */
if (new_map->answer != NULL) {
- /* Open new vector for reading/writing */
- if (0 > Vect_open_new(&Out, new_map->answer, WITHOUT_Z)) {
- Vect_close(&In);
- G_fatal_error(_("Unable to create vector map <%s>"),
- new_map->answer);
+ /* Open new vector for reading/writing */
+ if (0 > Vect_open_new(&Out, new_map->answer, WITHOUT_Z)) {
+ Vect_close(&In);
+ G_fatal_error(_("Unable to create vector map <%s>"),
+ new_map->answer);
- /* Write profile line and it's buffer into new vector map */
- Vect_write_line(&Out, GV_LINE, Profil, Cats);
- /* No category for boundary */
- Vect_reset_cats(Cats);
- Vect_write_line(&Out, GV_BOUNDARY, Buffer, Cats);
+ /* Write profile line and it's buffer into new vector map */
+ Vect_write_line(&Out, GV_LINE, Profil, Cats);
+ /* No category for boundary */
+ Vect_reset_cats(Cats);
+ Vect_write_line(&Out, GV_BOUNDARY, Buffer, Cats);
+ /* Here starts processing of input map */
rescount = 0;
resultset = NULL;
/* If input vector has a database connection... */
if (Fi != NULL) {
+ field_index = Vect_cidx_get_field_index(&In, layer);
+ if (field_index < 0) {
+ G_fatal_error(_("Vector map <%s> does not have cat's defined on layer %d"),
+ old_map->answer, layer);
- G_debug(1,
- Fi->number, Fi->name, Fi->driver, Fi->database, Fi->table,
- Fi->key);
- driver = db_start_driver(Fi->driver);
- Vect_close(&In);
- G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
- db_set_handle(&handle, Fi->database, NULL);
- Vect_close(&In);
- Fi->database, driver);
- db_set_string(&table_name, Fi->table);
- Vect_close(&In);
- G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
+ G_debug(1,
+ Fi->number, Fi->name, Fi->driver, Fi->database, Fi->table,
+ Fi->key);
- /* Create vector feature list for future processing by applying SQL WHERE conditions... */
- if (where_opt->answer != NULL) {
- ncats =
- db_select_int(driver, Fi->table, Fi->key, where_opt->answer,
- &cats);
- if (ncats < 1)
- field_index = Vect_cidx_get_field_index(&In, layer);
- for (i = 0; i < ncats; i++) {
- c = Vect_cidx_find_next(&In, field_index, cats[i],
- otype, 0, &type, &id);
- /* Crunch over all lines, that match specified CAT */
- while (c >= 0) {
- c++;
- if (type & otype) {
- switch (Vect_read_line(&In, Points, Cats, id)) {
- case GV_POINT:
- proc_point(Points, Profil, Buffer, Cats,
- &rescount, open3d);
- break;
- case GV_LINE:
- Vect_reset_line(Ipoints);
- if (Vect_line_get_intersections
- (Profil, Points, Ipoints, open3d) > 0)
- proc_line(Ipoints, Profil, Cats, &rescount,
- open3d);
- break;
- else
- G_fatal_error
- ("Error in Vect_cidx_find_next function! Report a bug.");
- c = Vect_cidx_find_next(&In, field_index, cats[i], otype,
- c, &type, &id);
+ driver = db_start_driver(Fi->driver);
+ Vect_close(&In);
+ G_fatal_error(_("Unable to start driver <%s>"), Fi->driver);
+ db_set_handle(&handle, Fi->database, NULL);
+ Vect_close(&In);
+ Fi->database, Fi->driver);
+ db_set_string(&table_name, Fi->table);
+ Vect_close(&In);
+ G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
+ /* Create vector feature list for future processing by applying SQL WHERE conditions... */
+ if (where_opt->answer != NULL) {
+ ncats =
+ db_select_int(driver, Fi->table, Fi->key, where_opt->answer,
+ &cats);
+ if (ncats < 1)
+ for (i = 0; i < ncats; i++) {
+ c = Vect_cidx_find_next(&In, field_index, cats[i],
+ otype, 0, &type, &id);
+ /* Crunch over all points/lines, that match specified CAT */
+ while (c >= 0) {
+ c++;
+ if (type & otype) {
+ switch (Vect_read_line(&In, Points, Cats, id)) {
+ case GV_POINT:
+ Vect_cat_get(Cats, layer, &cat);
+ proc_point(Points, Profil, Buffer, cat,
+ &rescount, open3d);
+ break;
+ case GV_LINE:
+ Vect_reset_line(Ipoints);
+ if (Vect_line_get_intersections
+ (Profil, Points, Ipoints, open3d) > 0) {
+ proc_line(Ipoints, Profil, cat, &rescount,
+ open3d);
+ break;
+ else
+ G_fatal_error
+ ("Error in Vect_cidx_find_next function! Report a bug.");
+ c = Vect_cidx_find_next(&In, field_index, cats[i], otype,
+ c, &type, &id);
/* Process all lines IF no database exists or WHERE was not provided.
Read in single line and get it's type */
if (Fi == NULL || (where_opt->answer == NULL && Fi != NULL)) {
- while ((type = Vect_read_next_line(&In, Points, Cats)) > 0) {
- if (type & GV_POINT)
- proc_point(Points, Profil, Buffer, Cats, &rescount, open3d);
- if (type & GV_LINE) {
- proc_line(Ipoints, Profil, Cats, &rescount, open3d);
+ while ((type = Vect_read_next_line(&In, Points, Cats)) > 0) {
+ if (type & GV_POINT) {
+ proc_point(Points, Profil, Buffer, cat, &rescount, open3d);
+ if (type & GV_LINE) {
+ proc_line(Ipoints, Profil, cat, &rescount, open3d);
/* We don't need input vector anymore */
Vect_close(&In);
- G_debug(1, "There are %d features matching profile line", rescount);
+ G_debug(1, "There are %zu features matching profile line", rescount);
/* Sort results by distance, cat */
qsort(&resultset[0], rescount, sizeof(Result), compdist);
/* Print out column names */
if (!no_column_flag->answer) {
- fprintf(ascii, "Number%sDistance", fs);
- if (open3d == WITH_Z)
- fprintf(ascii, "%sZ", fs);
- if (Fi != NULL) {
- for (col = 0; col < ncols; col++) {
- column = db_get_table_column(table, col);
- fprintf(ascii, "%s%s", fs, db_get_column_name(column));
- fprintf(ascii, "\n");
+ fprintf(ascii, "Number%sDistance", fs);
+ if (open3d == WITH_Z)
+ fprintf(ascii, "%sZ", fs);
+ if (Fi != NULL) {
+ /* ncols are initialized here from previous Fi != NULL if block */
+ for (col = 0; col < ncols; col++) {
+ column = db_get_table_column(table, col);
+ fprintf(ascii, "%s%s", fs, db_get_column_name(column));
+ fprintf(ascii, "\n");
/* Print out result */
for (i = 0; i < rescount; i++) {
- fprintf(ascii, "%d%s%.*f", i + 1, fs, dp, resultset[i].distance);
- fprintf(ascii, "%s%.*f", fs, dp, resultset[i].z);
- if (Fi != NULL) {
- sprintf(sql, "select * from %s where %s=%d", Fi->table, Fi->key,
- resultset[i].cat);
- G_debug(1, "SQL: \"%s\"", sql);
- db_set_string(&dbsql, sql);
- if (db_open_select_cursor(driver, &dbsql, &cursor, DB_SEQUENTIAL)
- != DB_OK)
- G_warning(_("Unabale to get attribute data for cat %d"),
- else {
- nrows = db_get_num_rows(&cursor);
- G_debug(1, "Result count: %d", nrows);
- table = db_get_cursor_table(&cursor);
+ fprintf(ascii, "%d%s%.*f", i + 1, fs, dp, resultset[i].distance);
+ fprintf(ascii, "%s%.*f", fs, dp, resultset[i].z);
+ if (Fi != NULL) {
+ sprintf(sql, "select * from %s where %s=%d", Fi->table, Fi->key,
+ resultset[i].cat);
+ G_debug(2, "SQL: \"%s\"", sql);
+ db_set_string(&dbsql, sql);
+ /* driver IS initialized here in case if Fi != NULL */
+ if (db_open_select_cursor(driver, &dbsql, &cursor, DB_SEQUENTIAL)
+ != DB_OK)
+ G_warning(_("Unabale to get attribute data for cat %d"),
+ else {
+ nrows = db_get_num_rows(&cursor);
+ G_debug(1, "Result count: %d", nrows);
+ table = db_get_cursor_table(&cursor);
- if (nrows > 0) {
- if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
- G_warning(_("Error while retreiving database record for cat %d"),
- else {
- /* Column description retreiving is fast, as they live in provided table structure */
- db_convert_column_value_to_string(column,
- &valstr);
- type = db_get_column_sqltype(column);
+ if (nrows > 0) {
+ if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
+ G_warning(_("Error while retreiving database record for cat %d"),
+ else {
+ /* Column description retreiving is fast, as they live in provided table structure */
+ db_convert_column_value_to_string(column,
+ &valstr);
+ type = db_get_column_sqltype(column);
- /* Those values should be quoted */
- if (type == DB_SQL_TYPE_CHARACTER ||
- type == DB_SQL_TYPE_DATE ||
- type == DB_SQL_TYPE_TIME ||
- type == DB_SQL_TYPE_TIMESTAMP ||
- type == DB_SQL_TYPE_INTERVAL ||
- type == DB_SQL_TYPE_TEXT ||
- type == DB_SQL_TYPE_SERIAL)
- fprintf(ascii, "%s\"%s\"", fs,
- db_get_string(&valstr));
- else
- else {
- fprintf(ascii, "%s", fs);
- db_close_cursor(&cursor);
- /* Terminate attribute data line and flush data to provided output (file/stdout) */
- if (fflush(ascii))
+ /* Those values should be quoted */
+ if (type == DB_SQL_TYPE_CHARACTER ||
+ type == DB_SQL_TYPE_DATE ||
+ type == DB_SQL_TYPE_TIME ||
+ type == DB_SQL_TYPE_TIMESTAMP ||
+ type == DB_SQL_TYPE_INTERVAL ||
+ type == DB_SQL_TYPE_TEXT ||
+ type == DB_SQL_TYPE_SERIAL)
+ fprintf(ascii, "%s\"%s\"", fs,
+ db_get_string(&valstr));
+ else
+ else {
+ fprintf(ascii, "%s", fs);
+ db_close_cursor(&cursor);
+ /* Terminate attribute data line and flush data to provided output (file/stdout) */
+ if (fflush(ascii))
G_fatal_error(_("Can not write data portion to provided output"));
/* Build topology for vector map and close them */
- Vect_build(&Out);
- Vect_close(&Out);
+ Vect_build(&Out);
+ Vect_close(&Out);
if (Fi != NULL)
- db_close_database_shutdown_driver(driver);
+ db_close_database_shutdown_driver(driver);
if (ascii != NULL)
- fclose(ascii);
+ fclose(ascii);
/* Don't forget to report to caller sucessfull end of data processing :) */
exit(EXIT_SUCCESS);
@@ -631,67 +630,13 @@
G_debug(5, "Comparing %f with %f", r1->distance, r2->distance);
if (r1->distance == r2->distance) {
- if (r1->cat > r2->cat)
- return 1;
- else
- return -1;
+ if (r1->cat > r2->cat)
+ return 1;
+ else
+ return -1;
if (r1->distance > r2->distance)
- return 1;
+ return 1;
else
- return -1;
+ return -1;
-void add_point(struct line_cats *Cats, const double dist,
- const double z, size_t *rescount, const int open3d)
- Result *tmp;
- tmp =
- (Result *) G_realloc(resultset, sizeof(Result) * (*rescount + 1));
- /* Don't leak memory if realloc fails */
- if (!tmp) {
- G_free(resultset);
- G_fatal_error(_("Out of memory"));
- else
- resultset = tmp;
- resultset[*rescount].distance = dist;
- Vect_cat_get(Cats, 1, &resultset[*rescount].cat);
- resultset[*rescount].z = z;
- (*rescount)++;
- G_debug(3, "Distance of point %d is %f", *rescount,
- resultset[*rescount - 1].distance);
-void proc_point(struct line_pnts *Points, struct line_pnts *Profil,
- struct line_pnts *Buffer, struct line_cats *Cats,
- size_t *rescount, const int open3d)
- double dist;
- if (Vect_point_in_poly(*Points->x, *Points->y, Buffer) > 0) {
- Vect_line_distance(Profil, *Points->x, *Points->y, *Points->z,
- open3d, NULL, NULL, NULL, NULL, NULL, &dist);
- add_point(Cats, dist, *Points->z, rescount, open3d);
-/* Process all line intersection points */
-void proc_line(struct line_pnts *Ipoints, struct line_pnts *Profil,
- struct line_cats *Cats, size_t *rescount, const int open3d)
- int i;
- double dist;
- /* Add all line and profile intersection points to resultset */
- for (i = 0; i < Ipoints->n_points; i++) {
- Vect_line_distance(Profil, Ipoints->x[i], Ipoints->y[i],
- Ipoints->z[i], open3d, NULL, NULL, NULL, NULL,
- NULL, &dist);
- add_point(Cats, dist, Ipoints->z[i], rescount, open3d);
Added: grass-addons/grass7/vector/v.profile/processors.c
--- grass-addons/grass7/vector/v.profile/processors.c (rev 0)
+++ grass-addons/grass7/vector/v.profile/processors.c 2017-01-22 09:36:47 UTC (rev 70409)
@@ -0,0 +1,76 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <grass/config.h>
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+/* For batch memory allocation */
+static size_t alloc_size = 0;
+void add_point(const int cat, const double dist,
+ const double z, size_t * rescount, const int open3d)
+ Result *tmp;
+ /* Allocate memory in batches */
+ if (*rescount + 1 > alloc_size) {
+ alloc_size += 100;
+ tmp =
+ (Result *) G_realloc(resultset,
+ sizeof(Result) * (*rescount + 100));
+ /* Don't leak memory if realloc fails */
+ if (!tmp) {
+ G_free(resultset);
+ G_fatal_error(_("Out of memory"));
+ else
+ resultset = tmp;
+ resultset[*rescount].distance = dist;
+ resultset[*rescount].cat = cat;
+ //Vect_cat_get(Cats, field_index, &resultset[*rescount].cat);
+ resultset[*rescount].z = z;
+ (*rescount)++;
+ G_debug(3, "Distance of point %zu is %f", *rescount,
+ resultset[*rescount - 1].distance);
+void proc_point(struct line_pnts *Points, struct line_pnts *Profil,
+ struct line_pnts *Buffer, const int cat,
+ size_t * rescount, const int open3d)
+ double dist;
+ if (Vect_point_in_poly(*Points->x, *Points->y, Buffer) > 0) {
+ Vect_line_distance(Profil, *Points->x, *Points->y, *Points->z,
+ open3d, NULL, NULL, NULL, NULL, NULL, &dist);
+ add_point(cat, dist, *Points->z, rescount, open3d);
+/* Process all line intersection points */
+void proc_line(struct line_pnts *Ipoints, struct line_pnts *Profil,
+ const int cat, size_t * rescount, const int open3d)
+ int i;
+ double dist;
+ /* Add all line and profile intersection points to resultset */
+ for (i = 0; i < Ipoints->n_points; i++) {
+ Vect_line_distance(Profil, Ipoints->x[i], Ipoints->y[i],
+ Ipoints->z[i], open3d, NULL, NULL, NULL, NULL,
+ NULL, &dist);
+ add_point(cat, dist, Ipoints->z[i], rescount, open3d);
Modified: grass-addons/grass7/vector/v.profile/v.profile.html
--- grass-addons/grass7/vector/v.profile/v.profile.html 2017-01-21 21:20:31 UTC (rev 70408)
+++ grass-addons/grass7/vector/v.profile/v.profile.html 2017-01-22 09:36:47 UTC (rev 70409)
@@ -1,29 +1,26 @@
<h2>DESCRIPTION</h2>
-This module will print out distance and attributes to points/lines
-along a profiling line. Distance is calculated from first profiling line
-coordinate pair or from the beginning of vector line
-<!-- TODO: update
-(use "Line directions" feature in gis.m to see distance calculation direction).
-Output can go to file or stdout.
+<p>This module will print out distance and attributes of points/lines
+along a profiling line. Distance is calculated from the first profiling line
+coordinate pair or from the beginning of vector line.<br>
Buffer (tolerance) parameter sets how far point can be
-located from profiling line and still be included in output data set.
+located from profiling line and still be included in output data set.<br>
Output map option can be used to visually check which points are
profiled. Buffer (tolerance) setting does not affect lines. Lines are
-sampled at their crossing point with profiling line. By default Z
-values are printed if input vector is a 3D map. It can be disabled with
--z flag. Profiling line can be provided as N,E coordinate pairs or can
+sampled at their crossing point with profiling line.<br>
+By default Z values are printed if input vector is a 3D map. It can be disabled with
+-z flag.<br>
+Profiling line can be provided as N,E coordinate pairs or can
come from input vector map. As currently profiling line must be single
line, one should use profile_where parameter to select single line from
-profile input map if it contains multiple features.
+profile input map if it contains multiple features.</p>
<h2>NOTE</h2>
-Currently module can profile only points and lines (including 3D ones).
+<p>Currently module can profile only points and lines (including 3D ones).
Areas and other complex features are not supported. If one can provide
reasonable examples how area sampling should work and why it is
-important, area (or any other feature type) sampling can be added.
+important, area (or any other feature type) sampling can be added.</p>
<h2>EXAMPLES</h2>
@@ -60,11 +57,15 @@
<h2>BUGS</h2>
-Strings are enclosed in double quotes ", still quotes within string are
-not escaped.
+<p>Strings are enclosed in double quotes ", still quotes within string are
+not escaped.</p>
<p>
-Vector CAT values are not outputed. Only way how to get CAT value is from
-attribute table.
+Output does not contain Vector CAT values. Only way how to get CAT value is from
+the attribute table.</p>
+<p>If sampled feature (point, line) contains multiple attribute entries
+(has multiple CAT values), only the first one is reported. If this is a
+limitation in some practical use case, open a feature request in GRASS GIS
+issue tracker.</p>
<h2>SEE ALSO</h2>
