[GRASS-SVN] r70460 - grass-addons/grass7/imagery/i.superpixels.slic
svn_grass at osgeo.org
Mon Jan 30 14:13:45 PST 2017
Author: mmetz
Date: 2017-01-30 14:13:45 -0800 (Mon, 30 Jan 2017)
New Revision: 70460
grass-addons/grass7/imagery/i.superpixels.slic/Makefile
grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html
grass-addons/grass7/imagery/i.superpixels.slic/main.c
grass-addons/grass7/imagery/i.superpixels.slic/minsize.c
i.superpixels.slic: use segment lib, update manual
Modified: grass-addons/grass7/imagery/i.superpixels.slic/Makefile
--- grass-addons/grass7/imagery/i.superpixels.slic/Makefile 2017-01-30 20:34:57 UTC (rev 70459)
+++ grass-addons/grass7/imagery/i.superpixels.slic/Makefile 2017-01-30 22:13:45 UTC (rev 70460)
@@ -4,8 +4,8 @@
PGM = i.superpixels.slic
-LIBES = $(IMAGERYLIB) $(RASTERLIB) $(GISLIB)
-DEPENDENCIES = $(IMAGERYDEP) $(RASTERDEP) $(GISDEP)
+LIBES = $(IMAGERYLIB) $(RASTERLIB) $(SEGMENTLIB) $(GISLIB)
+DEPENDENCIES = $(IMAGERYDEP) $(RASTERDEP) $(SEGMENTDEP) $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html
--- grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html 2017-01-30 20:34:57 UTC (rev 70459)
+++ grass-addons/grass7/imagery/i.superpixels.slic/i.superpixels.slic.html 2017-01-30 22:13:45 UTC (rev 70460)
@@ -1,24 +1,68 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-<EM>i.superpixels.slic</EM> performs superpixel segmentation
+<em>i.superpixels.slic</em> performs superpixel segmentation using a
+k means method. The number of superpixels is determined either with the
+<b>k</b> option (number of superpixels) or with the <b>step</b> option
+(distance between initial super pixel centers).
+<p>
+The <b>co</b> option controls the compactness of the resulting
+superpixels. A larger <b>co</b> value will cause spatially more
+compact, but also spectrally more heterogeneous superpixels. This is
+the most important parameter of the module. A reasonable value should
+be determined for small test regions before applying the module to a
+large region.
-<H2>NOTES</H2>
-This code performs superpixel segmentation as explained in the paper:
-"SLIC Superpixels", Radhakrishna Achanta, Appu Shaji, Kevin Smith, Aurelien Lucchi, Pascal Fua, and Sabine Susstrunk.
-EPFL Technical Report no. 149300, June 2010.
+<h2>NOTES</h2>
+In each iteration, the assigned of pixels to superpixels and the
+superpixels themselves (spatial and spectral means) are updated until
+either the maximum number of iterations is reached or until the
+superpixels do not change any more. More iterations will provide better
+results but will increase processing time. Recommended are about 500
+iterations for best results (stabilized superpixels).
+<p>
+If a minimum segment size of 2 or larger is given with the <b>min</b>
+parameter, segments with a smaller pixel count will be merged with
+their most similar neighbor.
<p>
+If the <b>-n</b> flag is used, the spectral distance of a pixel to a
+given superpixel is divided by the maximum previously observed spectral
+distance to that superpixel. This is the so-called <em>SLIC0</em> (SLIC
+zero) method. After each iteration, the largest spectral distance is
+determined for each superpixel separately. In the next iteration,
+spectral distances of pixels to superpixels are normalized by the
+largest spectral distance of the current superpixel.
+<p>
+That means that more heterogeneous superpixels have a larger maximum
+spectral distance. For a given pixel, the normalized spectral distance
+will be smaller for a more heterogeneous superpixel than for a more
+homogeneous superpixel. This favours more heterogeneous superpixels
+which can steal pixels from more homogeneous superpixels even if the
+not normalized spectral distance of a pixel to a homogeneous superpixel
+is smaller than to a heterogeneous pixel. As a consequence,
+heterogeneous superpixels can become larger and and even more
+heterogeneous. This effect becomes stronger with larger differences in
+the spectral homogeneity of neighboring superpixels.
-<H2>TODO</H2>
+<h2>REFERENCES</h2>
+"SLIC Superpixels", Radhakrishna Achanta, Appu Shaji, Kevin Smith,
+Aurelien Lucchi, Pascal Fua, and Sabine Susstrunk. EPFL Technical
+Report no. 149300, June 2010.
-<H2>SEE ALSO</H2>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.gui.iclass.html">g.gui.iclass</a>,
+<a href="i.group.html">i.group</a>,
+<a href="i.segment.html">i.segment</a>,
+<a href="i.maxlik.html">i.maxlik</a>,
+<a href="i.smap.html">i.smap</a>,
+<a href="r.kappa.html">r.kappa</a>
+</em>
-<H2>AUTHORS</H2>
+<h2>AUTHORS</h2>
-Rashad Kanavath, India <BR>
+Rashad Kanavath, India <br>
+Markus Metz
<p>
<i>Last changed: $Date$</i>
Modified: grass-addons/grass7/imagery/i.superpixels.slic/main.c
--- grass-addons/grass7/imagery/i.superpixels.slic/main.c 2017-01-30 20:34:57 UTC (rev 70459)
+++ grass-addons/grass7/imagery/i.superpixels.slic/main.c 2017-01-30 22:13:45 UTC (rev 70460)
@@ -17,17 +17,14 @@
-#include <grass/config.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
#include <grass/gis.h>
#include <grass/raster.h>
+#include <grass/segment.h>
+#include <grass/imagery.h>
#include <grass/glocale.h>
-#include <grass/imagery.h>
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <math.h>
-#include <limits.h>
-#include <float.h>
#ifndef MAX
#define MAX(x,y) ((x) > (y) ? (x) : (y))
@@ -36,11 +33,11 @@
#define MIN(x,y) ((x) < (y) ? (x) : (y))
#endif
-int SLIC_EnforceLabelConnectivity(int **labels, int ncols, int nrows,
- int **nlabels, int minsize);
+int SLIC_EnforceLabelConnectivity(SEGMENT *k_seg, int ncols, int nrows,
+ SEGMENT *nk_seg, int minsize);
-int merge_small_clumps(DCELL ***pdata, int nbands,
- int **klabels, int nlabels,
+int merge_small_clumps(SEGMENT *bands_seg, int nbands,
+ SEGMENT *k_seg, int nlabels,
int diag, int minsize);
int main(int argc, char *argv[])
@@ -48,7 +45,7 @@
struct GModule *module; /* GRASS module for parsing arguments */
struct Option *opt_grp; /* imagery group input option */
struct Option *opt_iteration, *opt_super_pixels, *opt_step,
- *opt_compactness, *opt_minsize;
+ *opt_compactness, *opt_minsize, *opt_mem;
struct Option *opt_out; /* option for output */
struct Flag *flag_n;
@@ -62,6 +59,9 @@
CELL *obuf;
struct Colors colors;
struct History hist;
+ int nseg;
+ double segs_mb, k_mb;
int n_iterations, n_super_pixels, numk, numlabels, slic0;
int nrows, ncols, row, col, b, k;
@@ -70,9 +70,10 @@
int superpixelsize, minsize;
int step;
int offset;
- DCELL ***pdata;
- int **klabels, **nlabels, schange;
- double ***dists;
+ DCELL *pdata;
+ double *dists;
+ SEGMENT bands_seg, k_seg, nk_seg, dist_seg;
+ int schange;
double xerrperstrip, yerrperstrip;
int xstrips, ystrips, xoff, yoff, xerr, yerr;
@@ -126,15 +127,16 @@
opt_step->key = "step";
opt_step->type = TYPE_INTEGER;
opt_step->required = NO;
- opt_step->label = _("Step size between super pixels");
- opt_step->description = _("Step size has precedence of number of super pixels");
+ opt_step->label = _("Distance (number of cells) between initial super pixel centers");
+ opt_step->description = _("A step size > 0 overrides the number of super pixels");
opt_step->answer = "0";
opt_compactness = G_define_option();
opt_compactness->key = "co";
opt_compactness->type = TYPE_DOUBLE;
opt_compactness->required = NO;
- opt_compactness->description = _("Compactness");
+ opt_compactness->label = _("Compactness");
+ opt_compactness->description = _("A larger value causes more compact superpixels");
opt_compactness->answer = "1";
opt_minsize = G_define_option();
@@ -144,10 +146,17 @@
opt_minsize->description = _("Minimum superpixel size");
opt_minsize->answer = "1";
+ opt_mem = G_define_option();
+ opt_mem->key = "memory";
+ opt_mem->type = TYPE_INTEGER;
+ opt_mem->required = NO;
+ opt_mem->answer = "300";
+ opt_mem->description = _("Memory in MB");
flag_n = G_define_flag();
flag_n->key = 'n';
flag_n->label = _("Normalize spectral distances");
- flag_n->description = _("Equvivalent to SLIC zero (SCLI0)");
+ flag_n->description = _("Equvivalent to SLIC zero (SLIC0)");
/* options and flags parser */
@@ -217,6 +226,17 @@
+ segs_mb = 300;
+ if (opt_mem->answer) {
+ int mb = 300;
+ if (sscanf(opt_mem->answer, "%d", &mb) != 1) {
+ G_fatal_error(_("Illegal value for memory (%s)"),
+ opt_mem->answer);
+ segs_mb = mb;
slic0 = flag_n->answer;
outname = opt_out->answer;
@@ -263,6 +283,33 @@
G_debug(1, "yerrperstrip = %g", yerrperstrip);
G_debug(1, "numk = %d", numk);
+ /* segment structures */
+ k_mb = 2 * (sizeof(DCELL) * nbands + 2 * sizeof(double)) + sizeof(double);
+ k_mb = k_mb * numk / (1024. * 1024.);
+ G_debug(1, "MB for seeds: %g", k_mb);
+ if (k_mb >= segs_mb)
+ G_fatal_error(_("Not enough memory, increase %s option"), opt_mem->answer);
+ segs_mb -= k_mb;
+ G_debug(1, "MB for temporary data: %g", segs_mb);
+ nseg = 1024. * 1024. * segs_mb / (64 * 64 * (sizeof(DCELL) * nbands + sizeof(double) * 2 + sizeof(int)));
+ G_debug(1, "Number of segments in memory: %d", nseg);
+ if (Segment_open(&bands_seg, G_tempfile(), nrows, ncols, 64, 64,
+ sizeof(DCELL) * nbands, nseg) != 1)
+ G_fatal_error("Unable to create input temporary file");
+ if (Segment_open(&k_seg, G_tempfile(), nrows, ncols, 64, 64,
+ sizeof(int), nseg) != 1)
+ if (Segment_open(&dist_seg, G_tempfile(), nrows, ncols, 64, 64,
+ sizeof(double) * 2, nseg) != 1)
/* load input bands */
G_message(_("Loading input..."));
pdata = G_malloc(sizeof(DCELL *) * nbands);
@@ -282,28 +329,33 @@
&drange);
Rast_get_fp_range_min_max(&drange, &min[b], &max[b]);
rng[b] = max[b] - min[b];
- pdata = G_malloc(sizeof(DCELL **) * nrows);
+ pdata = G_malloc(sizeof(DCELL) * nbands);
+ dists = G_malloc(sizeof(double) * 2);
+ dists[0] = dists[1] = 0;
+ k = -1;
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
- pdata[row] = G_malloc(sizeof(DCELL *) * ncols);
for (b = 0; b < nbands; b++)
Rast_get_d_row(ifd[b], ibuf[b], row);
for (col = 0; col < ncols; col++) {
- pdata[row][col] = G_malloc(sizeof(DCELL) * nbands);
for (b = 0; b < nbands; b++) {
if (Rast_is_d_null_value(&ibuf[b][col])) {
- Rast_set_d_null_value(pdata[row][col], nbands);
+ Rast_set_d_null_value(pdata, nbands);
break;
- pdata[row][col][b] = (ibuf[b][col] - min[b]) / rng[b];
+ pdata[b] = (ibuf[b][col] - min[b]) / rng[b];
+ if (Segment_put(&bands_seg, (void *)pdata, row, col) != 1)
+ G_fatal_error(_("Unable to write to temporary file"));
+ if (Segment_put(&k_seg, (void *)&k, row, col) != 1)
+ if (Segment_put(&dist_seg, (void *)&dists, row, col) != 1)
G_percent(nrows, nrows, 2);
@@ -362,9 +414,10 @@
seedy = (y * offset + yoff + ye);
- if (!Rast_is_d_null_value(pdata[seedy][seedx])) {
+ Segment_get(&bands_seg, (void *)pdata, seedy, seedx);
+ if (!Rast_is_d_null_value(pdata)) {
- kseedsb[k][b] = pdata[seedy][seedx][b];
+ kseedsb[k][b] = pdata[b];
kseedsx[k] = seedx;
kseedsy[k] = seedy;
@@ -375,23 +428,6 @@
if (k != numk)
G_warning(_("Initialized %d of %d seeds"), k, numk);
- /* allocate cell variables */
- klabels = G_malloc(sizeof(int *) * nrows);
- for (row = 0; row < nrows; row++) {
- klabels[row] = G_malloc(sizeof(int) * ncols);
- for (col = 0; col < ncols; col++)
- klabels[row][col] = -1;
- dists = G_malloc(sizeof(double **) * nrows);
- dists[row] = G_malloc(sizeof(double *) * ncols);
- for (col = 0; col < ncols; col++) {
- dists[row][col] = G_malloc(sizeof(double) * 2);
maxdistspec = maxdistspecprev = 0;
/* magic factor */
@@ -403,10 +439,11 @@
schange = 0;
+ dists[0] = 0;
+ dists[1] = 1E+9;
- dists[row][col][0] = 0;
- dists[row][col][1] = 1E+9;
+ Segment_put(&dist_seg, (void *)&dists, row, col);
@@ -420,13 +457,15 @@
dy = y - kseedsy[k];
for (x = x1; x <= x2; x++) {
- if (Rast_is_d_null_value(pdata[y][x]))
+ Segment_get(&bands_seg, (void *)pdata, y, x);
+ if (Rast_is_d_null_value(pdata))
continue;
+ Segment_get(&dist_seg, (void *)dists, y, x);
dist = 0.0;
- dist += (pdata[y][x][b] - kseedsb[k][b]) *
- (pdata[y][x][b] - kseedsb[k][b]);
+ dist += (pdata[b] - kseedsb[k][b]) *
+ (pdata[b] - kseedsb[k][b]);
dist /= nbands;
@@ -437,10 +476,12 @@
distsum = dist / maxdistspeck[k] + distxy * invwt;
/* dist = sqrt(dist) + sqrt(distxy*invwt); this is more exact */
- if (distsum < dists[y][x][1]) {
- dists[y][x][0] = dist;
- dists[y][x][1] = distsum;
- klabels[y][x] = k;
+ if (distsum < dists[1]) {
+ dists[0] = dist;
+ dists[1] = distsum;
+ Segment_put(&dist_seg, (void *)dists, y, x);
+ Segment_put(&k_seg, (void *)&k, y, x);
} /* for( x=x1 */
@@ -455,10 +496,11 @@
- k = klabels[row][col];
+ Segment_get(&k_seg, (void *)&k, row, col);
if (k >= 0) {
- if (maxdistspeck[k] < dists[row][col][0])
- maxdistspeck[k] = dists[row][col][0];
+ Segment_get(&dist_seg, (void *)dists, row, col);
+ if (maxdistspeck[k] < dists[0])
+ maxdistspeck[k] = dists[0];
@@ -468,10 +510,11 @@
maxdistspec = 0;
if (k >= 0) {
- if (maxdistspec < dists[row][col][0])
- maxdistspec = dists[row][col][0];
+ if (maxdistspec < dists[0])
+ maxdistspec = dists[0];
@@ -490,13 +533,15 @@
- if (klabels[row][col] >= 0) {
+ if (k >= 0) {
+ Segment_get(&bands_seg, (void *)pdata, row, col);
- sigmab[klabels[row][col]][b] += pdata[row][col][b];
+ sigmab[k][b] += pdata[b];
- sigmax[klabels[row][col]] += col;
- sigmay[klabels[row][col]] += row;
- clustersize[klabels[row][col]] += 1;
+ sigmax[k] += col;
+ sigmay[k] += row;
+ clustersize[k] += 1;
@@ -545,12 +590,6 @@
G_message(_("SLIC converged after %d iterations"), itr);
/* free */
- G_free(dists[row][col]);
- G_free(dists[row]);
- G_free(dists);
for (k = 0; k < numk; k++) {
G_free(kseedsb[k]);
@@ -564,40 +603,49 @@
G_free(sigmay);
G_free(clustersize);
- nlabels = G_malloc(sizeof(int *) * nrows);
- nlabels[row] = G_malloc(sizeof(int) * ncols);
- memset(nlabels[row], 0, sizeof(int) * ncols);
+ Segment_close(&dist_seg);
- numlabels = SLIC_EnforceLabelConnectivity(klabels, ncols, nrows,
- nlabels, 0);
+ if (Segment_open(&nk_seg, G_tempfile(), nrows, ncols, 64, 64,
+ numlabels = SLIC_EnforceLabelConnectivity(&k_seg, ncols, nrows,
+ &nk_seg, 0);
- klabels[row][col] = nlabels[row][col];
+ if (k >= 0) {
+ int n;
+ Segment_get(&nk_seg, (void *)&n, row, col);
+ Segment_put(&k_seg, (void *)&n, row, col);
- G_free(nlabels);
+ Segment_close(&nk_seg);
if (minsize > 1)
- numlabels = merge_small_clumps(pdata, nbands, klabels,
+ numlabels = merge_small_clumps(&bands_seg, nbands, &k_seg,
numlabels, 0, minsize);
+ Segment_close(&bands_seg);
outfd = Rast_open_new(outname, CELL_TYPE);
obuf = Rast_allocate_c_buf();
- if (klabels[row][col] < 0)
+ if (k < 0)
Rast_set_c_null_value(&obuf[col], 1);
else
- obuf[col] = klabels[row][col] + 1; /* +1 to avoid category value 0 */
+ obuf[col] = k + 1; /* +1 to avoid category value 0 */
Rast_put_row(outfd, obuf, CELL_TYPE);
Rast_close(outfd);
+ Segment_close(&k_seg);
/* history */
Rast_short_history(outname, "raster", &hist);
@@ -613,22 +661,23 @@
- int **nlabels, /*new labels */
+ SEGMENT *nk_seg, /*new labels */
int minsize)
const int dx4[4] = { -1, 0, 1, 0 };
const int dy4[4] = { 0, -1, 0, 1 };
- int n, label, adjlabel;
+ int n, label, adjlabel, k, k2, nk;
int row, col;
int x, y, c, count;
int *xvec, *yvec, vec_alloc;
+ nk = -1;
- nlabels[row][col] = -1;
+ Segment_put(nk_seg, (void *)&nk, row, col);
label = 0;
@@ -640,8 +689,10 @@
- if (labels[row][col] >= 0 && nlabels[row][col] < 0) {
- nlabels[row][col] = label;
+ Segment_get(k_seg, (void *)&k, row, col);
+ Segment_get(nk_seg, (void *)&nk, row, col);
+ if (k >= 0 && nk < 0) {
+ Segment_put(nk_seg, (void *)&label, row, col);
Start a new segment
@@ -657,8 +708,9 @@
x = xvec[0] + dx4[n];
y = yvec[0] + dy4[n];
if ((x >= 0 && x < ncols) && (y >= 0 && y < nrows)) {
- if (nlabels[y][x] >= 0)
- adjlabel = nlabels[y][x];
+ Segment_get(nk_seg, (void *)&nk, y, x);
+ if (nk >= 0)
+ adjlabel = nk;
@@ -670,8 +722,9 @@
- if (0 > nlabels[y][x] &&
- labels[row][col] == labels[y][x]) {
+ Segment_get(k_seg, (void *)&k2, y, x);
+ if (0 > nk && k == k2) {
if (vec_alloc <= count) {
vec_alloc += 100;
xvec =
@@ -683,7 +736,7 @@
xvec[count] = x;
yvec[count] = y;
- nlabels[y][x] = label;
+ Segment_put(nk_seg, (void *)&label, y, x);
count++;
@@ -696,7 +749,7 @@
if (count < minsize) {
for (c = 0; c < count; c++) {
- nlabels[yvec[c]][xvec[c]] = adjlabel;
+ Segment_put(nk_seg, (void *)&adjlabel, yvec[c], xvec[c]);
label--;
Modified: grass-addons/grass7/imagery/i.superpixels.slic/minsize.c
--- grass-addons/grass7/imagery/i.superpixels.slic/minsize.c 2017-01-30 20:34:57 UTC (rev 70459)
+++ grass-addons/grass7/imagery/i.superpixels.slic/minsize.c 2017-01-30 22:13:45 UTC (rev 70460)
@@ -1,5 +1,6 @@
#include "pavl.h"
#include "rclist.h"
@@ -138,18 +139,20 @@
static int (*get_neighbors)(int row, int col, int nrows, int ncols,
int neighbors[8][2]);
-static int update_cid(int **klabels, int row, int col, int old_id, int new_id)
+static int update_cid(SEGMENT *k_seg, int row, int col, int old_id, int new_id)
int nrows, ncols, rown, coln, n;
+ int this_id;
int neighbors[8][2];
struct rc next;
struct rclist rilist;
- if (klabels[row][col] != old_id) {
+ Segment_get(k_seg, (void *)&this_id, row, col);
+ if (this_id != old_id) {
G_fatal_error(_("Wrong id %d for row %d, col %d"),
- klabels[row][col], row, col);
+ this_id, row, col);
- klabels[row][col] = new_id;
+ Segment_put(k_seg, (void *)&new_id, row, col);
nrows = Rast_window_rows();
ncols = Rast_window_cols();
@@ -166,8 +169,9 @@
rown = neighbors[n][0];
coln = neighbors[n][1];
- if (klabels[rown][coln] == old_id) {
- klabels[rown][coln] = new_id;
+ Segment_get(k_seg, (void *)&this_id, rown, coln);
+ if (this_id == old_id) {
+ Segment_put(k_seg, (void *)&new_id, rown, coln);
rclist_add(&rilist, rown, coln);
@@ -180,7 +184,7 @@
static int find_best_neighbour(DCELL **clumpbsum, int nbands, int *clumpsize,
- int **klabels, int row, int col,
+ SEGMENT *k_seg, int row, int col,
int this_id, int *best_id)
int rown, coln, n, count, b;
@@ -222,7 +226,9 @@
- if (klabels[rown][coln] < 0)
+ /* get neighbor ID */
+ Segment_get(k_seg, (void *)&ngbr_id, rown, coln);
+ if (ngbr_id < 0)
continue;
ngbr_rc.row = rown;
@@ -236,8 +242,6 @@
if (pavl_insert(visited, pngbr_rc) == NULL) {
pngbr_rc = NULL;
- /* get neighbor ID */
- ngbr_id = klabels[rown][coln];
/* same neighbour */
if (ngbr_id == this_id) {
count++;
@@ -285,8 +289,8 @@
return (*best_id >= 0);
int row, col, nrows, ncols, i, b;
@@ -295,6 +299,7 @@
int reg_size;
int *clumpsize, n_clumps_new;
DCELL **clumpbsum;
+ DCELL *pdata;
/* merge with best (most similar) neighbour */
@@ -324,17 +329,19 @@
clumpbsum[i][b] = 0;
G_message(_("Merging clumps smaller than %d cells..."), minsize);
/* get clump sizes and band sums */
- this_id = klabels[row][col];
if (this_id >= 0) {
clumpsize[this_id]++;
+ Segment_get(bands_seg, (void *)pdata, row, col);
- clumpbsum[this_id][b] += pdata[row][col][b];
+ clumpbsum[this_id][b] += pdata[b];
@@ -347,7 +354,7 @@
/* get clump id */
if (this_id < 0)
continue;
@@ -357,12 +364,12 @@
while (reg_size < minsize && best_id >= 0) {
best_id = -1;
- find_best_neighbour(clumpbsum, nbands, clumpsize, klabels,
+ find_best_neighbour(clumpbsum, nbands, clumpsize, k_seg,
row, col, this_id, &best_id);
if (best_id >= 0) {
/* update cid */
- update_cid(klabels, row, col, this_id, best_id);
+ update_cid(k_seg, row, col, this_id, best_id);
/* mark as merged */
clumpbsum[best_id][b] += clumpbsum[this_id][b];
@@ -391,9 +398,11 @@
- if (this_id >= 0)
- klabels[row][col] = clumpsize[this_id];
+ if (this_id >= 0) {
+ this_id = clumpsize[this_id];
+ Segment_put(k_seg, (void *)&this_id, row, col);
G_percent(1, 1, 1);
