[GRASS-SVN] r70461 - in grass/trunk/gui/wxpython: core lmgr
svn_grass at osgeo.org
Mon Jan 30 15:46:38 PST 2017
Author: wenzeslaus
Date: 2017-01-30 15:46:38 -0800 (Mon, 30 Jan 2017)
New Revision: 70461
grass/trunk/gui/wxpython/core/menutree.py
grass/trunk/gui/wxpython/core/toolboxes.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/lmgr/menudata.py
wxGUI/toolboxes: store warning/error messages for later (see #3253)
GError and other message boxes during startup prevent
its completion unless OK is clicked quickly.
Messages are now stored and retrived later by the menu builder object.
lmgr stores them again and then shows them at the end of
init when everything is ready.
Messages (which are non-critical errors or warnings) are written as errors
to the Console output window. Console may flash during startup
but then Layers tab is shown anyway which seems like okay behavior
(careful user sees something happen but can ignore it).
Details of the exception are included into the message.
Modified: grass/trunk/gui/wxpython/core/menutree.py
--- grass/trunk/gui/wxpython/core/menutree.py 2017-01-30 22:13:45 UTC (rev 70460)
+++ grass/trunk/gui/wxpython/core/menutree.py 2017-01-30 23:46:38 UTC (rev 70461)
@@ -46,6 +46,9 @@
from core.treemodel import TreeModel, ModuleNode
from core.settings import UserSettings
from core.toolboxes import expandAddons as expAddons
+from core.toolboxes import getMessages as getToolboxMessages
+from core.toolboxes import clearMessages as clearToolboxMessages
+from core.gcmd import GError
from core.utils import _
if not os.getenv("GISBASE"):
@@ -56,7 +59,9 @@
class MenuTreeModelBuilder:
"""Abstract menu data class"""
- def __init__(self, filename, expandAddons=True):
+ # TODO: message_handler=GError is just for backwards compatibility
+ # message_handler=GError should be replaced by None
+ def __init__(self, filename, expandAddons=True, message_handler=GError):
self.menustyle = UserSettings.Get(group='appearance',
key='menustyle',
@@ -65,6 +70,9 @@
xmlTree = etree.parse(filename)
if expandAddons:
expAddons(xmlTree)
+ for message in getToolboxMessages():
+ message_handler(message)
+ clearToolboxMessages()
self.model = TreeModel(ModuleNode)
self._createModel(xmlTree)
Modified: grass/trunk/gui/wxpython/core/toolboxes.py
--- grass/trunk/gui/wxpython/core/toolboxes.py 2017-01-30 22:13:45 UTC (rev 70460)
+++ grass/trunk/gui/wxpython/core/toolboxes.py 2017-01-30 23:46:38 UTC (rev 70461)
@@ -100,15 +100,23 @@
# attribute translate of function _
_.translate = None
+# TODO: this should be part of some reader object
+_MESSAGES = []
def _warning(message):
"""Show warning"""
- # TODO: enable choice between GUI and script behavior
- # import only when really needed
- from core.gcmd import GError
- GError(message)
+ _MESSAGES.append("WARNING: %s" % message)
+def getMessages():
+ return _MESSAGES
+def clearMessages():
+ del _MESSAGES[:]
def _debug(level, message):
"""Show debug message"""
# this has interface as originally used GUI Debug but uses grass.script
@@ -505,9 +513,10 @@
def _getAddons():
try:
output = gcore.read_command('g.extension', quiet=True, flags='ag')
- except CalledModuleError:
+ except CalledModuleError as error:
_warning(_("List of addons cannot be obtained"
- " because g.extension failed."))
+ " because g.extension failed."
+ " Details: %s") % error)
return []
flist = []
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2017-01-30 22:13:45 UTC (rev 70460)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2017-01-30 23:46:38 UTC (rev 70461)
@@ -113,10 +113,21 @@
self._giface = LayerManagerGrassInterface(self)
+ menu_errors = []
+ def add_menu_error(message):
+ menu_errors.append(message)
+ def show_menu_errors(messages):
+ if messages:
+ self._gconsole.WriteError(
+ _("There were some issues when loading menu"
+ " or Modules tab:"))
+ for message in messages:
+ self._gconsole.WriteError(message)
# the main menu bar
- self._menuTreeBuilder = LayerManagerMenuData()
+ self._menuTreeBuilder = LayerManagerMenuData(message_handler=add_menu_error)
# the search tree and command console
- self._moduleTreeBuilder = LayerManagerModuleTree()
+ self._moduleTreeBuilder = LayerManagerModuleTree(message_handler=add_menu_error)
self._auimgr = wx.aui.AuiManager(self)
# list of open dialogs
@@ -236,6 +247,8 @@
self.workspaceChanged = False
+ show_menu_errors(menu_errors)
# start with layer manager on top
if self.currentPage:
self.GetMapDisplay().Raise()
Modified: grass/trunk/gui/wxpython/lmgr/menudata.py
--- grass/trunk/gui/wxpython/lmgr/menudata.py 2017-01-30 22:13:45 UTC (rev 70460)
+++ grass/trunk/gui/wxpython/lmgr/menudata.py 2017-01-30 23:46:38 UTC (rev 70461)
@@ -18,7 +18,7 @@
import os
from core.menutree import MenuTreeModelBuilder
-from core.toolboxes import getMenudataFile
+from core.toolboxes import getMenudataFile, getMessages, clearMessages
from core.globalvar import WXGUIDIR
@@ -26,7 +26,7 @@
class LayerManagerMenuData(MenuTreeModelBuilder):
- def __init__(self, filename=None):
+ def __init__(self, filename=None, message_handler=GError):
if filename:
expandAddons = False
else:
@@ -39,17 +39,19 @@
fallback=fallback)
try:
MenuTreeModelBuilder.__init__(
- self, filename, expandAddons=expandAddons)
+ self, filename, expandAddons=expandAddons,
+ message_handler=message_handler)
except (ValueError, AttributeError, TypeError):
- GError(_("Unable to parse user toolboxes XML files. "
- "Default main menu will be loaded."))
+ message_handler(_("Unable to parse user toolboxes XML files. "
+ "Default main menu will be loaded."))
fallback = os.path.join(WXGUIDIR, 'xml', 'menudata.xml')
- MenuTreeModelBuilder.__init__(self, fallback)
+ MenuTreeModelBuilder.__init__(
+ self, fallback, message_handler=message_handler)
class LayerManagerModuleTree(MenuTreeModelBuilder):
if filename:
else:
@@ -63,8 +65,10 @@
# TODO: try-except useless?
try:
- "Default module tree will be loaded."))
+ error_handler(_("Unable to parse user toolboxes XML files. "
+ "Default module tree will be loaded."))
