[GRASS-SVN] r70462 - grass/trunk/scripts/d.polar
svn_grass at osgeo.org
Mon Jan 30 18:55:25 PST 2017
Author: wenzeslaus
Date: 2017-01-30 18:55:25 -0800 (Mon, 30 Jan 2017)
New Revision: 70462
grass/trunk/scripts/d.polar/d.polar.py
d.polar: fail fast if map does not exist
Modified: grass/trunk/scripts/d.polar/d.polar.py
--- grass/trunk/scripts/d.polar/d.polar.py 2017-01-30 23:46:38 UTC (rev 70461)
+++ grass/trunk/scripts/d.polar/d.polar.py 2017-01-31 02:55:25 UTC (rev 70462)
@@ -53,6 +53,11 @@
from grass.script import core as gcore
+def raster_map_required(name):
+ if not gcore.find_file(name, 'cell')['file']:
+ gcore.fatal(_("Raster map <%s> not found") % name)
def cleanup():
try_remove(tmp)
for f in glob.glob(tmp + '_*'):
@@ -418,6 +423,8 @@
gcore.fatal(
_("xgraph required, please install first (www.xgraph.org)"))
+ raster_map_required(map)
# this file contains everything:
rawfile = tmp + "_raw"
