[GRASS-SVN] r71308 - grass/trunk/gui/wxpython
svn_grass at osgeo.org
Sat Jul 22 12:35:06 PDT 2017
Author: wenzeslaus
Date: 2017-07-22 12:35:06 -0700 (Sat, 22 Jul 2017)
New Revision: 71308
grass/trunk/gui/wxpython/gis_set.py
wxGUI/startup: instead of just complaining about no grassdata, try to find it
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2017-07-22 17:54:36 UTC (rev 71307)
+++ grass/trunk/gui/wxpython/gis_set.py 2017-07-22 19:35:06 UTC (rev 71308)
@@ -521,6 +521,57 @@
else:
return None
+ def SuggestDatabase(self):
+ """Suggest (set) possible GRASS Database value"""
+ # only if nothing is set (<UNKNOWN> comes from init script)
+ if self.GetRCValue("LOCATION_NAME") != "<UNKNOWN>":
+ return
+ home = os.path.expanduser('~')
+ # try some common directories for grassdata
+ # always assuming grassdata (lowercase)
+ # home for Linux
+ # Documents and My Documents for Windows
+ # potential translations (old Windows and some Linux)
+ # but ~ and ~/Documents should cover most of the cases
+ candidates = [
+ os.path.join(home, "grassdata"),
+ os.path.join(home, "Documents", "grassdata"),
+ os.path.join(home, "My Documents", "grassdata"),
+ try:
+ # here goes everything which has potential unicode issues
+ candidates.append(os.path.join(home, _("Documents"), "grassdata"))
+ candidates.append(os.path.join(home, _("My Documents"), "grassdata"))
+ except UnicodeDecodeError:
+ # just ignore the errors if it doesn't work
+ pass
+ path = None
+ for candidate in candidates:
+ if os.path.exists(candidate):
+ path = candidate
+ if path:
+ try:
+ self.tgisdbase.SetValue(path)
+ # restore previous state
+ # wizard gives error in this case, we just ignore
+ path = None
+ self.tgisdbase.SetValue(self.gisdbase)
+ # if we still have path
+ if path:
+ self.gisdbase = path
+ self.OnSetDatabase(None)
+ else:
+ # nothing found
+ # TODO: should it be warning, hint or message?
+ self._showWarning(_(
+ 'GRASS needs a directory (GRASS database) '
+ 'in which to store its data. '
+ 'Create one now if you have not already done so. '
+ 'A popular choice is "grassdata", located in '
+ 'your home directory. '
+ 'Press Browse button to select the directory.'))
def OnWizard(self, event):
"""Location wizard started"""
from location_wizard.wizard import LocationWizard
@@ -1160,21 +1211,8 @@
StartUp.CenterOnScreen()
self.SetTopWindow(StartUp)
StartUp.Show()
+ StartUp.SuggestDatabase()
- if StartUp.GetRCValue("LOCATION_NAME") == "<UNKNOWN>":
- # TODO: This is not ideal, either it should be checked elsewhere
- # where other checks are performed or it should use some public
- # API. There is no reason for not exposing it.
- # TODO: another question is what should be warning, hint or message
- StartUp._showWarning(
- _(
- 'GRASS needs a directory (GRASS database) '
- 'in which to store its data. '
- 'Create one now if you have not already done so. '
- 'A popular choice is "grassdata", located in '
- 'your home directory. '
- 'Press Browse button to select the directory.'))
return 1
if __name__ == "__main__":
