[GRASS-SVN] r71309 - in grass/trunk: gui/wxpython/core gui/wxpython/datacatalog lib/python/script
svn_grass at osgeo.org
Sat Jul 22 19:21:32 PDT 2017
Author: annakrat
Date: 2017-07-22 19:21:32 -0700 (Sat, 22 Jul 2017)
New Revision: 71309
grass/trunk/gui/wxpython/core/giface.py
grass/trunk/gui/wxpython/datacatalog/dialogs.py
grass/trunk/gui/wxpython/datacatalog/tree.py
grass/trunk/lib/python/script/core.py
wxGUI/catalog: implement moving maps between mapsets and locations including reprojection
Modified: grass/trunk/gui/wxpython/core/giface.py
--- grass/trunk/gui/wxpython/core/giface.py 2017-07-22 19:35:06 UTC (rev 71308)
+++ grass/trunk/gui/wxpython/core/giface.py 2017-07-23 02:21:32 UTC (rev 71309)
@@ -247,7 +247,7 @@
event.Skip()
def RunCmd(self, command, compReg=True, env=None, skipInterface=False,
- onDone=None, onPrepare=None, userData=None,
+ onDone=None, onPrepare=None, userData=None, addLayer=None,
notification=Notification.MAKE_VISIBLE):
self._gconsole.RunCmd(
command=command,
@@ -257,6 +257,7 @@
onDone=onDone,
onPrepare=onPrepare,
userData=userData,
+ addLayer=addLayer,
notification=notification)
def Help(self, entry):
Modified: grass/trunk/gui/wxpython/datacatalog/dialogs.py
--- grass/trunk/gui/wxpython/datacatalog/dialogs.py 2017-07-22 19:35:06 UTC (rev 71308)
+++ grass/trunk/gui/wxpython/datacatalog/dialogs.py 2017-07-23 02:21:32 UTC (rev 71309)
@@ -7,7 +7,7 @@
Classes:
- dialogs::CatalogReprojectionDialog
-(C) 2016 by the GRASS Development Team
+(C) 2017 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -17,63 +17,66 @@
import wx
-import grass.script as gscript
-from grass.script import task as gtask
-from gui_core.forms import CmdPanel
+from gui_core.widgets import FloatValidator, IntegerValidator
from core.giface import Notification
+from core.gcmd import RunCommand
+from grass.script import parse_key_val, region_env
class CatalogReprojectionDialog(wx.Dialog):
- def __init__(self, parent, giface, inputGisdbase, inputLocation, inputMapset, inputLayer,
- outputGisdbase, outputLocation, outputMapset, etype,
+ def __init__(self, parent, giface, inputGisdbase, inputLocation,
+ inputMapset, inputLayer, inputEnv,
+ outputGisdbase, outputLocation, outputMapset, outputLayer,
+ etype, outputEnv, callback,
id=wx.ID_ANY, title=_("Reprojection"),
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
- self.parent = parent # GMFrame
- self._giface = giface # used to add layers
+ self.parent = parent
+ self._giface = giface
wx.Dialog.__init__(self, parent, id, title, style=style,
name="ReprojectionDialog")
- self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
+ self.panel = wx.Panel(parent=self)
self.iGisdbase = inputGisdbase
self.iLocation = inputLocation
self.iMapset = inputMapset
self.iLayer = inputLayer
+ self.iEnv = inputEnv
self.oGisdbase = outputGisdbase
self.oLocation = outputLocation
self.oMapset = outputMapset
+ self.oLayer = outputLayer
self.etype = etype
+ self.oEnv = outputEnv
+ self.callback = callback
- self._blackList = {
- 'enabled': True,
- 'items': {
- 'r.proj': {
- 'params': ['location', 'mapset', 'input', 'dbase'],
- 'flags': ['l']},
- 'v.proj': {
- 'flags': ['l']}}}
+ self._widgets()
+ self._doLayout()
if self.etype == 'raster':
- grass_task = gtask.parse_interface('r.proj', blackList=self._blackList)
- elif self.etype == 'vector':
- grass_task = gtask.parse_interface('v.proj', blackList=self._blackList)
+ self._estimateResampling()
+ self._estimateResolution()
- self.settingsPanel = CmdPanel(parent=self, giface=self._giface, task=grass_task, frame=None)
- self.closeOnFinished = wx.CheckBox(self.panel, label=_("Close dialog on finish"))
+ def _widgets(self):
+ if self.etype == 'raster':
+ self.resolution = wx.TextCtrl(self.panel, validator=FloatValidator())
+ self.resampling = wx.Choice(self.panel, size=(200, -1),
+ choices=['nearest', 'bilinear', 'bicubic', 'lanczos',
+ 'bilinear_f', 'bicubic_f', 'lanczos_f'])
+ else:
+ self.vsplit = wx.TextCtrl(self.panel, validator=IntegerValidator())
+ self.vsplit.SetValue('10000')
# buttons
- # cancel
self.btn_close = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
- self.btn_close.Bind(wx.EVT_BUTTON, lambda evt: self.Close())
+ self.SetEscapeId(self.btn_close.GetId())
# run
- self.btn_run = wx.Button(
- parent=self.panel,
- id=wx.ID_OK,
- label=_("Reproject"))
+ self.btn_run = wx.Button(parent=self.panel, id=wx.ID_OK, label=_("Reproject"))
self.btn_run.SetToolTipString(_("Reproject raster"))
@@ -81,62 +84,98 @@
self.btn_run.SetDefault()
self.btn_run.Bind(wx.EVT_BUTTON, self.OnReproject)
- self.doLayout()
- def doLayout(self):
+ def _doLayout(self):
"""Do layout"""
dialogSizer = wx.BoxSizer(wx.VERTICAL)
+ optionsSizer = wx.GridBagSizer(5, 5)
- dialogSizer.Add(wx.StaticText(self.panel, label=_("The copied layer needs to be reprojected:")),
- flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, border=5)
- dialogSizer.Add(self.settingsPanel, proportion=1,
- flag=wx.ALL | wx.EXPAND, border=5)
- dialogSizer.Add(self.closeOnFinished, flag=wx.ALL | wx.EXPAND, border=5)
+ label = _("Map layer <{ml}> needs to be reprojected.\n"
+ "Please review and modify reprojection parameters:").format(ml=self.iLayer)
+ dialogSizer.Add(wx.StaticText(self.panel, label=label),
+ flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, border=10)
+ optionsSizer.Add(wx.StaticText(self.panel, label=_("Estimated resolution:")),
+ pos=(0, 0), flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+ optionsSizer.Add(self.resolution, pos=(0, 1), flag=wx.EXPAND)
+ optionsSizer.Add(wx.StaticText(self.panel, label=_("Resampling method:")),
+ pos=(1, 0), flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+ optionsSizer.Add(self.resampling, pos=(1, 1), flag=wx.EXPAND)
+ else:
+ optionsSizer.Add(wx.StaticText(self.panel, label=_("Maximum segment length:")),
+ optionsSizer.Add(self.vsplit, pos=(1, 1), flag=wx.EXPAND)
+ optionsSizer.AddGrowableCol(1)
+ dialogSizer.Add(optionsSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=10)
+ helptext = wx.StaticText(self.panel,
+ label="For more reprojection options,"
+ " please see {module}".format(module='r.proj' if self.etype == 'raster'
+ else 'v.proj'))
+ dialogSizer.Add(helptext, proportion=0, flag=wx.ALL | wx.EXPAND, border=10)
# buttons
- btnsizer = wx.BoxSizer(orient=wx.HORIZONTAL)
+ btnStdSizer = wx.StdDialogButtonSizer()
+ btnStdSizer.AddButton(self.btn_run)
+ btnStdSizer.AddButton(self.btn_close)
+ btnStdSizer.Realize()
+ dialogSizer.Add(btnStdSizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=5)
- btnsizer.Add(self.btn_close, proportion=0,
- flag=wx.LEFT | wx.RIGHT | wx.ALIGN_CENTER,
- border=10)
- btnsizer.Add(self.btn_run, proportion=0,
- flag=wx.RIGHT | wx.ALIGN_CENTER,
- border=10)
- dialogSizer.Add(
- btnsizer,
- proportion=0,
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT,
- border=5)
self.panel.SetSizer(dialogSizer)
dialogSizer.Fit(self.panel)
self.Layout()
- # sizing not working properly
- self.SetMinSize(self.GetBestSize())
+ self.SetSize(self.GetBestSize())
- def getSettingsPageCmd(self):
- return self.settingsPanel.createCmd(
- ignoreErrors=True, ignoreRequired=True)
+ def _estimateResolution(self):
+ output = RunCommand('r.proj', flags='g', quiet=False, read=True, input=self.iLayer,
+ dbase=self.iGisdbase, location=self.iLocation, mapset=self.iMapset,
+ env=self.oEnv).strip()
+ params = parse_key_val(output, vsep=' ')
+ output = RunCommand('g.region', flags='ug', quiet=False, read=True, env=self.oEnv,
+ parse=lambda x: parse_key_val(x, val_type=float), **params)
+ cell_ns = (output['n'] - output['s']) / output['rows']
+ cell_ew = (output['e'] - output['w']) / output['cols']
+ estimate = (cell_ew + cell_ns) / 2.
+ self.resolution.SetValue(str(estimate))
+ self.params = params
+ def _estimateResampling(self):
+ output = RunCommand('r.info', flags='g', quiet=False, read=True, map=self.iLayer,
+ env=self.iEnv, parse=parse_key_val)
+ if output['datatype'] == 'CELL':
+ self.resampling.SetStringSelection('nearest')
+ else:
+ self.resampling.SetStringSelection('bilinear')
def OnReproject(self, event):
- cmd = self.getSettingsPageCmd()
- cmd.append('dbase=' + self.iGisdbase)
- cmd.append('location=' + self.iLocation)
- cmd.append('mapset=' + self.iMapset)
- cmd.append('input=' + self.iLayer)
+ cmd = []
+ cmd.append('r.proj')
+ cmd.append('dbase=' + self.iGisdbase)
+ cmd.append('location=' + self.iLocation)
+ cmd.append('mapset=' + self.iMapset)
+ cmd.append('input=' + self.iLayer)
+ cmd.append('output=' + self.oLayer)
+ cmd.append('method=' + self.resampling.GetStringSelection())
- self.tmpfile, env = gscript.create_environment(self.oGisdbase, self.oLocation, self.oMapset)
+ self.oEnv['GRASS_REGION'] = region_env(n=self.params['n'], s=self.params['s'],
+ e=self.params['e'], w=self.params['w'],
+ flags='a', res=float(self.resolution.GetValue()),
+ env=self.oEnv)
+ else:
+ cmd.append('v.proj')
+ cmd.append('smax=' + self.vsplit.GetValue())
- self._giface.RunCmd(cmd, env=env,
- onDone=self.OnDone, userData=None,
- notification=Notification.MAKE_VISIBLE)
+ self._giface.RunCmd(cmd, env=self.oEnv, compReg=False, addLayer=False,
+ onDone=self._onDone, userData=None,
+ notification=Notification.MAKE_VISIBLE)
- def OnDone(self, event):
- gscript.try_remove(self.tmpfile)
- if self.closeOnFinished.IsChecked() and event.returncode == 0:
- self.Close()
+ event.Skip()
+ def _onDone(self, event):
+ self.callback()
Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
--- grass/trunk/gui/wxpython/datacatalog/tree.py 2017-07-22 19:35:06 UTC (rev 71308)
+++ grass/trunk/gui/wxpython/datacatalog/tree.py 2017-07-23 02:21:32 UTC (rev 71309)
@@ -541,6 +541,7 @@
def _initVariablesCatalog(self):
"""Init variables."""
+ self.copy_mode = False
self.copy_layer = None
self.copy_type = None
self.copy_mapset = None
@@ -559,18 +560,24 @@
"""Add locations, mapsets and layers to the tree."""
self._initTreeItems()
+ def OnMoveMap(self, event):
+ """Move layer or mapset (just save it temporarily, copying is done by paste)"""
+ self.copy_layer = self.selected_layer
+ self.copy_type = self.selected_type
+ self.copy_mapset = self.selected_mapset
+ self.copy_location = self.selected_location
+ label = _("Map <{layer}> marked for moving.").format(layer=self.copy_layer)
+ self.showNotification.emit(message=label)
def OnCopyMap(self, event):
"""Copy layer or mapset (just save it temporarily, copying is done by paste)"""
+ self.copy_mode = True
- label = _(
- "Map <{layer}> marked for copying. "
- "You can paste it to the current mapset "
- "<{mapset}>.".format(
- layer=self.copy_layer.label,
- mapset=gisenv()['MAPSET']))
+ label = _("Map <{layer}> marked for copying.").format(layer=self.copy_layer)
def OnRenameMap(self, event):
@@ -631,98 +638,115 @@
gscript.try_remove(gisrc)
def OnPasteMap(self, event):
- """Paste layer"""
# copying between mapsets of one location
if not self.copy_layer:
- GMessage(_("No map selected for copying."), parent=self)
+ if self.copy_mode:
+ GMessage(_("No map selected for copying."), parent=self)
+ else:
+ GMessage(_("No map selected for moving."), parent=self)
return
+ gisrc, env = gscript.create_environment(
+ gisenv()['GISDBASE'], self.selected_location.label, mapset=self.selected_mapset.label)
+ gisrc2, env2 = gscript.create_environment(
+ gisenv()['GISDBASE'], self.copy_location.label, mapset=self.copy_mapset.label)
+ new_name = self.copy_layer.label
if self.selected_location == self.copy_location:
- gisrc, env = gscript.create_environment(
- gisenv()['GISDBASE'], self.selected_location.label, mapset=self.selected_mapset.label)
- new_name = self._getNewMapName(
- _('New name'),
- _('Copy map'),
- self.copy_layer.label,
- env=env,
- mapset=self.selected_mapset.label,
- element=self.copy_type.label)
- if not new_name:
- return
- if map_exists(
- new_name, element=self.copy_type.label, env=env,
- mapset=self.selected_mapset.label):
- GMessage(
- _("Failed to copy map: new map has the same name"),
- parent=self)
- return
+ # within one mapset
+ if self.selected_mapset == self.copy_mapset:
+ # ignore when just moves map
+ if self.copy_mode is False:
+ return
+ new_name = self._getNewMapName(_('New name'), _('Select new name'),
+ self.copy_layer.label, env=env,
+ mapset=self.selected_mapset.label,
+ element=self.copy_type.label)
+ if not new_name:
+ return
+ # within one location, different mapsets
+ else:
+ if map_exists(new_name, element=self.copy_type.label, env=env,
+ mapset=self.selected_mapset.label):
+ if not new_name:
+ return
- if not self.selected_type:
- found = self._model.SearchNodes(
- parent=self.selected_mapset, type='element',
- name=self.copy_type.label)
- self.selected_type = found[0] if found else None
- overwrite = False
- if self.selected_type:
- parent=self.selected_type,
- type=self.copy_type.label,
- name=new_name)
- if found and found[0]:
- dlg = wx.MessageDialog(
- parent=self,
- message=_(
- "Map <{map}> already exists "
- "in the current mapset. "
- "Do you want to overwrite it?").format(
- map=new_name),
- caption=_("Overwrite?"),
- style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
- ret = dlg.ShowModal()
- dlg.Destroy()
- if ret == wx.ID_YES:
- overwrite = True
string = self.copy_layer.label + '@' + self.copy_mapset.label + ',' + new_name
pasted = 0
- label = _("Copying <{name}>...").format(name=string)
+ label = _("Copying <{name}>...").format(name=string)
+ else:
+ label = _("Moving <{name}>...").format(name=string)
if self.copy_type.label == 'vector':
- pasted, cmd = self._runCommand(
- 'g.copy', vector=string, overwrite=overwrite, env=env)
+ pasted, cmd = self._runCommand('g.copy', vector=string, env=env)
node = 'vector'
elif self.copy_type.label == 'raster':
- 'g.copy', raster=string, overwrite=overwrite, env=env)
+ pasted, cmd = self._runCommand('g.copy', raster=string, env=env)
node = 'raster'
else:
- 'g.copy', raster_3d=string, overwrite=overwrite, env=env)
+ pasted, cmd = self._runCommand('g.copy', raster_3d=string, env=env)
node = 'raster_3d'
if pasted == 0:
- self.InsertLayer(
- name=new_name,
- mapset_node=self.selected_mapset,
- element_name=node)
+ self.InsertLayer(name=new_name, mapset_node=self.selected_mapset,
+ element_name=node)
Debug.msg(1, "COPIED TO: " + new_name)
- self.showNotification.emit(
- message=_("g.copy completed").format(cmd=cmd))
+ self.showNotification.emit(message=_("g.copy completed").format(cmd=cmd))
+ else:
+ # remove old
+ if not self.copy_mode:
+ self._removeMapAfterCopy(env2)
+ gscript.try_remove(gisrc2)
+ # expand selected mapset
+ self.ExpandNode(self.selected_mapset, recursive=True)
+ self._initVariablesCatalog()
else:
if self.copy_type.label == 'raster_3d':
- GError(_("Reprojection is not implemented for 3D rasters"), parent=self)
- return
+ GError(_("Reprojection is not implemented for 3D rasters"), parent=self)
+ return
+ if not new_name:
+ return
gisdbase = gisenv()['GISDBASE']
+ callback = lambda: self._onDoneReprojection(iEnv=env2, iGisrc=gisrc2, oGisrc=gisrc)
dlg = CatalogReprojectionDialog(self, self._giface, gisdbase, self.copy_location.label,
- self.copy_mapset.label, self.copy_layer.label,
+ self.copy_mapset.label, self.copy_layer.label, env2,
gisdbase, self.selected_location.label, self.selected_mapset.label,
- etype=self.copy_type.label)
- dlg.Show()
+ new_name, self.copy_type.label, env, callback)
+ dlg.ShowModal()
- # expand selected mapset
+ def _onDoneReprojection(self, iEnv, iGisrc, oGisrc):
+ self.InsertLayer(name=self.copy_layer.label, mapset_node=self.selected_mapset,
+ element_name=self.copy_type.label)
+ self._removeMapAfterCopy(iEnv)
+ gscript.try_remove(iGisrc)
+ gscript.try_remove(oGisrc)
+ def _removeMapAfterCopy(self, env):
+ removed, cmd = self._runCommand('g.remove', type=self.copy_type.label,
+ name=self.copy_layer.label, flags='f', env=env)
+ if removed == 0:
+ self._model.RemoveNode(self.copy_layer)
+ self.RefreshNode(self.copy_type, recursive=True)
+ Debug.msg(1, "LAYER " + self.copy_layer.label + " DELETED")
+ self.showNotification.emit(message=_("g.remove completed").format(cmd=cmd))
def InsertLayer(self, name, mapset_node, element_name):
"""Insert layer into model and refresh tree"""
found_element = self._model.SearchNodes(
@@ -813,27 +837,19 @@
def OnEndDrag(self, node, event):
"""Copy layer into target"""
- if not wx.GetMouseState().ControlDown():
- GMessage(_("Moving maps not implemented"), parent=self)
- event.Veto()
- return
+ self.copy_mode = wx.GetMouseState().ControlDown()
if node:
self.DefineItems(node)
- if self._restricted and gisenv(
- )['MAPSET'] != self.selected_mapset.label:
- GMessage(
- _("Maps can be copied only to current mapset"),
- parent=self)
+ if self._restricted and gisenv()['MAPSET'] != self.selected_mapset.label:
+ GMessage(_("To move or copy maps to other mapsets, unlock editing of other mapsets"),
+ parent=self)
event.Veto()
return
- if self.selected_location == self.copy_location and self.selected_mapset:
- event.Allow()
- self.OnPasteMap(event)
- Debug.msg(1, "DROP DONE")
- else:
- event.Veto()
+ event.Allow()
+ Debug.msg(1, "DROP DONE")
+ self.OnPasteMap(event)
def OnSwitchLocationMapset(self, event):
genv = gisenv()
if self.selected_location.label == genv['LOCATION_NAME']:
@@ -929,6 +945,12 @@
genv = gisenv()
currentLocation, currentMapset = self._isCurrent(genv)
+ item = wx.MenuItem(menu, wx.NewId(), _("&Cut"))
+ menu.AppendItem(item)
+ self.Bind(wx.EVT_MENU, self.OnMoveMap, item)
+ if not currentMapset:
+ item.Enable(False)
item = wx.MenuItem(menu, wx.NewId(), _("&Copy"))
self.Bind(wx.EVT_MENU, self.OnCopyMap, item)
@@ -940,7 +962,7 @@
item = wx.MenuItem(menu, wx.NewId(), _("&Paste"))
self.Bind(wx.EVT_MENU, self.OnPasteMap, item)
- if not(currentLocation and self.copy_layer):
+ if not(currentMapset and self.copy_layer):
item.Enable(False)
item = wx.MenuItem(menu, wx.NewId(), _("&Delete"))
@@ -977,7 +999,7 @@
item.Enable(False)
item = wx.MenuItem(menu, wx.NewId(), _("&Switch mapset"))
@@ -997,7 +1019,7 @@
genv = gisenv()
item.Enable(False)
self.PopupMenu(menu)
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2017-07-22 19:35:06 UTC (rev 71308)
+++ grass/trunk/lib/python/script/core.py 2017-07-23 02:21:32 UTC (rev 71309)
@@ -999,7 +999,7 @@
# interface to g.gisenv
-def gisenv():
+def gisenv(env=None):
"""Returns the output from running g.gisenv (with no arguments), as a
dictionary. Example:
@@ -1007,9 +1007,10 @@
>>> print(env['GISDBASE']) # doctest: +SKIP
/opt/grass-data
+ :param env run with different environment
:return: list of GRASS variables
- s = read_command("g.gisenv", flags='n')
+ s = read_command("g.gisenv", flags='n', env=env)
return parse_key_val(s)
# interface to g.region
@@ -1029,12 +1030,13 @@
return False
-def region(region3d=False, complete=False):
+def region(region3d=False, complete=False, env=None):
"""Returns the output from running "g.region -gu", as a
:param bool region3d: True to get 3D region
:param bool complete:
+ :param env env
>>> curent_region = region()
>>> # obtain n, s, e and w values
@@ -1052,7 +1054,7 @@
if complete:
flgs += 'cep'
- s = read_command("g.region", flags=flgs)
+ s = read_command("g.region", flags=flgs, env=env)
reg = parse_key_val(s, val_type=float)
for k in ['projection', 'zone', 'rows', 'cols', 'cells',
'rows3', 'cols3', 'cells3', 'depths']:
@@ -1063,7 +1065,7 @@
return reg
-def region_env(region3d=False, **kwargs):
+def region_env(region3d=False, flags=None, env=None, **kwargs):
"""Returns region settings as a string which can used as
GRASS_REGION environmental variable.
@@ -1074,6 +1076,8 @@
temporary region used for raster-based computation.
+ :param string flags: for example 'a'
+ :param env: different environment than current
:param kwargs: g.region's parameters like 'raster', 'vector' or 'region'
@@ -1086,9 +1090,9 @@
:return: empty string on error
# read proj/zone from WIND file
- env = gisenv()
- windfile = os.path.join(env['GISDBASE'], env['LOCATION_NAME'],
- env['MAPSET'], "WIND")
+ gis_env = gisenv(env)
+ windfile = os.path.join(gis_env['GISDBASE'], gis_env['LOCATION_NAME'],
+ gis_env['MAPSET'], "WIND")
fd = open(windfile, "r")
grass_region = ''
for line in fd.readlines():
@@ -1109,8 +1113,10 @@
flgs = 'ug'
if region3d:
flgs += '3'
+ if flags:
+ flgs += flags
- s = read_command('g.region', flags=flgs, **kwargs)
+ s = read_command('g.region', flags=flgs, env=env, **kwargs)
if not s:
return ''
reg = parse_key_val(s)
