[GRASS-SVN] r71318 - grass/trunk
Sat Jul 29 09:04:18 PDT 2017
Author: wenzeslaus
Date: 2017-07-29 09:04:18 -0700 (Sat, 29 Jul 2017)
New Revision: 71318
Added:
   grass/trunk/Dockerfile
   grass/trunk/README
Dockerfile for the local source code with doc in README
Added: grass/trunk/Dockerfile
--- grass/trunk/Dockerfile	                        (rev 0)
+++ grass/trunk/Dockerfile	2017-07-29 16:04:18 UTC (rev 71318)
@@ -0,0 +1,86 @@
+FROM ubuntu:16.04
+MAINTAINER Vaclav Petras <wenzeslaus at gmail.com>
+# system environment
+ENV DEBIAN_FRONTEND noninteractive
+# GRASS GIS compile dependencies
+RUN apt-get update \
+    && apt-get install -y --install-recommends \
+        autoconf2.13 \
+        autotools-dev \
+        bison \
+        flex \
+        g++ \
+        gettext \
+        libblas-dev \
+        libbz2-dev \
+        libcairo2-dev \
+        libfftw3-dev \
+        libfreetype6-dev \
+        libgdal-dev \
+        libgeos-dev \
+        libglu1-mesa-dev \
+        libjpeg-dev \
+        liblapack-dev \
+        liblas-c-dev \
+        libncurses5-dev \
+        libnetcdf-dev \
+        libpng-dev \
+        libpq-dev \
+        libproj-dev \
+        libreadline-dev \
+        libsqlite3-dev \
+        libtiff-dev \
+        libxmu-dev \
+        make \
+        netcdf-bin \
+        proj-bin \
+        python \
+        python-dev \
+        python-numpy \
+        python-pil \
+        python-ply \
+        unixodbc-dev \
+        zlib1g-dev \
+    && apt-get autoremove \
+    && apt-get clean
+RUN mkdir /code
+RUN mkdir /code/grass
+# add repository files to the image
+COPY . /code/grass
+WORKDIR /code/grass
+# install GRASS GIS
+RUN ./configure \
+    --enable-largefile=yes \
+    --with-nls \
+    --with-cxx \
+    --with-readline \
+    --with-bzlib \
+    --with-pthread \
+    --with-proj-share=/usr/share/proj \
+    --with-geos=/usr/bin/geos-config \
+    --with-cairo \
+    --with-opengl-libs=/usr/include/GL \
+    --with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
+    --with-sqlite=yes \
+    --with-liblas=yes --with-liblas-config=/usr/bin/liblas-config \
+    && make && make install && ldconfig
+# enable simple grass command regardless of version number
+RUN ln -s /usr/local/bin/grass* /usr/local/bin/grass
+# create a user
+RUN useradd -m -U grass
+VOLUME ["/data"]
+# switch the user
+USER grass
+WORKDIR /data
Modified: grass/trunk/README
--- grass/trunk/README	2017-07-28 00:41:34 UTC (rev 71317)
+++ grass/trunk/README	2017-07-29 16:04:18 UTC (rev 71318)
@@ -50,3 +50,24 @@
 An online version is available at:
 http://grass.osgeo.org/programming7/
+## Docker
+Build using the downloaded source code (in the directory with the
+source code):
+    docker build -t grass .
+A test run (assuming you have existing GRASS GIS location)
+    docker run --rm -v /your/local/grassdata/:/data -it grass \
+        grass /data/nc_basic_spm/PERMANENT --exec g.region -p
+Note that the first `grass` is a name of the image while the second
+`grass` is the name of the executable.
+To run the tests (again assuming local location):
+    docker run --rm -v /your/test/grassdata/:/data -w /code/grass \
+        -it grass grass /data/nc_basic_spm/PERMANENT --exec \
+            python -m grass.gunittest.main \
+                --location nc_basic_spm --location-type nc
