[GRASS-SVN] r71319 - grass/trunk/raster/r.patch
svn_grass at osgeo.org
Sat Jul 29 21:15:08 PDT 2017
Author: wenzeslaus
Date: 2017-07-29 21:15:07 -0700 (Sat, 29 Jul 2017)
New Revision: 71319
Added:
grass/trunk/raster/r.patch/r_patch.png
grass/trunk/raster/r.patch/r_patch_zeros_as_nulls.png
grass/trunk/raster/r.patch/r.patch.html
r.patch: explanatory images and theoretical example, comparison to COALESCE
Modified: grass/trunk/raster/r.patch/r.patch.html
--- grass/trunk/raster/r.patch/r.patch.html 2017-07-29 16:04:18 UTC (rev 71318)
+++ grass/trunk/raster/r.patch/r.patch.html 2017-07-30 04:15:07 UTC (rev 71319)
@@ -8,12 +8,21 @@
with the data from the first input map.
Once this is done the remaining holes are filled in by the next input map,
and so on.
+<p>
This program
is useful for making a composite raster map layer from two or more adjacent
map layers, for filling in "holes" in a raster map layer's data (e.g., in
digital elevation data), or for updating an older map layer with more recent
data. The current geographic region definition and mask settings are
respected.
+<center>
+<img src="r_patch.png">
+<p><em>Figure: Result of patching two raster maps containing NULLs using
+the default settings</em></p>
+</center>
<p>The first <em>name</em> listed in the string
<b>input=</b><em>name</em>,<em>name</em>,<em>name</em>, ... is the name of
the first map whose data values will be used to fill in "no data" cells
@@ -21,6 +30,24 @@
maps will be used, in order, to supply data values for for the remaining
"no data" cells.
+<center>
+<img src="r_patch_zeros_as_nulls.png">
+<p><em>Figure: Result of patching two raster maps using the <b>-z</b> flag
+to treat zeros as NULLs</em></p>
+</center>
+<h3>Relation to SQL COALESCE() function</h3>
+The module is corresponds to the SQL COALESCE() function.
+This function takes two or more arguments and returns
+a copy of its first non-NULL argument. If all arguments are NULL,
+the function returns NULL.
+<p>
+The <em>r.patch</em> module iterates over all cells and for each cell
+of the output raster map uses the first corresponding non-NULL cell
+in the series of the input raster maps.
<h3>Example of filling areas</h3>
<!-- this example is also used in the tests -->
@@ -113,8 +140,25 @@
<em>r.patch</em>.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
+<h3>Example with three maps</h3>
+The input are three maps called roads, water and forest. Primarily,
+we want to use the values from roads, then from water and if no
+other values are available we want to use forest.
+First we set the computation region assuming that the all three maps
+fully overlap and have the same resolution (so we can safely use the
+just the one without further modifications of the region).
+Then we perform the patching.
+<div class="code"><pre>
+g.region raster=roads
+r.patch input=roads,water,forest output=result
+</pre></div>
+<h3>Example using Bash syntax</h3>
Create a list of maps matching a pattern, extend the region to include them
all, and patch them together to create a mosaic. Overlapping maps will be
used in the order listed.
@@ -124,7 +168,6 @@
g.region raster=$MAPS
r.patch in=$MAPS out=mosaic
</pre></div>
-<br>
<h2>SEE ALSO</h2>
Added: grass/trunk/raster/r.patch/r_patch.png
(Binary files differ)
Property changes on: grass/trunk/raster/r.patch/r_patch.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: grass/trunk/raster/r.patch/r_patch_zeros_as_nulls.png
Property changes on: grass/trunk/raster/r.patch/r_patch_zeros_as_nulls.png
