[GRASS-SVN] r71218 - in grass-addons/grass7/raster: . r.colors.contrastbrightness
svn_grass at osgeo.org
Mon Jun 26 00:08:39 PDT 2017
Author: ychemin
Date: 2017-06-26 00:08:39 -0700 (Mon, 26 Jun 2017)
New Revision: 71218
Added:
grass-addons/grass7/raster/r.colors.contrastbrightness/
grass-addons/grass7/raster/r.colors.contrastbrightness/Makefile
grass-addons/grass7/raster/r.colors.contrastbrightness/main.c
grass-addons/grass7/raster/r.colors.contrastbrightness/r.colors.contrastbrightness.html
grass-addons/grass7/raster/Makefile
added r.colors.contrastbrightness
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile 2017-06-25 23:18:17 UTC (rev 71217)
+++ grass-addons/grass7/raster/Makefile 2017-06-26 07:08:39 UTC (rev 71218)
@@ -22,6 +22,7 @@
r.bitpattern \
r.catchment \
r.category.trim \
+ r.colors.contrastbrightness \
r.colors.cubehelix \
r.colors.matplotlib \
r.colors.out_sld \
Added: grass-addons/grass7/raster/r.colors.contrastbrightness/Makefile
--- grass-addons/grass7/raster/r.colors.contrastbrightness/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.colors.contrastbrightness/Makefile 2017-06-26 07:08:39 UTC (rev 71218)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.colors.contrastbrightness
+LIBES = $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/raster/r.colors.contrastbrightness/main.c
--- grass-addons/grass7/raster/r.colors.contrastbrightness/main.c (rev 0)
+++ grass-addons/grass7/raster/r.colors.contrastbrightness/main.c 2017-06-26 07:08:39 UTC (rev 71218)
@@ -0,0 +1,235 @@
+ * MODULE: r.colors.contrast
+ * AUTHOR(S): Yann Chemin
+ * PURPOSE: Change the contrast of a band
+ * COPYRIGHT: (C) 2017 by the GRASS Development Team
+ * This program is free software under the GPL (>=v2)
+ * Read the file COPYING that comes with GRASS for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+ int nrows, ncols, row, col;
+ /* GRASS region properties */
+ struct Cell_head cellhd, region;
+ struct History hist;
+ /* GRASS module options */
+ struct GModule *module;
+ struct
+ struct Option
+ *input, *output,
+ *contrast, *f_offset, *min, *max;
+ } parm;
+ /* program settings */
+ char *input;
+ char *output;
+ double contrast = 1.0;
+ double brightness = 1.0;
+ double min = 0.0;
+ double max = 0.0;
+ /* file handlers */
+ int in_fd;
+ int out_fd;
+ CELL *inrastc, *outrastc;
+ FCELL *inrastf, *outrastf;
+ DCELL *inrastd, *outrastd;
+ DCELL pix = 0.0;
+ DCELL pixout = 0.0;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("raster"));
+ G_add_keyword(_("imagery"));
+ G_add_keyword(_("contrast"));
+ G_add_keyword(_("brightness"));
+ module->description =
+ _("Change the contrast/brightness of a raster.");
+ /* parameters */
+ parm.input = G_define_standard_option(G_OPT_R_INPUT);
+ parm.input->key = "input";
+ parm.input->required = YES;
+ parm.input->description = _("Raster map to change the contrast of.");
+ parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
+ parm.output->required = YES;
+ parm.output->key = "output";
+ parm.min = G_define_option();
+ parm.min->key = "minimum";
+ parm.min->key_desc = "value";
+ parm.min->required = YES;
+ parm.min->type = TYPE_DOUBLE;
+ parm.min->description =
+ _("Minimum input/output data value");
+ parm.max = G_define_option();
+ parm.max->key = "maximum";
+ parm.max->key_desc = "value";
+ parm.max->required = YES;
+ parm.max->type = TYPE_DOUBLE;
+ parm.max->description =
+ _("Maximum input/output data value");
+ parm.contrast = G_define_option();
+ parm.contrast->key = "contrast";
+ parm.contrast->key_desc = "value";
+ parm.contrast->required = YES;
+ parm.contrast->type = TYPE_DOUBLE;
+ parm.contrast->answer = "1.0";
+ parm.contrast->description = _("Contrast (gain, 8bit=>[1.0-3.0] ");
+ parm.f_offset = G_define_option();
+ parm.f_offset->key = "brightness";
+ parm.f_offset->key_desc = "value";
+ parm.f_offset->required = YES;
+ parm.f_offset->type = TYPE_DOUBLE;
+ parm.f_offset->answer = "0.0";
+ parm.f_offset->description = _("Brightness (bias, 8bit=>[0.0-100.0])");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ input = parm.input->answer;
+ output = parm.output->answer;
+ /* get setting of current GRASS region */
+ nrows = Rast_window_rows();
+ ncols = Rast_window_cols();
+ /* get user parameters */
+ contrast = strtod(parm.contrast->answer, 0);
+ brightness = strtod(parm.f_offset->answer, 0);
+ min = strtod(parm.min->answer, 0);
+ max = strtod(parm.max->answer, 0);
+ /* open raster input map and get its storage type */
+ Rast_get_cellhd(input, "", &cellhd);
+ in_fd = Rast_open_old(input, "");
+ RASTER_MAP_TYPE IN_TYPE = Rast_get_map_type(in_fd);
+ /* Open output map with right data type */
+ out_fd = Rast_open_new(output, IN_TYPE);
+ if (out_fd < 0) {
+ G_fatal_error("Cannot open output map.");
+ switch(IN_TYPE){
+ case CELL_TYPE:
+ inrastc = Rast_allocate_c_buf();
+ outrastc = Rast_allocate_c_buf();
+ for (row = 0; row < nrows; row++)
+ G_percent(row, nrows, 2);
+ Rast_get_c_row(in_fd, inrastc, row);
+ for (col = 0; col < ncols; col++)
+ pix = (double) inrastc[col];
+ if (Rast_is_d_null_value(&pix)){
+ Rast_set_c_null_value(&outrastc[col], 1);
+ }else{
+ pixout=contrast*pix+brightness;
+ if(pixout<min) pixout=min;
+ if(pixout>max) pixout=max;
+ outrastc[col] = (int) pixout;
+ Rast_put_c_row(out_fd, outrastc);
+ G_free(inrastc);
+ G_free(outrastc);
+ break;
+ case FCELL_TYPE:
+ inrastf = Rast_allocate_f_buf();
+ outrastf = Rast_allocate_f_buf();
+ Rast_get_f_row(in_fd, inrastf, row);
+ pix = (double) inrastf[col];
+ Rast_set_f_null_value(&outrastf[col], 1);
+ }else{
+ outrastf[col] = (float) pixout;
+ Rast_put_f_row(out_fd, outrastf);
+ G_free(inrastf);
+ G_free(outrastf);
+ break;
+ case DCELL_TYPE:
+ inrastd = Rast_allocate_d_buf();
+ outrastd = Rast_allocate_d_buf();
+ Rast_get_d_row(in_fd, inrastd, row);
+ pix = inrastd[col];
+ Rast_set_d_null_value(&outrastd[col], 1);
+ }else{
+ outrastd[col] = pixout;
+ Rast_put_d_row(out_fd, outrastd);
+ G_free(inrastd);
+ G_free(outrastd);
+ break;
+ /* close all maps */
+ Rast_close(out_fd);
+ Rast_close(in_fd);
+ /* write metadata into result and error maps */
+ Rast_short_history(parm.output->answer, "raster", &hist);
+ Rast_put_cell_title(parm.output->answer,
+ "Result from r.colors.contrast");
+ switch(IN_TYPE){
+ case CELL_TYPE:
+ Rast_append_format_history(&hist,
+ " min=%d, max=%d",(int) min, (int) max);
+ break;
+ case FCELL_TYPE:
+ " min=%.3f, max=%.3f", min, max);
+ break;
+ case DCELL_TYPE:
+ break;
+ Rast_write_history(parm.output->answer, &hist);
+ return (EXIT_SUCCESS);
Added: grass-addons/grass7/raster/r.colors.contrastbrightness/r.colors.contrastbrightness.html
--- grass-addons/grass7/raster/r.colors.contrastbrightness/r.colors.contrastbrightness.html (rev 0)
+++ grass-addons/grass7/raster/r.colors.contrastbrightness/r.colors.contrastbrightness.html 2017-06-26 07:08:39 UTC (rev 71218)
@@ -0,0 +1,49 @@
+<h2>DESCRIPTION</h2>
+The <em>r.colors.contrastbrightness</em> module generates
+a contrasted version of the input raster map.
+The contrast is the gain of the affine transform, use values of 1.0-3.0 in case of an 8 bit image.
+The brightness is the bias of the affine transform, use values of 0.0-100.0 in case of an 8 bit image.
+<h2>EXAMPLES</h2>
+Contrast enhancement of an 8-bit raster band
+This does nothing to the image:
+<div class="code"><pre>
+r.colors.contrastbrightness min=0.0 max=255.0 contrast=1.0 brightness=0.0 input=myinraster output=myoutraster
+</pre></div>
+This does change the contrast of the image:
+r.colors.contrastbrightness min=0.0 max=255.0 contrast=3.0 brightness=0.0 input=myinraster output=myoutraster
+</pre></div>
+This does change the brightness of the image:
+r.colors.contrastbrightness min=0.0 max=255.0 contrast=1.0 brightness=100.0 input=myinraster output=myoutraster
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.colors.html">r.colors</a>,
+<a href="v.colors.html">v.colors</a>,
+<a href="r3.colors.html">r3.colors</a>,
+<a href="r.cpt2grass.html">r.cpt2grass</a>,
+<a href="r.colors.matplotlib.html">r.colors.matplotlib</a>
+</em>
+<h2>AUTHOR</h2>
+Yann Chemin, <a href="http://jrc.it/">JRC, Ispra, Italy</a><br>
+<p>
+<i>Last changed: $Date: 2017-06-26 09:40:22 +0200 (Sam., 26 juin 2017) $</i>
