[GRASS-SVN] r71219 - grass/branches/releasebranch_7_2/lib/python/ctypes/ctypesgencore/parser
svn_grass at osgeo.org
Mon Jun 26 05:48:38 PDT 2017
Author: neteler
Date: 2017-06-26 05:48:38 -0700 (Mon, 26 Jun 2017)
New Revision: 71219
grass/branches/releasebranch_7_2/lib/python/ctypes/ctypesgencore/parser/lextab.py
grass/branches/releasebranch_7_2/lib/python/ctypes/ctypesgencore/parser/pplexer.py
python ctypesgencore: lexer support added for FLT64X_EPSILON (trunk r71196 and r71213; trac #3331; contributed by glynn)
Modified: grass/branches/releasebranch_7_2/lib/python/ctypes/ctypesgencore/parser/lextab.py
--- grass/branches/releasebranch_7_2/lib/python/ctypes/ctypesgencore/parser/lextab.py 2017-06-26 07:08:39 UTC (rev 71218)
+++ grass/branches/releasebranch_7_2/lib/python/ctypes/ctypesgencore/parser/lextab.py 2017-06-26 12:48:38 UTC (rev 71219)
@@ -1,59 +1,8 @@
# lextab.py. This file automatically created by PLY (version 2.2). Don't edit!
-_lextokens = {
- 'RIGHT_OP': None,
- 'RIGHT_ASSIGN': None,
- 'DEC_OP': None,
- 'PP_MACRO_PARAM': None,
- 'DIV_ASSIGN': None,
- 'PP_DEFINE': None,
- 'PP_END_DEFINE': None,
- 'PP_DEFINE_MACRO_NAME': None,
- 'HEADER_NAME': None,
- 'NEWLINE': None,
- 'CHARACTER_CONSTANT': None,
- 'PP_STRINGIFY': None,
- 'AND_ASSIGN': None,
- 'PTR_OP': None,
- 'ELLIPSIS': None,
- 'IDENTIFIER': None,
- 'ADD_ASSIGN': None,
- 'PERIOD': None,
- 'AND_OP': None,
- 'OTHER': None,
- 'LPAREN': None,
- 'LEFT_OP': None,
- 'LE_OP': None,
- 'OR_OP': None,
- 'SUB_ASSIGN': None,
- 'MOD_ASSIGN': None,
- 'STRING_LITERAL': None,
- 'PP_IDENTIFIER_PASTE': None,
- 'PP_NUMBER': None,
- 'PP_DEFINE_NAME': None,
- 'XOR_ASSIGN': None,
- 'OR_ASSIGN': None,
- 'GE_OP': None,
- 'MUL_ASSIGN': None,
- 'LEFT_ASSIGN': None,
- 'INC_OP': None,
- 'NE_OP': None,
- 'EQ_OP': None}
-_lexreflags = 0
-_lexliterals = ''
+_lextokens = {'RIGHT_OP': None, 'RIGHT_ASSIGN': None, 'DEC_OP': None, 'PP_MACRO_PARAM': None, 'DIV_ASSIGN': None, 'PP_DEFINE': None, 'PP_END_DEFINE': None, 'PP_DEFINE_MACRO_NAME': None, 'HEADER_NAME': None, 'NEWLINE': None, 'CHARACTER_CONSTANT': None, 'PP_STRINGIFY': None, 'AND_ASSIGN': None, 'PTR_OP': None, 'ELLIPSIS': None, 'IDENTIFIER': None, 'ADD_ASSIGN': None, 'PERIOD': None, 'AND_OP': None, 'OTHER': None, 'LPAREN': None, 'LEFT_OP': None, 'LE_OP': None, 'OR_OP': None, 'SUB_ASSIGN': None, 'MOD_ASSIGN': None, 'STRING_LITERAL': None, 'PP_IDENTIFIER_PASTE': None, 'PP_NUMBER': None, 'PP_DEFINE_NAME': None, 'XOR_ASSIGN': None, 'OR_ASSIGN': None, 'GE_OP': None, 'MUL_ASSIGN': None, 'LEFT_ASSIGN': None, 'INC_OP': None, 'NE_OP': None, 'EQ_OP': None}
+_lexreflags = 0
+_lexliterals = ''
_lexstateinfo = {'INITIAL': 'inclusive', 'DEFINE': 'exclusive'}
-_lexstatere = {
- 'INITIAL': [
- ('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|\\*=|\\^=|<<=|>>=|\\|=|\\+=|>=|>>|<<|<=|<:|%=|:>|<%|!=|\\)|\\+|\\*|\\.|\\?|==|&=|&&|\\[|\\^|--|/=|%>|-=|->|\\||!|%|&|-|,|/|;|:|=|>|]|<|{|}|~))', [
- None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [
- None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>[FflL]?)(?!\\w))', [
- None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [
- None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_INITIAL_newline>\\n)|(?P<t_INITIAL_pp_define>\\#define)', [
- None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_INITIAL_newline', 'INITIAL_newline'), ('t_INITIAL_pp_define', 'INITIAL_pp_define')])], 'DEFINE': [
- None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [
- None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>[FflL]?)(?!\\w))', [
- None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t_DEFINE_pp_param_op>(\\#\\#)|(\\#))', [
- None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])]}
+_lexstatere = {'INITIAL': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|>>=|\\|=|\\^=|<<=|\\*=|\\+=|>=|>>|%=|:>|%>|!=|\\*|\\.|==|\\^|--|-=|->|\\||<<|<=|<:|<%|\\)|\\+|\\?|&=|&&|\\[|/=|&|,|:|<|>|~|!|%|-|/|;|=|]|{|}))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_INITIAL_newline>\\n)|
(?P<t_INITIAL_pp_define>\\#define)', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_INITIAL_newline', 'INITIAL_newline'), ('t_INITIAL_pp_define', 'INITIAL_pp_define')])], 'DEFINE': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|>>=|\\|=|\\^=|<<=|\\*=|\\+=|>=|>>|%=|:>|%>|!=|\\*|\\.|==|\\^|--|-=|->|\\||<<|<=|<:|<%|\\)|\\+|\\?|&=|&&|\\[|/=|&|,|:|<|>|~|!|%|-|/|;|=|]|{|}))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_
int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t_DEFINE_pp_param_op>(\\#\\#)|(\\#))', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])]}
_lexstateignore = {'INITIAL': ' \t\x0b\x0c\r', 'DEFINE': ' \t\x0b\x0c\r'}
_lexstateerrorf = {'INITIAL': 't_INITIAL_error', 'DEFINE': 't_DEFINE_error'}
Modified: grass/branches/releasebranch_7_2/lib/python/ctypes/ctypesgencore/parser/pplexer.py
--- grass/branches/releasebranch_7_2/lib/python/ctypes/ctypesgencore/parser/pplexer.py 2017-06-26 07:08:39 UTC (rev 71218)
+++ grass/branches/releasebranch_7_2/lib/python/ctypes/ctypesgencore/parser/pplexer.py 2017-06-26 12:48:38 UTC (rev 71219)
@@ -52,7 +52,7 @@
'L': '[a-zA-Z_]',
'H': '[a-fA-F0-9]',
'E': '[Ee][+-]?\s*{D}+',
- 'FS': '[FflL]',
+ 'FS': '([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)',
'IS': '[uUlL]*',
# Helper: substitute {foo} with subs[foo] in string (makes regexes more lexy)
@@ -226,10 +226,10 @@
exp = m.group("exp")
suf = m.group("suf")
- if dp or exp or (suf and suf in ("Ff")):
+ if dp or exp or (suf and suf not in ("Ll")):
s = m.group(0)
if suf:
- s = s[:-1]
+ s = s[:-len(suf)]
# Attach a prefix so the parser can figure out if should become an
# integer, float, or long
t.value = "f" + s
