[GRASS-SVN] r70710 - in grass/branches/releasebranch_7_2: lib/vector/vedit raster/r.timestamp raster/r.to.vect raster/r.topidx raster/r.topmodel scripts/v.db.addtable vector/v.build.polylines vector/v.distance vector/v.edit vector/v.patch vector/v.select vector/v.to.db vector/v.to.points vector/v.what
svn_grass at osgeo.org
Wed Mar 1 03:45:44 PST 2017
Author: hcho
Date: 2017-03-01 03:45:44 -0800 (Wed, 01 Mar 2017)
New Revision: 70710
Added:
grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c
grass/branches/releasebranch_7_2/lib/vector/vedit/break.c
grass/branches/releasebranch_7_2/lib/vector/vedit/move.c
grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c
grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html
grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c
grass/branches/releasebranch_7_2/raster/r.to.vect/global.h
grass/branches/releasebranch_7_2/raster/r.to.vect/main.c
grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html
grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html
grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py
grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c
grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c
grass/branches/releasebranch_7_2/vector/v.distance/main.c
grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html
grass/branches/releasebranch_7_2/vector/v.edit/main.c
grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c
grass/branches/releasebranch_7_2/vector/v.patch/main.c
grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c
grass/branches/releasebranch_7_2/vector/v.select/main.c
grass/branches/releasebranch_7_2/vector/v.to.db/main.c
grass/branches/releasebranch_7_2/vector/v.to.points/write.c
grass/branches/releasebranch_7_2/vector/v.what/main.c
Backport r70666, r70637, r70636, r70635, r70634, r70633, r70706, r70707, r70708, r70611, r70612, r70613, r70614, r70599, r70589, r70586, r70582, r70537, r70509, r70506, r70709, r70507, r69139
Modified: grass/branches/releasebranch_7_2/lib/vector/vedit/break.c
--- grass/branches/releasebranch_7_2/lib/vector/vedit/break.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/lib/vector/vedit/break.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -247,12 +247,13 @@
line_new = -1;
if (line_new > -1) {
+ n_points = Points_from->n_points - 1;
if (first) {
x = Points_from->x[0];
y = Points_from->y[0];
else {
- n_points = Points_from->n_points - 1;
x = Points_from->x[n_points];
y = Points_from->y[n_points];
Modified: grass/branches/releasebranch_7_2/lib/vector/vedit/move.c
--- grass/branches/releasebranch_7_2/lib/vector/vedit/move.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/lib/vector/vedit/move.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -71,7 +71,7 @@
for (bgi = 0; bgi < nbgmaps; bgi++) {
if (Vedit_snap_point
- (BgMap[bgi], line, &x[j], &y[j], &z[j], thresh,
+ (BgMap[bgi], -1, &x[j], &y[j], &z[j], thresh,
(snap == SNAPVERTEX) ? 1 : 0))
break; /* snapped, don't continue */
Modified: grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c
--- grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/lib/vector/vedit/vertex.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -115,7 +115,7 @@
- (BgMap[bgi], line, &x[k], &y[k],
+ (BgMap[bgi], -1, &x[k], &y[k],
&z[k], thresh_snap,
moved[k] = 2;
Modified: grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html
--- grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.timestamp/r.timestamp.html 2017-03-01 11:45:44 UTC (rev 70710)
@@ -15,7 +15,7 @@
The timestamp values must use the format as described in the <em>GRASS
Datetime Library</em>. The source tree for this library should have a
-description of the format. For convience, the formats are reproduced
+description of the format. For convenience, the formats are reproduced
here:
<p>There are two types of datetime values:
Modified: grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c
--- grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.to.vect/areas_io.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -34,7 +34,7 @@
int write_boundary(struct COOR *seed)
struct COOR *point, *line_begin, *line_end, *last;
- int dir, line_type, n, n1, i;
+ int dir, line_type, n, n1;
point = seed;
if ((dir = at_end(point))) { /* already have one end of line */
Modified: grass/branches/releasebranch_7_2/raster/r.to.vect/global.h
--- grass/branches/releasebranch_7_2/raster/r.to.vect/global.h 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.to.vect/global.h 2017-03-01 11:45:44 UTC (rev 70710)
@@ -104,7 +104,7 @@
int extract_lines(void);
/* lines_io.c */
-int write_line(struct COOR *seed);
+int write_line(struct COOR *);
/* areas.c */
int alloc_areas_bufs(int);
@@ -112,7 +112,7 @@
int more_equivs(void);
/* areas_io.c */
-int write_boundary(struct COOR *seed);
+int write_boundary(struct COOR *);
int write_area(struct area_table *, struct equiv_table *, int, int);
/* points.c */
@@ -124,4 +124,7 @@
int at_end(struct COOR *);
int read_row(void *);
void insert_value(int, int, double);
-int free_ptr(struct COOR *ptr);
+int free_ptr(struct COOR *);
+/* set_error_handler.c */
+void set_error_handler(struct Map_info *, dbDriver **);
Modified: grass/branches/releasebranch_7_2/raster/r.to.vect/main.c
--- grass/branches/releasebranch_7_2/raster/r.to.vect/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.to.vect/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -8,7 +8,7 @@
* PURPOSE: Converts a raster map into a vector map layer
- * COPYRIGHT: (C) 2007, 2011 by the GRASS Development Team
+ * COPYRIGHT: (C) 2007, 2011, 2017 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -151,10 +151,11 @@
G_warning(_("Categories will be unique sequence, raster values will be lost."));
+ set_error_handler(&Map, &driver);
if (Vect_open_new(&Map, out_opt->answer, z_flg->answer) < 0)
G_fatal_error(_("Unable to create vector map <%s>"), out_opt->answer);
- Vect_set_error_handler_io(NULL, &Map);
Vect_hist_command(&Map);
Cats = Vect_new_cats_struct();
@@ -186,7 +187,6 @@
if (driver == NULL)
G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
Fi->database, Fi->driver);
- db_set_error_handler_driver(driver);
/* Create new table */
db_zero_string(&sql);
Added: grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c
--- grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c (rev 0)
+++ grass/branches/releasebranch_7_2/raster/r.to.vect/set_error_handler.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -0,0 +1,33 @@
+#include <grass/gis.h>
+#include <grass/vector.h>
+struct handler_input
+ struct Map_info *Map;
+ dbDriver **driver;
+static void error_handler(void *p)
+ const struct handler_input *input = (const struct handler_input *)p;
+ if (input->driver && *input->driver)
+ db_close_database_shutdown_driver(*input->driver);
+ if (input->Map) {
+ char *name = G_store(input->Map->name);
+ if (input->Map->open == VECT_OPEN_CODE)
+ Vect_close(input->Map);
+ Vect_delete(name);
+ G_free(name);
+void set_error_handler(struct Map_info *Map, dbDriver **driver)
+ struct handler_input *input = G_malloc(sizeof(struct handler_input));
+ input->Map = Map;
+ input->driver = driver;
+ G_add_error_handler(error_handler, input);
Modified: grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html
--- grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.topidx/r.topidx.html 2017-03-01 11:45:44 UTC (rev 70710)
@@ -23,7 +23,7 @@
<a href="r.mapcalc.html">r.mapcalc</a>
</em>
<br>
-<a href="http://idea.isnew.info/r.topidx">Known issues</a>
+<a href="http://idea.isnew.info/r.topidx.html">Known issues</a>
<h2>REFERENCES</h2>
Modified: grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html
--- grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/raster/r.topmodel/r.topmodel.html 2017-03-01 11:45:44 UTC (rev 70710)
@@ -152,7 +152,7 @@
<a href="r.topidx.html">r.topidx</a>
</em>
<br>
-<a href="http://idea.isnew.info/r.topmodel">How to run r.topmodel</a>
+<a href="http://idea.isnew.info/r.topmodel.html">How to run r.topmodel</a>
<h2>AUTHORS</h2>
Modified: grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py
--- grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/scripts/v.db.addtable/v.db.addtable.py 2017-03-01 11:45:44 UTC (rev 70710)
@@ -86,7 +86,7 @@
grass.verbose(_("Using user specified table name: %s") % table)
# check if DB parameters are set, and if not set them.
- grass.run_command('db.connect', flags='c')
+ grass.run_command('db.connect', flags='c', quiet=True)
grass.verbose(_("Creating new DB connection based on default mapset settings..."))
kv = grass.db_connection()
database = kv['database']
@@ -106,15 +106,21 @@
stderr=nuldev)
if not table in tables.splitlines():
+ colnames = []
if columns:
- column_def = [x.strip().lower() for x in columns.strip().split(',')]
+ column_def = []
+ for x in ' '.join(columns.lower().split()).split(','):
+ colname = x.split()[0]
+ if colname in colnames:
+ grass.fatal(_("Duplicate column name '%s' not allowed") % colname)
+ colnames.append(colname)
+ column_def.append(x)
else:
column_def = []
# if not existing, create it:
- column_def_key = "%s integer" % key
- if column_def_key not in column_def:
- column_def.insert(0, column_def_key)
+ if not key in colnames:
+ column_def.insert(0, "%s integer" % key)
column_def = ','.join(column_def)
grass.verbose(_("Creating table with columns (%s)...") % column_def)
@@ -133,10 +139,17 @@
map=map_name, database=database, driver=driver,
layer=layer, table=table, key=key)
- # finally we have to add cats into the attribute DB to make modules such as v.what.rast happy:
- # (creates new row for each vector line):
- grass.run_command('v.to.db', map=map_name, layer=layer,
- option='cat', column=key, qlayer=layer)
+ # finally we have to add cats into the attribute DB to make
+ # modules such as v.what.rast happy: (creates new row for each
+ # vector line):
+ try:
+ grass.run_command('v.to.db', map=map_name, layer=layer,
+ option='cat', column=key, qlayer=layer)
+ except CalledModuleError:
+ # remove link
+ grass.run_command('v.db.connect', quiet=True, flags='d',
+ map=map_name, layer=layer)
+ return 1
grass.verbose(_("Current attribute table links:"))
if grass.verbosity() > 2:
Modified: grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c
--- grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.build.polylines/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -97,7 +97,6 @@
int polyline;
int *lines_visited;
- int points_in_polyline;
int start_line;
int nlines;
int write_cats, copy_tables;
@@ -177,8 +176,10 @@
write_cats = NO_CATS;
else if (strcmp(cats->answer, "first") == 0)
write_cats = ONE_CAT;
- else
+ else if (strcmp(cats->answer, "multi") == 0)
write_cats = MULTI_CATS;
+ else
+ write_cats = SAME_CATS;
if (type_opt->answer)
type = Vect_option_to_types(type_opt);
@@ -218,9 +219,8 @@
G_debug(1, "Polyline %d: start line = %d", polyline, start_line);
/* Walk forward and pick up coordinates */
- points_in_polyline =
- walk_forward_and_pick_up_coords(&map, start_line, ltype, points,
- lines_visited, Cats, write_cats);
+ walk_forward_and_pick_up_coords(&map, start_line, ltype, points,
+ lines_visited, Cats, write_cats);
/* Write the line (type of the first line is used) */
Vect_write_line(&Out, ltype, points, Cats);
@@ -230,12 +230,10 @@
G_verbose_message(n_("%d line or boundaries found in input vector map",
"%d lines or boundaries found in input vector map",
- nlines),
- nlines, Vect_get_name(&map), Vect_get_mapset(&map));
+ nlines), nlines);
G_verbose_message(n_("%d polyline stored in output vector map",
"%d polylines stored in output vector map",
- polyline),
- polyline, Vect_get_name(&Out), Vect_get_mapset(&Out));
+ polyline), polyline);
/* Copy (all linked) tables if needed */
if (copy_tables) {
Modified: grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c
--- grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.build.polylines/walk.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -129,7 +129,7 @@
int cat_idx;
int line, next_line, n1, n2;
- int type, node, next_node;
+ int node, next_node;
struct line_pnts *pnts;
struct line_cats *cats_tmp;
@@ -149,9 +149,9 @@
/* Pick up first set of coordinates */
lines_visited[line] = 1;
if (cats_tmp)
- type = Vect_read_line(map, pnts, Cats, line);
+ Vect_read_line(map, pnts, Cats, line);
else
- type = Vect_read_line(map, pnts, NULL, line);
+ Vect_read_line(map, pnts, NULL, line);
Vect_get_line_nodes(map, line, &n1, &n2);
next_line = find_next_line(map, line, n1, ltype);
@@ -175,7 +175,7 @@
node = next_node;
while (line != 0 && line != start_line) {
G_debug(2, " line = %d", line);
- type = Vect_read_line(map, pnts, cats_tmp, line);
+ Vect_read_line(map, pnts, cats_tmp, line);
if (cats_tmp && write_cats == MULTI_CATS) {
for (cat_idx = 0; cat_idx < cats_tmp->n_cats; cat_idx++) {
Vect_cat_set(Cats, cats_tmp->field[cat_idx],
Modified: grass/branches/releasebranch_7_2/vector/v.distance/main.c
--- grass/branches/releasebranch_7_2/vector/v.distance/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.distance/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -286,6 +286,10 @@
Upload[i].upload = TO_ATTR;
+ /* store default column names if column= is not given */
+ if (!opt.column->answer)
+ Upload[i].column = G_store(opt.upload->answers[i]);
i++;
Upload[i].upload = END;
@@ -625,8 +629,12 @@
/* Go through all lines in 'from' and find nearest in 'to' for each */
- /* Note: as from_type is restricted to GV_POINTS (for now) everything is simple */
+ /* Note: as from_type is restricted to GV_POINTS (for now) everything is
+ * simple */
+ /* suppress compiler warnings */
+ tx = ty = tz = fx = fy = fz = 0;
count = 0; /* count of distances in 'do_all' mode */
/* Find nearest features for 'from' lines */
if (nfromlines) {
@@ -1388,7 +1396,7 @@
G_percent(i, count, 1);
/* Write line connecting nearest points */
- if (Outp != NULL) {
+ if (Near[i].count > 0 && Outp != NULL) {
Vect_reset_line(FPoints);
Vect_reset_cats(FCats);
Modified: grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html
--- grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.distance/v.distance.html 2017-03-01 11:45:44 UTC (rev 70710)
@@ -97,7 +97,7 @@
needed for network analysis:
<div class="code"><pre>
-v.distance -p from=pnt to=ln out=connections upload=dist column=dist
+v.distance from=pnt to=ln out=connections upload=dist column=dist
</pre></div>
<h3>Query information</h3>
@@ -116,7 +116,7 @@
Find nearest features:
-v.distance from=pnt to=map_to_query upload=cat col=somecol -p
+v.distance -p from=pnt to=map_to_query upload=cat
</pre></div>
<h3>Point-in-polygon</h3>
@@ -174,7 +174,7 @@
echo "0|-58|1" | v.in.ascii output=pnt2 input=-
# here, distances is in degree units
-v.distance from=pnt1 to=pnt2 upload=dist col=distance -p --q
+v.distance -p --q from=pnt1 to=pnt2 upload=dist
from_cat|distance
1|3
</pre></div>
@@ -186,15 +186,14 @@
<p>
Spearfish sample data location:
-v.distance -pa from=archsites to=archsites upload=dist col=dist
+v.distance -pa from=archsites to=archsites upload=dist
</pre></div>
<p>
North Carolina sample data location:
-v.distance -pa from=hospitals to=hospitals upload=dist \
- col=dist separator=comma
+v.distance -pa from=hospitals to=hospitals upload=dist separator=tab
from_cat to_cat dist
1 2 3 4 5 ...
1 0 7489.10 339112.17 70900.39 70406.23 ...
Modified: grass/branches/releasebranch_7_2/vector/v.edit/main.c
--- grass/branches/releasebranch_7_2/vector/v.edit/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.edit/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -8,7 +8,7 @@
* Jachym Cepicky
* Major updates by Martin Landa <landa.martin gmail.com>
- * COPYRIGHT: (C) 2006-2014 by the GRASS Development Team
+ * COPYRIGHT: (C) 2006-2017 by the GRASS Development Team
* Public License (>=v2). Read the file COPYING that comes
Modified: grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c
--- grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.edit/max_distance.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -39,6 +39,8 @@
if (maxdistance < 0.0) {
G_get_window(&window);
+ G_begin_distance_calculations();
ew_dist1 =
G_distance(window.east, window.north, window.west, window.north);
/* EW Dist at South Edge */
Modified: grass/branches/releasebranch_7_2/vector/v.patch/main.c
--- grass/branches/releasebranch_7_2/vector/v.patch/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.patch/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -413,8 +413,11 @@
Vect_set_map_name(&OutMap, "Output from v.patch");
Vect_set_person(&OutMap, G_whoami());
- if (!no_topo->answer)
+ if (!no_topo->answer) {
+ if (append->answer)
+ Vect_build_partial(&OutMap, GV_BUILD_NONE);
Vect_build(&OutMap);
Vect_close(&OutMap);
if (bbox_name) {
Modified: grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c
--- grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.select/copy_tabs.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -55,12 +55,17 @@
OFi =
Vect_default_field_info(Out, IFi->number, IFi->name, ttype);
- ret =
- db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
- OFi->driver,
- Vect_subst_var(OFi->database, Out),
- OFi->table, IFi->key, cats[i],
- ncats[i]);
+ if (ncats[i] > 0)
+ ret = db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
+ OFi->driver,
+ Vect_subst_var(OFi->database, Out),
+ OFi->table, IFi->key, cats[i],
+ ncats[i]);
+ else
+ ret = db_copy_table_where(IFi->driver, IFi->database, IFi->table,
+ OFi->driver,
+ OFi->table, "0 = 1");
if (ret == DB_FAILED) {
G_warning(_("Unable to copy table for layer %d"), fields[i]);
Modified: grass/branches/releasebranch_7_2/vector/v.select/main.c
--- grass/branches/releasebranch_7_2/vector/v.select/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.select/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -7,7 +7,7 @@
* Markus Neteler <neteler itc.it>
* Martin Landa <landa.martin gmail.com> (GEOS support)
* PURPOSE: Select features from one map by features in another map.
- * COPYRIGHT: (C) 2003-2014 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2017 by the GRASS Development Team
Modified: grass/branches/releasebranch_7_2/vector/v.to.db/main.c
--- grass/branches/releasebranch_7_2/vector/v.to.db/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.to.db/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -68,7 +68,7 @@
/* allocate array for values */
- /* (+ 1 is for cat -1 (no category) reported at the end ) */
+ /* (+1 is for cat -1 (no category) reported at the end ) */
findex = Vect_cidx_get_field_index(&Map, options.field);
if (findex > -1) {
n = Vect_cidx_get_num_unique_cats_by_index(&Map, findex);
@@ -80,7 +80,8 @@
Values = (struct value *) G_calloc(n + 1, sizeof(struct value));
/* prepopulate Values */
- n = Vect_cidx_get_num_cats_by_index(&Map, findex);
+ if (findex > -1)
+ n = Vect_cidx_get_num_cats_by_index(&Map, findex);
i = 0;
Values[i].cat = -1; /* features without category */
Values[i].used = 0;
Modified: grass/branches/releasebranch_7_2/vector/v.to.points/write.c
--- grass/branches/releasebranch_7_2/vector/v.to.points/write.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.to.points/write.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -84,7 +84,7 @@
len = hypot(hypot(dx, dy), dz);
/* interpolate segment */
- if (interpolate && vert < (LPoints->n_points - 1)) {
+ if (vertex == GV_VERTEX && interpolate) {
int i, n;
double x, y, z, dlen;
Modified: grass/branches/releasebranch_7_2/vector/v.what/main.c
--- grass/branches/releasebranch_7_2/vector/v.what/main.c 2017-03-01 11:35:50 UTC (rev 70709)
+++ grass/branches/releasebranch_7_2/vector/v.what/main.c 2017-03-01 11:45:44 UTC (rev 70710)
@@ -134,6 +134,7 @@
x = window.proj;
G_format_resolution(window.ew_res, ewres, x);
G_format_resolution(window.ns_res, nsres, x);
EW_DIST1 =
