[GRASS-SVN] r70711 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Mar 1 04:00:30 PST 2017
Author: hcho
Date: 2017-03-01 04:00:30 -0800 (Wed, 01 Mar 2017)
New Revision: 70711
grass/trunk/lib/vector/Vlib/sindex.c
Vlib: Don't select duplicate areas
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c 2017-03-01 11:45:44 UTC (rev 70710)
+++ grass/trunk/lib/vector/Vlib/sindex.c 2017-03-01 12:00:30 UTC (rev 70711)
@@ -44,7 +44,7 @@
Box->E, Box->W, Box->T, Box->B);
plus = &(Map->plus);
- list->n_values = 0;
+ Vect_reset_list(list);
ntypes = mtype = 0;
/* count the number of different primitives in Map */
@@ -203,7 +203,7 @@
dig_select_nodes(plus, Box, list);
G_debug(3, " %d nodes selected", list->n_values);
@@ -238,7 +238,7 @@
/* TODO: this function was not tested with isles */
G_debug(3, "Vect_select_lines_by_polygon() nisles = %d", nisles);
- List->n_values = 0;
+ Vect_reset_list(List);
if (!LPoints)
LPoints = Vect_new_line_struct();
if (!LocList) {
@@ -279,14 +279,14 @@
if (intersect) {
- G_ilist_add(List, line);
+ Vect_list_append(List, line);
continue;
/* Check intersections of the line with area/isles boundary */
/* Outer boundary */
if (Vect_line_check_intersection(LPoints, Polygon, 0)) {
continue;
@@ -298,7 +298,7 @@
if (intersect) {
@@ -313,8 +313,6 @@
Polygons should be closed, i.e. first and last points must be identical.
- Warning : values in list may be duplicate!
\param Map vector map
\param Polygon outer ring
\param nisles number of islands or 0
@@ -334,7 +332,7 @@
G_debug(3, "Vect_select_areas_by_polygon() nisles = %d", nisles);
if (!BoundList)
BoundList = Vect_new_list();
@@ -352,23 +350,23 @@
G_debug(4, "boundary = %d left = %d right = %d", line, left, right);
if (left > 0) {
- G_ilist_add(List, left);
+ Vect_list_append(List, left);
else if (left < 0) { /* island */
area = Vect_get_isle_area(Map, abs(left));
G_debug(4, " left island -> area = %d", area);
if (area > 0)
- G_ilist_add(List, area);
+ Vect_list_append(List, area);
if (right > 0) {
- G_ilist_add(List, right);
+ Vect_list_append(List, right);
else if (right < 0) { /* island */
area = Vect_get_isle_area(Map, abs(right));
G_debug(4, " right island -> area = %d", area);
if (area > 0)
@@ -376,7 +374,7 @@
* we find the area by one polygon point and add it to the list */
area = Vect_find_area(Map, Polygon->x[0], Polygon->y[0]);
if (area > 0)
G_debug(3, " %d areas selected by polygon", List->n_values);
