[GRASS-SVN] r70742 - grass-addons/grass7/raster/r.lfp
svn_grass at osgeo.org
Fri Mar 10 22:31:12 PST 2017
Author: hcho
Date: 2017-03-10 22:31:12 -0800 (Fri, 10 Mar 2017)
New Revision: 70742
grass-addons/grass7/raster/r.lfp/r.lfp.html
grass-addons/grass7/raster/r.lfp/r.lfp.py
r.lfp: Make it clear that this module requires r.stream.distance
Modified: grass-addons/grass7/raster/r.lfp/r.lfp.html
--- grass-addons/grass7/raster/r.lfp/r.lfp.html 2017-03-11 06:12:03 UTC (rev 70741)
+++ grass-addons/grass7/raster/r.lfp/r.lfp.html 2017-03-11 06:31:12 UTC (rev 70742)
@@ -1,6 +1,7 @@
<h2>DESCRIPTION</h2>
<em>r.lfp</em> calculates the longest flow path for a given outlet point and
creates a new raster map with a thin line representing the longest flow path.
+This module requires the <em>r.stream.distance</em> addon.
<h2>NOTES</h2>
Modified: grass-addons/grass7/raster/r.lfp/r.lfp.py
--- grass-addons/grass7/raster/r.lfp/r.lfp.py 2017-03-11 06:12:03 UTC (rev 70741)
+++ grass-addons/grass7/raster/r.lfp/r.lfp.py 2017-03-11 06:31:12 UTC (rev 70742)
@@ -14,7 +14,7 @@
#%module
-#% description: Calculates the longest flow path for a given outlet point.
+#% description: Calculates the longest flow path for a given outlet point using the r.stream.distance addon.
#% keyword: hydrology
#% keyword: watershed
#%end
@@ -134,7 +134,7 @@
grass.run_command("g.remove", flags="f", type="raster,vector",
pattern="%s*" % prefix)
- # write history
+ # write metadata
tmphist = grass.tempfile()
f = open(tmphist, "w+")
f.write(os.environ["CMDLINE"])
@@ -144,6 +144,7 @@
loadhistory=tmphist, description="generated by r.lfp")
grass.try_remove(tmphist)
if __name__ == "__main__":
options, flags = grass.parser()
sys.exit(main())
