[GRASS-SVN] r70743 - grass/trunk/gui/wxpython/iphoto2image
svn_grass at osgeo.org
Sat Mar 11 03:13:12 PST 2017
Author: ychemin
Date: 2017-03-11 03:13:12 -0800 (Sat, 11 Mar 2017)
New Revision: 70743
grass/trunk/gui/wxpython/iphoto2image/ip2i_manager.py
Module adds output file to the group for use in the next i.ortho.photo module
Modified: grass/trunk/gui/wxpython/iphoto2image/ip2i_manager.py
--- grass/trunk/gui/wxpython/iphoto2image/ip2i_manager.py 2017-03-11 06:31:12 UTC (rev 70742)
+++ grass/trunk/gui/wxpython/iphoto2image/ip2i_manager.py 2017-03-11 11:13:12 UTC (rev 70743)
@@ -370,7 +370,7 @@
# make a backup of the current points file if exists
if os.path.exists(self.file['points']):
shutil.copy(self.file['points'], self.file['points_bak'])
- GMessage (_("An POINTS file exists, renaming it to POINTS_BAK"))
+ GMessage (_("A POINTS file exists, renaming it to POINTS_BAK"))
#"""Make a POINTS file """
import re,sys
@@ -993,7 +993,7 @@
def OnGeorect(self, event):
- Georectifies map(s) in group using i.rectify or v.transform
+ Georectifies map(s) in group using i.rectify
global maptype
self.SaveGCPs(None)
@@ -1027,8 +1027,29 @@
# provide feedback on failure
if ret != 0:
+ print >> sys.stderr, 'ip2i: Error in i.rectify'
+ print >> sys.stderr, self.grwiz.src_map
print >> sys.stderr, msg
+ busy = wx.BusyInfo(message=_("Writing output image to group, please wait..."),
+ parent=self)
+ wx.Yield()
+ ret1, msg1 = RunCommand('i.group',
+ parent=self,
+ getErrorMsg=True,
+ quiet=False,
+ group=self.xygroup,
+ input=''.join([self.grwiz.src_map.split('@')[0],self.extension]))
+ busy.Destroy()
+ if ret1 != 0:
+ print >> sys.stderr, 'ip2i: Error in i.group'
+ print >> sys.stderr, self.grwiz.src_map.split('@')[0]
+ print >> sys.stderr, self.extension
+ print >> sys.stderr, msg1
self.grwiz.SwitchEnv('target')
def OnGeorectDone(self, **kargs):
