[GRASS-SVN] r70781 - in grass/branches/releasebranch_7_2/lib/vector: Vlib diglib
Tue Mar 21 13:39:38 PDT 2017
Author: mmetz
Date: 2017-03-21 13:39:38 -0700 (Tue, 21 Mar 2017)
New Revision: 70781
   grass/branches/releasebranch_7_2/lib/vector/Vlib/intersect.c
   grass/branches/releasebranch_7_2/lib/vector/diglib/linecros.c
vectorlib: enhance numerical stability for segment intersections (backport from trunk r70780)
Modified: grass/branches/releasebranch_7_2/lib/vector/Vlib/intersect.c
--- grass/branches/releasebranch_7_2/lib/vector/Vlib/intersect.c	2017-03-21 20:38:30 UTC (rev 70780)
+++ grass/branches/releasebranch_7_2/lib/vector/Vlib/intersect.c	2017-03-21 20:39:38 UTC (rev 70781)
@@ -128,20 +128,7 @@
 	first_3d = 0;
-    /* Check identical segments */
-    if ((ax1 == bx1 && ay1 == by1 && ax2 == bx2 && ay2 == by2) ||
-	(ax1 == bx2 && ay1 == by2 && ax2 == bx1 && ay2 == by1)) {
-	G_debug(2, " -> identical segments");
-	*x1 = ax1;
-	*y1 = ay1;
-	*z1 = az1;
-	*x2 = ax2;
-	*y2 = ay2;
-	*z2 = az2;
-	return 5;
-    /*  'Sort' lines by x, y
+    /*  'Sort' each segment by x, y
      *   MUST happen before D, D1, D2 are calculated */
     switched = 0;
     if (bx2 < bx1)
@@ -183,6 +170,59 @@
 	az2 = t;
+    /* Check for identical segments */
+    if (ax1 == bx1 && ay1 == by1 && ax2 == bx2 && ay2 == by2) {
+	G_debug(2, " -> identical segments");
+	*x1 = ax1;
+	*y1 = ay1;
+	*z1 = az1;
+	*x2 = ax2;
+	*y2 = ay2;
+	*z2 = az2;
+	return 5;
+    /*  'Sort' segments by x, y: make sure a <= b
+     *   MUST happen before D, D1, D2 are calculated */
+    switched = 0;
+    if (bx1 < ax1)
+	switched = 1;
+    else if (bx1 == ax1) {
+	if (bx2 < ax2)
+	    switched = 1;
+	else if (bx2 == ax2) {
+	    if (by1 < ay1)
+		switched = 1;
+	    else if (by1 == ay1) {
+		if (by2 < ay2)
+		    switched = 1;
+    if (switched) {
+	t = ax1;
+	ax1 = bx1;
+	bx1 = t;
+	t = ax2;
+	ax2 = bx2;
+	bx2 = t;
+	t = ay1;
+	ay1 = by1;
+	by1 = t;
+	t = ay2;
+	ay2 = by2;
+	by2 = t;
+	t = az1;
+	az1 = bz1;
+	bz1 = t;
+	t = az2;
+	az2 = bz2;
+	bz2 = t;
     d = D;
     d1 = D1;
     d2 = D2;
Modified: grass/branches/releasebranch_7_2/lib/vector/diglib/linecros.c
--- grass/branches/releasebranch_7_2/lib/vector/diglib/linecros.c	2017-03-21 20:38:30 UTC (rev 70780)
+++ grass/branches/releasebranch_7_2/lib/vector/diglib/linecros.c	2017-03-21 20:39:38 UTC (rev 70781)
@@ -61,6 +61,7 @@
     register double d, d1, d2;
     double t;
+    int switched;
     if (ax1 > ax2 || (ax1 == ax2 && ay1 > ay2)) {
 	t = ax1;
@@ -82,6 +83,38 @@
 	by2 = t;
+    switched = 0;
+    if (bx1 < ax1)
+	switched = 1;
+	if (bx2 < ax2)
+	    switched = 1;
+	    if (by1 < ay1)
+		switched = 1;
+		if (by2 < ay2)
+		    switched = 1;
+    if (switched) {
+	t = ax1;
+	ax1 = bx1;
+	bx1 = t;
+	t = ax2;
+	ax2 = bx2;
+	bx2 = t;
+	t = ay1;
+	ay1 = by1;
+	by1 = t;
+	t = ay2;
+	ay2 = by2;
+	by2 = t;
     d = D;
     d1 = D1;
     d2 = D2;
@@ -156,6 +189,7 @@
     register double d, r1, r2;
     double t;
+    int switched;
 	t = ax1;
@@ -177,6 +211,38 @@
 	by2 = t;
+    switched = 0;
+    if (bx1 < ax1)
+	switched = 1;
+	if (bx2 < ax2)
+	    switched = 1;
+	    if (by1 < ay1)
+		switched = 1;
+		if (by2 < ay2)
+		    switched = 1;
+    if (switched) {
+	t = ax1;
+	ax1 = bx1;
+	bx1 = t;
+	t = ax2;
+	ax2 = bx2;
+	bx2 = t;
+	t = ay1;
+	ay1 = by1;
+	by1 = t;
+	t = ay2;
+	ay2 = by2;
+	by2 = t;
     d = D;
     if (d) {
