[GRASS-SVN] r70782 - in grass/branches/releasebranch_7_0/lib/vector: Vlib diglib
svn_grass at osgeo.org
Tue Mar 21 13:40:02 PDT 2017
Author: mmetz
Date: 2017-03-21 13:40:02 -0700 (Tue, 21 Mar 2017)
New Revision: 70782
grass/branches/releasebranch_7_0/lib/vector/Vlib/intersect.c
grass/branches/releasebranch_7_0/lib/vector/diglib/linecros.c
vectorlib: enhance numerical stability for segment intersections (backport from trunk r70780)
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/intersect.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/intersect.c 2017-03-21 20:39:38 UTC (rev 70781)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/intersect.c 2017-03-21 20:40:02 UTC (rev 70782)
@@ -128,20 +128,7 @@
first_3d = 0;
- /* Check identical segments */
- if ((ax1 == bx1 && ay1 == by1 && ax2 == bx2 && ay2 == by2) ||
- (ax1 == bx2 && ay1 == by2 && ax2 == bx1 && ay2 == by1)) {
- G_debug(2, " -> identical segments");
- *x1 = ax1;
- *y1 = ay1;
- *z1 = az1;
- *x2 = ax2;
- *y2 = ay2;
- *z2 = az2;
- return 5;
- /* 'Sort' lines by x, y
+ /* 'Sort' each segment by x, y
* MUST happen before D, D1, D2 are calculated */
switched = 0;
if (bx2 < bx1)
@@ -183,6 +170,59 @@
az2 = t;
+ /* Check for identical segments */
+ if (ax1 == bx1 && ay1 == by1 && ax2 == bx2 && ay2 == by2) {
+ G_debug(2, " -> identical segments");
+ *x1 = ax1;
+ *y1 = ay1;
+ *z1 = az1;
+ *x2 = ax2;
+ *y2 = ay2;
+ *z2 = az2;
+ return 5;
+ /* 'Sort' segments by x, y: make sure a <= b
+ * MUST happen before D, D1, D2 are calculated */
+ switched = 0;
+ if (bx1 < ax1)
+ switched = 1;
+ else if (bx1 == ax1) {
+ if (bx2 < ax2)
+ switched = 1;
+ else if (bx2 == ax2) {
+ if (by1 < ay1)
+ switched = 1;
+ else if (by1 == ay1) {
+ if (by2 < ay2)
+ switched = 1;
+ if (switched) {
+ t = ax1;
+ ax1 = bx1;
+ bx1 = t;
+ t = ax2;
+ ax2 = bx2;
+ bx2 = t;
+ t = ay1;
+ ay1 = by1;
+ by1 = t;
+ t = ay2;
+ ay2 = by2;
+ by2 = t;
+ t = az1;
+ az1 = bz1;
+ bz1 = t;
+ t = az2;
+ az2 = bz2;
+ bz2 = t;
d = D;
d1 = D1;
d2 = D2;
Modified: grass/branches/releasebranch_7_0/lib/vector/diglib/linecros.c
--- grass/branches/releasebranch_7_0/lib/vector/diglib/linecros.c 2017-03-21 20:39:38 UTC (rev 70781)
+++ grass/branches/releasebranch_7_0/lib/vector/diglib/linecros.c 2017-03-21 20:40:02 UTC (rev 70782)
@@ -61,6 +61,7 @@
register double d, d1, d2;
double t;
+ int switched;
if (ax1 > ax2 || (ax1 == ax2 && ay1 > ay2)) {
t = ax1;
@@ -82,6 +83,38 @@
by2 = t;
+ switched = 0;
+ if (bx1 < ax1)
+ switched = 1;
+ if (bx2 < ax2)
+ switched = 1;
+ if (by1 < ay1)
+ switched = 1;
+ if (by2 < ay2)
+ switched = 1;
+ if (switched) {
+ t = ax1;
+ ax1 = bx1;
+ bx1 = t;
+ t = ax2;
+ ax2 = bx2;
+ bx2 = t;
+ t = ay1;
+ ay1 = by1;
+ by1 = t;
+ t = ay2;
+ ay2 = by2;
+ by2 = t;
d = D;
d1 = D1;
d2 = D2;
@@ -156,6 +189,7 @@
register double d, r1, r2;
double t;
+ int switched;
t = ax1;
@@ -177,6 +211,38 @@
by2 = t;
+ switched = 0;
+ if (bx1 < ax1)
+ switched = 1;
+ if (bx2 < ax2)
+ switched = 1;
+ if (by1 < ay1)
+ switched = 1;
+ if (by2 < ay2)
+ switched = 1;
+ if (switched) {
+ t = ax1;
+ ax1 = bx1;
+ bx1 = t;
+ t = ax2;
+ ax2 = bx2;
+ bx2 = t;
+ t = ay1;
+ ay1 = by1;
+ by1 = t;
+ t = ay2;
+ ay2 = by2;
+ by2 = t;
d = D;
if (d) {
