[GRASS-SVN] r70783 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Mar 21 13:45:45 PDT 2017
Author: mmetz
Date: 2017-03-21 13:45:45 -0700 (Tue, 21 Mar 2017)
New Revision: 70783
grass/trunk/lib/vector/Vlib/intersect.c
vectorlib: fix r70780
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c 2017-03-21 20:40:02 UTC (rev 70782)
+++ grass/trunk/lib/vector/Vlib/intersect.c 2017-03-21 20:45:45 UTC (rev 70783)
@@ -114,6 +114,7 @@
static int first_3d = 1;
double d, d1, d2, r1, dtol, t;
+ int switched;
/* TODO: Works for points ? */
@@ -129,19 +130,17 @@
/* 'Sort' each segment by x, y
* MUST happen before D, D1, D2 are calculated */
- if (ax2 < ax1 || (ax2 == ax1 && ay2 < ay1)) {
- t = ax1;
- ax1 = ax2;
- ax2 = t;
- t = ay1;
- ay1 = ay2;
- ay2 = t;
- t = az1;
- az1 = az2;
- az2 = t;
+ /* 'Sort' each segment by x, y
+ * MUST happen before D, D1, D2 are calculated */
+ switched = 0;
+ if (bx2 < bx1)
+ switched = 1;
+ else if (bx2 == bx1) {
+ if (by2 < by1)
+ switched = 1;
- if (bx2 < bx1 || (bx2 == bx1 && by2 < by1)) {
+ if (switched) {
t = bx1;
bx1 = bx2;
bx2 = t;
@@ -153,6 +152,26 @@
bz2 = t;
+ switched = 0;
+ if (ax2 < ax1)
+ switched = 1;
+ else if (ax2 == ax1) {
+ if (ay2 < ay1)
+ switched = 1;
+ if (switched) {
+ t = ax1;
+ ax1 = ax2;
+ ax2 = t;
+ t = ay1;
+ ay1 = ay2;
+ ay2 = t;
+ t = az1;
+ az1 = az2;
+ az2 = t;
/* Check for identical segments */
if (ax1 == bx1 && ay1 == by1 && ax2 == bx2 && ay2 == by2) {
G_debug(2, " -> identical segments");
