[GRASS-SVN] r71020 - grass-addons/grass7/raster/r.object.activelearning
svn_grass at osgeo.org
Thu May 4 01:40:45 PDT 2017
Author: mlennert
Date: 2017-05-04 01:40:45 -0700 (Thu, 04 May 2017)
New Revision: 71020
grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py
r.object.activelearning: Import grass libraries before calling them
Modified: grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py
--- grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py 2017-05-04 07:29:38 UTC (rev 71019)
+++ grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py 2017-05-04 08:40:45 UTC (rev 71020)
@@ -95,6 +95,11 @@
#%end
+try : # You can run the tests outside of grass where those imports are not available
+ import grass as grass
+ import grass.script as gcore
+except ImportError :
+ pass
try :
from sklearn import svm
@@ -106,12 +111,6 @@
gcore.fatal("This module requires the scikit-learn python package. Please install it.")
-try : # You can run the tests outside of grass where those imports are not available
- import grass as grass
- import grass.script as gcore
-except ImportError :
- pass
import numpy as np
import scipy
import os.path
