[GRASS-SVN] r71021 - in grass-addons/grass7/raster: . r.vect.stats
svn_grass at osgeo.org
Thu May 4 19:48:20 PDT 2017
Author: wenzeslaus
Date: 2017-05-04 19:48:20 -0700 (Thu, 04 May 2017)
New Revision: 71021
Added:
grass-addons/grass7/raster/r.vect.stats/
grass-addons/grass7/raster/r.vect.stats/r.vect.stats.html
grass-addons/grass7/raster/r.vect.stats/r.vect.stats.py
Removed:
grass-addons/grass7/raster/r.binning/
grass-addons/grass7/raster/r.vect.stats/r.binning.html
grass-addons/grass7/raster/r.vect.stats/r.binning.py
grass-addons/grass7/raster/Makefile
grass-addons/grass7/raster/r.vect.stats/Makefile
rename r.binning to r.vect.stats
Modified: grass-addons/grass7/raster/Makefile
--- grass-addons/grass7/raster/Makefile 2017-05-04 08:40:45 UTC (rev 71020)
+++ grass-addons/grass7/raster/Makefile 2017-05-05 02:48:20 UTC (rev 71021)
@@ -17,7 +17,7 @@
r.agent \
r.area \
r.basin \
- r.binning \
+ r.vect.stats \
r.bioclim \
r.bitpattern \
r.catchment \
Modified: grass-addons/grass7/raster/r.vect.stats/Makefile
--- grass-addons/grass7/raster/r.binning/Makefile 2017-05-04 08:40:45 UTC (rev 71020)
+++ grass-addons/grass7/raster/r.vect.stats/Makefile 2017-05-05 02:48:20 UTC (rev 71021)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM=r.binning
+PGM=r.vect.stats
include $(MODULE_TOPDIR)/include/Make/Script.make
Deleted: grass-addons/grass7/raster/r.vect.stats/r.binning.html
--- grass-addons/grass7/raster/r.binning/r.binning.html 2017-05-04 08:40:45 UTC (rev 71020)
+++ grass-addons/grass7/raster/r.vect.stats/r.binning.html 2017-05-05 02:48:20 UTC (rev 71021)
@@ -1,34 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.binning</em> bins points from a vector map into a raster map.
-<p>
-Use <em><a href="g.region.html">g.region</a></em> to set the extent and
-resolution of the resulting raster.
-<h2>EXAMPLES</h2>
-Calculate for current region the beam irradiance (direct radiation)
-for DOY 355 in 2014 from 8am to 3pm:
-<div class="code"><pre>
-g.region vect=elev_lid792_bepts res=10
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.region.html">g.region</a>,
-<a href="r.in.xyz.html">r.in.xyz</a>,
-<a href="r.in.lidar.html">r.in.lidar</a>
-</em>
-<h2>AUTHOR</h2>
-Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
-<p>
-<i>Last changed: $Date: 2017-04-14 18:20:35 -0400 (Fri, 14 Apr 2017) $</i>
Deleted: grass-addons/grass7/raster/r.vect.stats/r.binning.py
--- grass-addons/grass7/raster/r.binning/r.binning.py 2017-05-04 08:40:45 UTC (rev 71020)
+++ grass-addons/grass7/raster/r.vect.stats/r.binning.py 2017-05-05 02:48:20 UTC (rev 71021)
@@ -1,52 +0,0 @@
-#!/usr/bin/env python
-# MODULE: r.binning
-# AUTHOR(S): Vaclav Petras <wenzeslaus gmail com>
-# PURPOSE:
-# COPYRIGHT: (C) 2017 by Vaclav Petras and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%module
-#% description: Bin vector points into a raster map
-#% keyword: raster
-#% keyword: vector
-#% keyword: points
-#% overwrite: yes
-#%end
-#%option G_OPT_V_INPUT
-#%end
-#%option G_OPT_R_OUTPUT
-#%end
-import grass.script as gs
-def main():
- options, flags = gs.parser()
- vector = options['input']
- layer = 1
- raster = options['output']
- method = 'mean'
- sep = 'pipe'
- out_process = gs.pipe_command(
- 'v.out.ascii', input=vector, layer=layer, format='point',
- separator=sep)
- in_process = gs.start_command(
- 'r.in.xyz', input='-', output=raster, method=method,
- separator=sep, stdin=out_process.stdout)
- in_process.communicate()
- out_process.wait()
-if __name__ == "__main__":
- main()
Copied: grass-addons/grass7/raster/r.vect.stats/r.vect.stats.html (from rev 71020, grass-addons/grass7/raster/r.binning/r.binning.html)
--- grass-addons/grass7/raster/r.vect.stats/r.vect.stats.html (rev 0)
+++ grass-addons/grass7/raster/r.vect.stats/r.vect.stats.html 2017-05-05 02:48:20 UTC (rev 71021)
@@ -0,0 +1,34 @@
+<h2>DESCRIPTION</h2>
+<em>r.vect.stats</em> bins points from a vector map into a raster map.
+<p>
+Use <em><a href="g.region.html">g.region</a></em> to set the extent and
+resolution of the resulting raster.
+<h2>EXAMPLES</h2>
+Calculate for current region the beam irradiance (direct radiation)
+for DOY 355 in 2014 from 8am to 3pm:
+<div class="code"><pre>
+g.region vect=elev_lid792_bepts res=10
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="g.region.html">g.region</a>,
+<a href="r.in.xyz.html">r.in.xyz</a>,
+<a href="r.in.lidar.html">r.in.lidar</a>
+</em>
+<h2>AUTHOR</h2>
+Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a>
+<p>
+<i>Last changed: $Date: 2017-04-14 18:20:35 -0400 (Fri, 14 Apr 2017) $</i>
Copied: grass-addons/grass7/raster/r.vect.stats/r.vect.stats.py (from rev 71020, grass-addons/grass7/raster/r.binning/r.binning.py)
--- grass-addons/grass7/raster/r.vect.stats/r.vect.stats.py (rev 0)
+++ grass-addons/grass7/raster/r.vect.stats/r.vect.stats.py 2017-05-05 02:48:20 UTC (rev 71021)
@@ -0,0 +1,53 @@
+#!/usr/bin/env python
+# MODULE: r.binning
+# AUTHOR(S): Vaclav Petras <wenzeslaus gmail com>
+# PURPOSE:
+# COPYRIGHT: (C) 2017 by Vaclav Petras and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Bin vector points into a raster map
+#% keyword: raster
+#% keyword: vector
+#% keyword: points
+#% keyword: binning
+#% overwrite: yes
+#%end
+#%option G_OPT_V_INPUT
+#%end
+#%option G_OPT_R_OUTPUT
+#%end
+import grass.script as gs
+def main():
+ options, flags = gs.parser()
+ vector = options['input']
+ layer = 1
+ raster = options['output']
+ method = 'mean'
+ sep = 'pipe'
+ out_process = gs.pipe_command(
+ 'v.out.ascii', input=vector, layer=layer, format='point',
+ separator=sep)
+ in_process = gs.start_command(
+ 'r.in.xyz', input='-', output=raster, method=method,
+ separator=sep, stdin=out_process.stdout)
+ in_process.communicate()
+ out_process.wait()
+if __name__ == "__main__":
+ main()
