[GRASS-SVN] r71095 - grass/branches/releasebranch_7_2/vector/v.surf.bspline
svn_grass at osgeo.org
Wed May 17 06:22:26 PDT 2017
Author: mlennert
Date: 2017-05-17 06:22:26 -0700 (Wed, 17 May 2017)
New Revision: 71095
grass/branches/releasebranch_7_2/vector/v.surf.bspline/main.c
grass/branches/releasebranch_7_2/vector/v.surf.bspline/v.surf.bspline.html
v.surf.bspline: document units used for step parameters (backport from trunk r71094)
Modified: grass/branches/releasebranch_7_2/vector/v.surf.bspline/main.c
--- grass/branches/releasebranch_7_2/vector/v.surf.bspline/main.c 2017-05-17 13:18:18 UTC (rev 71094)
+++ grass/branches/releasebranch_7_2/vector/v.surf.bspline/main.c 2017-05-17 13:22:26 UTC (rev 71095)
@@ -146,7 +146,7 @@
stepE_opt->required = NO;
stepE_opt->answer = "4";
stepE_opt->description =
- _("Length of each spline step in the east-west direction");
+ _("Length of each spline step (pixels) in the east-west direction");
stepE_opt->guisection = _("Settings");
stepN_opt = G_define_option();
@@ -155,7 +155,7 @@
stepN_opt->required = NO;
stepN_opt->answer = "4";
stepN_opt->description =
- _("Length of each spline step in the north-south direction");
+ _("Length of each spline step (pixels) in the north-south direction");
stepN_opt->guisection = _("Settings");
type_opt = G_define_option();
Modified: grass/branches/releasebranch_7_2/vector/v.surf.bspline/v.surf.bspline.html
--- grass/branches/releasebranch_7_2/vector/v.surf.bspline/v.surf.bspline.html 2017-05-17 13:18:18 UTC (rev 71094)
+++ grass/branches/releasebranch_7_2/vector/v.surf.bspline/v.surf.bspline.html 2017-05-17 13:22:26 UTC (rev 71095)
@@ -19,13 +19,13 @@
here, the splines are 2D piece-wise non-zero polynomial functions
calculated within a limited, 2D area. The length of each spline step
is defined by <b>ew_step</b> for the east-west direction and
-<b>ns_step</b> for the north-south direction. For optimal performance, the
-length of spline step should be no less than the distance between observation
-points. Each vector point observation is modeled as a linear function of the
-non-zero splines in the area around the observation. The least squares
-regression predicts the the coefficients of these linear functions.
-Regularization, avoids the need to have one observation and one
-coefficient for each spline (in order to avoid instability).
+<b>ns_step</b> for the north-south direction. Step is defined in number of
+pixels. For optimal performance, the length of spline step should be no less
+than the distance between observation points. Each vector point observation is
+modeled as a linear function of the non-zero splines in the area around the
+observation. The least squares regression predicts the the coefficients of these
+linear functions. Regularization, avoids the need to have one observation and
+one coefficient for each spline (in order to avoid instability).
<p>With regularly distributed data points, a spline step corresponding
to the maximum distance between two points in both the east and north
