[GRASS-SVN] r71096 - grass/branches/releasebranch_7_2/vector/v.in.ogr
Wed May 17 12:07:28 PDT 2017
Author: mmetz
Date: 2017-05-17 12:07:28 -0700 (Wed, 17 May 2017)
New Revision: 71096
   grass/branches/releasebranch_7_2/vector/v.in.ogr/dsn.c
   grass/branches/releasebranch_7_2/vector/v.in.ogr/main.c
v.in.ogr: disable OGR dsn corruption
Modified: grass/branches/releasebranch_7_2/vector/v.in.ogr/dsn.c
--- grass/branches/releasebranch_7_2/vector/v.in.ogr/dsn.c	2017-05-17 13:22:26 UTC (rev 71095)
+++ grass/branches/releasebranch_7_2/vector/v.in.ogr/dsn.c	2017-05-17 19:07:28 UTC (rev 71096)
@@ -7,7 +7,12 @@
 char *get_datasource_name(const char *opt_dsn, int use_ogr)
     char *dsn;
+    dsn = G_store(opt_dsn);
+    return dsn;
+    /* TODO: remove below code, or use it in e.g. a new v.in.pg */
     if (G_strncasecmp(opt_dsn, "PG:", 3) == 0) {
         /* PostgreSQL/PostGIS */
         size_t i;
Modified: grass/branches/releasebranch_7_2/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_7_2/vector/v.in.ogr/main.c	2017-05-17 13:22:26 UTC (rev 71095)
+++ grass/branches/releasebranch_7_2/vector/v.in.ogr/main.c	2017-05-17 19:07:28 UTC (rev 71096)
@@ -363,9 +363,11 @@
 	datetime_type = "datetime";
     dsn = NULL;
-    if (param.dsn->answer)
-        dsn = get_datasource_name(param.dsn->answer, TRUE);
+    if (param.dsn->answer) {
+        /* dsn = get_datasource_name(param.dsn->answer, TRUE); */
+	dsn = param.dsn->answer;
     min_area = atof(param.min_area->answer);
     snap = atof(param.snap->answer);
     type = Vect_option_to_types(param.type);
