[GRASS-SVN] r71145 - grass-addons/grass7/temporal/t.rast.what.aggr
svn_grass at osgeo.org
Fri May 26 04:52:54 PDT 2017
Author: veroandreo
Date: 2017-05-26 04:52:54 -0700 (Fri, 26 May 2017)
New Revision: 71145
Added:
grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.html
t.rast.what.aggr: added manual page
Added: grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.html
--- grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.html (rev 0)
+++ grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.html 2017-05-26 11:52:54 UTC (rev 71145)
@@ -0,0 +1,149 @@
+<h2>DESCRIPTION</h2>
+<em>t.rast.what.aggr</em> samples a space time raster dataset at points
+from a vector map and returns aggregated values either printing
+them to stdout or updating the attribute table. A single date
+for the aggregation can be provided with the option <em>date</em> or
+alteratively, different dates for each point in the vector map
+can be passed through the option <em>date_column</em>.
+Either <em>date</em> or <em>date_column</em> must be provided.
+The aggregation is done by default backwards in time starting from the
+date provided and with the <em>granularity</em> set. Alternatively, the
+data can be aggregated forward in time by using the <em>a</em> flag.
+By default, the output is printed to stdout. To write the output into
+the attribute table of the vector map, <em>u</em> flag must be set and
+the target column should be created beforehand
+(See <a href="v.db.addcolumn.html">v.db.addcolumn</a>).
+Alternatively, <em>c</em> flag creates the columns using the name of the
+space time raster dataset (strds) and the method(s) as column name(s).
+<h2>NOTES</h2>
+For <it>method=mode</it> the module requires
+<a href="https://www.scipy.org/scipylib/index.html">scipy</a>
+library to be installed.
+<h2>EXAMPLES</h2>
+Average NDVI for the previous 2 months starting from 2015-05-01
+(i.e.: date="2015-05-01") for all points in the vector map.
+<div class="code"><pre>
+t.rast.what.aggr input=GR_GSOM_stations strds=ndvi_16_5600m \
+ date=2015-05-01 granularity="2 months"
+1|2015-05-01|4480.0
+2|2015-05-01|5852.66666667
+3|2015-05-01|5683.33333333
+4|2015-05-01|4985.0
+</pre></div>
+Average, minimum and maximum NDVI for the previous 2 months starting
+from 2015-05-01 (i.e.: date="2015-05-01") for all points in the
+vector map.
+ date=2015-05-01 granularity="2 months" method=average,minimum,maximum
+1|2015-05-01|4480.0|4371.0|4545.0
+2|2015-05-01|5852.66666667|5618.0|6249.0
+3|2015-05-01|5683.33333333|5530.0|5955.0
+4|2015-05-01|4985.0|4820.0|5169.0
+</pre></div>
+Average NDVI for the previous 2 months, starting from different
+dates for each point in the vector map (i.e.: providing date_column).
+ granularity="2 months" date_column=fechas
+1|2015-01-01|*
+2|2015-02-01|5254.0
+3|2015-03-01|6023.66666667
+4|2015-04-01|4399.66666667
+</pre></div>
+Minimum and maximum NDVI for the previous 2 months, starting
+from different dates for each point in the vector map (i.e.: providing
+date_column).
+ date_column=fechas granularity="2 months" \
+ method=minimum,maximum
+1|2015-01-01|*|*
+2|2015-02-01|5254.0|5254.0
+3|2015-03-01|5944.0|6119.0
+4|2015-04-01|3786.0|4820.0
+</pre></div>
+Minimum and maximum NDVI for the 2 months after (i.e.: set -a flag)
+the date provided in <em>date_column</em>. Note that in this example the
+first point gets populated.
+t.rast.what.aggr -a input=GR_GSOM_stations date_column=fechas \
+ granularity="2 months" strds=ndvi_16_5600m method=minimum,maximum
+1|2015-01-01|3497.0|4280.0
+2|2015-02-01|4801.0|6249.0
+3|2015-03-01|5530.0|5955.0
+4|2015-04-01|5169.0|6390.0
+</pre></div>
+Minimum and maximum NDVI for the previous 2 months, starting from
+different dates for each point in the vector map (i.e.: providing
+date_column) and write the output into the vector atrribute's table.
+# create columns
+v.db.addcolumn map=GR_GSOM_stations column="ndvi_min double precision"
+v.db.addcolumn map=GR_GSOM_stations column="ndvi_max double precision"
+# write the aggregated values to the attribute table
+t.rast.what.aggr -u input=GR_GSOM_stations strds=ndvi_16_5600m \
+ date_column=fechas granularity="2 months" columns=ndvi_min,ndvi_max \
+# check the result
+v.db.select map=GR_GSOM_stations
+cat|station|name|long|lat|fechas|ndvi_min|ndvi_max
+1|GRE00105244|LAMIA|22.4|38.9|2015-01-01||
+2|GRE00105246|TANAGRA|23.53|38.32|2015-02-01|5254|5254
+3|GRE00105240|CHIOS|26.13|38.33|2015-03-01|5944|6119
+4|GRE00105242|FLORINA|21.4|40.78|2015-04-01|3786|4820
+</pre></div>
+Automatically create the columns and populate them with the aggregated values.
+t.rast.what.aggr -u -c input=GR_GSOM_stations date_column=fechas \
+cat|station|name|long|lat|fechas|ndvi_mean|ndvi_max|ndvi_16_5600m_minimum|ndvi_16_5600m_maximum
+1|GRE00105244|LAMIA|22.4|38.9|2015-01-01||||
+2|GRE00105246|TANAGRA|23.53|38.32|2015-02-01|5254|5254|5254|5254
+3|GRE00105240|CHIOS|26.13|38.33|2015-03-01|5944|6119|5944|6119
+4|GRE00105242|FLORINA|21.4|40.78|2015-04-01|3786|4820|3786|4820
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.what.html">r.what</a>,
+<a href="t.rast.what.html">t.rast.what</a>,
+<a href="t.rast.aggregate.html">t.rast.aggregate</a>
+</em>
+<p>
+<a href="https://grasswiki.osgeo.org/wiki/Temporal_data_processing">GRASS GIS Wiki: temporal data processing</a>
+<h2>AUTHOR</h2>
+Luca Delucchi
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/temporal/t.rast.what.aggr/t.rast.what.aggr.html
___________________________________________________________________
Added: svn:mime-type
+ text/html
Added: svn:keywords
+ Author Date Id
Added: svn:eol-style
+ native
