[GRASS-SVN] r71146 - in grass-addons/grass7/temporal/t.rast.what.aggr: . testsuite
Fri May 26 06:21:30 PDT 2017
Author: lucadelu
Date: 2017-05-26 06:21:30 -0700 (Fri, 26 May 2017)
New Revision: 71146
Added:
   grass-addons/grass7/temporal/t.rast.what.aggr/Makefile
   grass-addons/grass7/temporal/t.rast.what.aggr/testsuite/
   grass-addons/grass7/temporal/t.rast.what.aggr/testsuite/test_whataggr.py
t.rast.what.aggr: added Makefile and testsuite
Added: grass-addons/grass7/temporal/t.rast.what.aggr/Makefile
--- grass-addons/grass7/temporal/t.rast.what.aggr/Makefile	                        (rev 0)
+++ grass-addons/grass7/temporal/t.rast.what.aggr/Makefile	2017-05-26 13:21:30 UTC (rev 71146)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.rast.what.aggr
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Property changes on: grass-addons/grass7/temporal/t.rast.what.aggr/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/temporal/t.rast.what.aggr/testsuite/test_whataggr.py
--- grass-addons/grass7/temporal/t.rast.what.aggr/testsuite/test_whataggr.py	                        (rev 0)
+++ grass-addons/grass7/temporal/t.rast.what.aggr/testsuite/test_whataggr.py	2017-05-26 13:21:30 UTC (rev 71146)
@@ -0,0 +1,171 @@
+"""Test t.rast.whatcsv
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+from grass.gunittest.case import TestCase
+from grass.gunittest.gmodules import SimpleModule
+class TestRasterWhatAggr(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Initiate the temporal GIS and set the region
+        cls.use_temp_region()
+        cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50, res=10,
+                      res3=10)
+        cls.runModule("r.mapcalc", expression="a_1 = 100", overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_2 = 200", overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_3 = 300", overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_4 = 400", overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_5 = 500", overwrite=True)
+        cls.runModule("r.mapcalc", expression="a_6 = 600", overwrite=True)
+        cls.runModule("v.random", output="points", npoints=3, seed=1,
+                      overwrite=True)
+        cls.runModule("v.db.addtable", map="points")
+        cls.runModule("v.db.addcolumn", map="points", columns="data date")
+        cls.runModule("v.db.update", map="points", column="data",
+                      value="2001-05-10", where="cat=1")
+                      value="2001-04-08", where="cat=2")
+                      value="2001-06-01", where="cat=3")
+        cls.runModule("t.create", type="strds", temporaltype="absolute",
+                      output="A",  title="A test", description="A test",
+                      overwrite=True)
+        cls.runModule("t.register", flags="i", type="raster", input="A",
+                      maps="a_1,a_2,a_3,a_4,a_5,a_6", start="2001-01-01",
+                      increment="1 months", overwrite=True)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region
+        cls.runModule("t.remove", flags="rf", type="strds", inputs="A")
+        cls.del_temp_region()
+    def test_simple(self):
+        """Simpler test"""
+        t_rast_what = SimpleModule("t.rast.what.aggr", strds="A",
+                                   input="points", date="2001-04-01",
+                                   granularity="2 months", overwrite=True,
+                                   verbose=True)
+        self.assertModule(t_rast_what)
+        text="""1|2001-04-01|200.0
+2|2001-04-01|200.0
+3|2001-04-01|200.0
+        self.assertLooksLike(text, t_rast_what.outputs.stdout)
+    def test_aflag(self):
+        """Testing a flag"""
+        t_rast_what = SimpleModule("t.rast.what.aggr", strds="A", flags='a',
+                                   verbose=True)
+        text="""1|2001-04-01|400.0
+2|2001-04-01|400.0
+3|2001-04-01|400.0
+    def test_cflag(self):
+        """Testing c flag"""
+        self.assertModule(SimpleModule("t.rast.what.aggr", flags="c",
+                                       strds="A", input="points",
+                                       date="2001-04-01", verbose=True,
+                                       granularity="2 months", overwrite=True))
+        dbcols = SimpleModule("db.columns", table="points")
+        self.assertModule(dbcols)
+        text="""cat
+data
+A_average
+        self.assertLooksLike(text, dbcols.outputs.stdout)
+        dbvals = SimpleModule("v.db.select", map="points")
+        self.assertModule(dbvals)
+        text="""cat|data|A_average
+1|2001-05-10|200
+2|2001-04-08|200
+3|2001-06-01|200
+        self.assertLooksLike(text, dbvals.outputs.stdout)
+    def test_methods(self):
+        """Testing more methods in a single query"""
+                                   input="points", date="2001-05-01",
+                                   granularity="3 months", overwrite=True,
+                                   method=["minimum","maximum"], verbose=True)
+        text="""1|2001-05-01|200.0|300.0
+2|2001-05-01|200.0|300.0
+3|2001-05-01|200.0|300.0
+    def test_date_column(self):
+        """Testing date_column option"""
+                                   input="points", date_column="data",
+                                   verbose=True)
+        text="""2|2001-04-08|250.0
+1|2001-05-10|350.0
+3|2001-06-01|400.0
+    def test_date_format(self):
+                                   input="points", date="2001/05/01",
+                                   method=["minimum","maximum"], verbose=True,
+                                   date_format="%Y/%m/%d")
+        text="""1|2001/05/01|200.0|300.0
+2|2001/05/01|200.0|300.0
+3|2001/05/01|200.0|300.0
+class TestRasterWhatFails(TestCase):
+    def test_error_handling(self):
+        # No vector map, no strds, no coordinates
+        self.assertModuleFail("t.rast.what.aggr", output="out.txt")
+        # No vector map, no coordinates
+        self.assertModuleFail("t.rast.what.aggr", strds="A", output="out.txt")
+        # c flag and columns are mutually exclusive
+        self.assertModuleFail("t.rast.what.aggr", flags="c",
+                              strds="A", input="points", columns="average",
+        # u flag and columns are mutually exclusive
+        self.assertModuleFail("t.rast.what.aggr", flags="u", strds="A",
+                              input="points", columns="average", verbose=True,
+                              date="2001-04-01", granularity="2 months",
+                              overwrite=True)
+if __name__ == '__main__':
+    from grass.gunittest.main import test
+    test()
Property changes on: grass-addons/grass7/temporal/t.rast.what.aggr/testsuite/test_whataggr.py
   + text/x-python
   + native
