[GRASS-SVN] r71728 - grass/branches/releasebranch_7_4/lib/init
svn_grass at osgeo.org
Mon Nov 13 00:53:46 PST 2017
Author: veroandreo
Date: 2017-11-13 00:53:46 -0800 (Mon, 13 Nov 2017)
New Revision: 71728
Added:
grass/branches/releasebranch_7_4/lib/init/circle_6.png
grass/branches/releasebranch_7_4/lib/init/circle_1.png
grass/branches/releasebranch_7_4/lib/init/circle_2.png
grass/branches/releasebranch_7_4/lib/init/circle_3.png
grass/branches/releasebranch_7_4/lib/init/circle_4.png
grass/branches/releasebranch_7_4/lib/init/circle_5.png
grass/branches/releasebranch_7_4/lib/init/grass_start.png
grass/branches/releasebranch_7_4/lib/init/helptext.html
lib/init/helptext: start-up screen fig updated and Download button explained, trunk r71726
Modified: grass/branches/releasebranch_7_4/lib/init/circle_1.png
(Binary files differ)
Modified: grass/branches/releasebranch_7_4/lib/init/circle_2.png
Modified: grass/branches/releasebranch_7_4/lib/init/circle_3.png
Modified: grass/branches/releasebranch_7_4/lib/init/circle_4.png
Modified: grass/branches/releasebranch_7_4/lib/init/circle_5.png
Added: grass/branches/releasebranch_7_4/lib/init/circle_6.png
Property changes on: grass/branches/releasebranch_7_4/lib/init/circle_6.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
Modified: grass/branches/releasebranch_7_4/lib/init/grass_start.png
Modified: grass/branches/releasebranch_7_4/lib/init/helptext.html
--- grass/branches/releasebranch_7_4/lib/init/helptext.html 2017-11-13 08:05:04 UTC (rev 71727)
+++ grass/branches/releasebranch_7_4/lib/init/helptext.html 2017-11-13 08:53:46 UTC (rev 71728)
@@ -42,6 +42,9 @@
easily create a new LOCATION from scratch from a geocoded file, by
defining the parameters or by selecting the corresponding EPSG projection
code.
+<p>
+See <img src="circle_5.png" alt="[(5)]"> to directly download a
+sample LOCATION into the DATABASE.
<h3><img src="circle_3.png" alt="[(3)]"> Selecting the MAPSET (a subproject)</h3>
@@ -58,8 +61,16 @@
data file (e.g., SHAPE file or GeoTIFF, see below). Find below also some
rules to define the default raster resolution for a new LOCATION.
-<h3><img src="circle_5.png" alt="[(5)]"> Start GRASS</h3>
+<h3><img src="circle_5.png" alt="[(5)]"> Download a sample LOCATION</h3>
+In the "Location Wizard" there is also a Download button that allows you to
+directly download a ready-to-use LOCATION into the DATABASE. You can
+choose among different sample LOCATIONS that are currently available at the
+<a href="https://grass.osgeo.org/download/sample-data/">Download</a>
+section in the GRASS GIS website.
+<h3><img src="circle_6.png" alt="[(6)]"> Start GRASS</h3>
Once you have selected an existing LOCATION/MAPSET or defined a new
one, you can enter GRASS. The graphical user interface
<a href="wxGUI.html">wxGUI</a> will open and provide you with a
