[GRASS-SVN] r71729 - in grass/trunk: gui/wxpython/gui_core lib/init
svn_grass at osgeo.org
Mon Nov 13 02:46:57 PST 2017
Author: marisn
Date: 2017-11-13 02:46:57 -0800 (Mon, 13 Nov 2017)
New Revision: 71729
grass/trunk/gui/wxpython/gui_core/preferences.py
grass/trunk/lib/init/grass.py
Try to use some of en_XX locales for en language.
As a failback, consider C.UTF-8 and only then plain C locale.
Attempts to fix #3441.
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2017-11-13 08:53:46 UTC (rev 71728)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2017-11-13 10:46:57 UTC (rev 71729)
@@ -190,15 +190,6 @@
subkey='lc_all',
value=None)
lang = None
- if lang == 'en':
- # GRASS doesn't ship EN translation, default texts have to be
- # used instead
- self.settings.Set(
- group='language',
- key='locale',
- subkey='lc_all',
- value='C')
- lang = 'C'
self.settings.SaveToFile()
Debug.msg(
1, "Settings saved to file '%s'" %
@@ -570,6 +561,7 @@
choices=locales, name="GetStringSelection")
if loc in locales:
elementList.SetStringSelection(loc)
+ # Keep this check, as in older wx files C value instead of en might be present
if loc == 'C':
elementList.SetStringSelection('en')
if not loc:
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2017-11-13 08:53:46 UTC (rev 71728)
+++ grass/trunk/lib/init/grass.py 2017-11-13 10:46:57 UTC (rev 71729)
@@ -1117,6 +1117,10 @@
language = ''.join(line.split(';')[-1:])
break
fd.close()
+ # Backwards compatability with old wx preferences files
+ if language == 'C':
+ language = 'en'
if language == 'None' or language == '' or not language:
# Language override is disabled (system language specified)
@@ -1128,16 +1132,16 @@
# If we get here, system locale settings are terribly wrong
# There is no point to continue as GRASS/Python will fail
# in some other unpredictable way.
- print("System locale is not usable (LC_ALL variable not defined). "
- "It indicates misconfigured environment.")
- print("Reported error message: %s" % e)
+ sys.stderr.write("System locale is not usable (LC_ALL variable not defined). "
+ "Most likely it indicates misconfigured environment.\n")
+ sys.stderr.write("Reported error message: %s\n" % e)
## TOO DRASTIC: sys.exit("Fix system locale settings and then try again.")
locale.setlocale(locale.LC_ALL, 'C')
- warning(_("Default locale settings are missing. GRASS running with C locale."))
+ sys.stderr.write("Default locale settings are missing. GRASS running with C locale.")
language, encoding = locale.getdefaultlocale()
if not language:
return
else:
@@ -1155,22 +1159,49 @@
normalized = locale.normalize('%s.%s' % (language, encoding))
locale.setlocale(locale.LC_ALL, normalized)
except locale.Error as e:
- # The last attempt...
- try:
- encoding = locale.getpreferredencoding()
- normalized = locale.normalize('%s.%s' % (language, encoding))
- locale.setlocale(locale.LC_ALL, normalized)
- except locale.Error as e:
- # If we got so far, attempts to set up language and locale have failed
- # on this system
- sys.stderr.write("Failed to enforce user specified language '%s' with error: '%s'\n" % (language, e))
- sys.stderr.write("A LANGUAGE environmental variable has been set.\nPart of messages will be displayed in the requested language.\n")
- # Even if setting locale will fail, let's set LANG in a hope,
- # that UI will use it GRASS texts will be in selected language,
- # system messages (i.e. OK, Cancel etc.) - in system default
- # language
- os.environ['LANGUAGE'] = language
- return
+ if language == 'en':
+ # en_US locale might be missing, still all messages in
+ # GRASS are already in en_US language.
+ # Using plain C as locale forces encodings to ascii
+ # thus lets try our luck with C.UTF-8 first.
+ # See bugs #3441 and #3423
+ try:
+ locale.setlocale(locale.LC_ALL, 'C.UTF-8')
+ except locale.Error as e:
+ # All lost. Setting to C as much as possible.
+ # We can not call locale.normalize on C as it
+ # will transform it to en_US and we already know
+ # it doesn't work.
+ locale.setlocale(locale.LC_ALL, 'C')
+ os.environ['LANGUAGE'] = 'C'
+ os.environ['LANG'] = 'C'
+ os.environ['LC_MESSAGES'] = 'C'
+ os.environ['LC_NUMERIC'] = 'C'
+ os.environ['LC_TIME'] = 'C'
+ gettext.install('grasslibs', gpath('locale'))
+ sys.stderr.write("All attempts to enable English language have failed. "
+ "GRASS running with C locale.\n"
+ "If you observe UnicodeError in Python, install en_US.UTF-8 "
+ "locale and restart GRASS.\n")
+ return
+ else:
+ # The last attempt...
+ try:
+ encoding = locale.getpreferredencoding()
+ normalized = locale.normalize('%s.%s' % (language, encoding))
+ locale.setlocale(locale.LC_ALL, normalized)
+ # If we got so far, attempts to set up language and locale have failed
+ # on this system
+ sys.stderr.write("Failed to enforce user specified language '%s' with error: '%s'\n" % (language, e))
+ sys.stderr.write("A LANGUAGE environmental variable has been set.\nPart of messages will be displayed in the requested language.\n")
+ # Even if setting locale will fail, let's set LANG in a hope,
+ # that UI will use it GRASS texts will be in selected language,
+ # system messages (i.e. OK, Cancel etc.) - in system default
+ # language
+ os.environ['LANGUAGE'] = language
+ os.environ['LANG'] = language
+ return
# Set up environment for subprocesses
