[GRASS-SVN] r71837 - grass-addons/grass7/raster/r.fill.gaps
svn_grass at osgeo.org
Sat Nov 25 19:00:40 PST 2017
Author: annakrat
Date: 2017-11-25 19:00:40 -0800 (Sat, 25 Nov 2017)
New Revision: 71837
grass-addons/grass7/raster/r.fill.gaps/main.c
r.fill.gaps: fix bug in median and mode computation, remove unused variables
Modified: grass-addons/grass7/raster/r.fill.gaps/main.c
--- grass-addons/grass7/raster/r.fill.gaps/main.c 2017-11-26 01:38:25 UTC (rev 71836)
+++ grass-addons/grass7/raster/r.fill.gaps/main.c 2017-11-26 03:00:40 UTC (rev 71837)
@@ -240,8 +240,6 @@
void collect_values_filtered(double val1, double val2, double min, double max,
stats_struct * stats)
- unsigned long i;
if (val1 >= min && val1 <= max) {
collect_values_unfiltered(val1, val2, min, max, stats);
@@ -260,8 +258,6 @@
void collect_values_and_weights_filtered(double val1, double val2, double min,
double max, stats_struct * stats)
- unsigned long i;
collect_values_and_weights_unfiltered(val1, val2, min, max, stats);
@@ -272,7 +268,6 @@
unsigned long i;
- int done;
stats->certainty += val2;
@@ -305,8 +300,6 @@
- unsigned long i;
collect_values_and_frequencies_unfiltered(val1, val2, min, max,
stats);
@@ -449,15 +442,15 @@
/* sort list of values */
qsort(&stats->values[0], stats->num_values, sizeof(double), &compare_dbl);
- if ((double)stats->num_values / 2.0 == 0.0) {
+ if (stats->num_values % 2 == 0.0) {
/* even number of elements: result is average of the two central values */
stats->result =
- (stats->values[stats->num_values / 2] +
- stats->values[(stats->num_values / 2) + 1]) / 2.0;
+ (stats->values[stats->num_values / 2 - 1] +
+ stats->values[(stats->num_values / 2)]) / 2.0;
else {
/* odd number of elements: result is the central element */
- stats->result = stats->values[(stats->num_values / 2) + 1];
+ stats->result = stats->values[(stats->num_values / 2)];
@@ -491,6 +484,9 @@
stats->result = mode;
+ /* need to initialize, otherwise old values sometimes stay */
+ for (i = 0; i < WINDOW_WIDTH * WINDOW_HEIGHT; i++)
+ stats->frequencies[i] = 0;
@@ -566,7 +562,7 @@
stats_struct * stats, int write_err)
unsigned long j;
- void *cell_input, *cell_output;
+ void *cell_output;
FCELL *err_output;
cell_output = CELL_OUTPUT;
@@ -747,7 +743,6 @@
char *input;
char *output;
char *mapset;
- char *error;
double radius = 1.0;
unsigned long min_cells = 12;
double power = 2.0;
@@ -759,7 +754,6 @@
/* file handlers */
void *cell_input;
- void *cell_output;
int in_fd;
int out_fd;
int err_fd;
@@ -768,9 +762,8 @@
stats_struct cell_stats;
/* generic indices, loop counters, etc. */
- unsigned long i, j, k;
+ unsigned long i, j;
long l;
- unsigned long count;
start = time(NULL);
