[GRASS-SVN] r71838 - grass/trunk/locale
svn_grass at osgeo.org
Sat Nov 25 19:17:27 PST 2017
Author: wenzeslaus
Date: 2017-11-25 19:17:27 -0800 (Sat, 25 Nov 2017)
New Revision: 71838
grass/trunk/locale/grass_po_stats.py
fix most obvious Python 3 compatibility issues: tabs, has_key, print in po script (see #2708)
Modified: grass/trunk/locale/grass_po_stats.py
--- grass/trunk/locale/grass_po_stats.py 2017-11-26 03:00:40 UTC (rev 71837)
+++ grass/trunk/locale/grass_po_stats.py 2017-11-26 03:17:27 UTC (rev 71838)
@@ -14,6 +14,8 @@
+from __future__ import print_function
import os, sys
import subprocess
import json
@@ -33,7 +35,7 @@
lang = lang[0].split('.')[0]
# if keys is not in languages add it and the file's name
- if not languages.has_key(lang):
+ if lang not in languages:
languages[lang] = [pofile,]
# add only files name
else:
@@ -112,7 +114,7 @@
# check if some errors occurs
if msg.find('error') != -1:
# TODO CHECK IF grass.warning()
- print "WARNING: file <%s> has some problems: <%s>" % (flang, msg)
+ print("WARNING: file <%s> has some problems: <%s>" % (flang, msg))
continue
output['langs'][lang][fpref], lgood, lfuzzy, lbad = \
read_msgfmt_statistics(msg, lgood, lfuzzy, lbad)
@@ -137,7 +139,7 @@
try:
os.remove("messages.mo")
except:
- pass
+ pass
def main(in_dirpath, out_josonpath):
languages = read_po_files(in_dirpath)
