[GRASS-SVN] r71542 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Sat Oct 7 23:45:15 PDT 2017
Author: neteler
Date: 2017-10-07 23:45:15 -0700 (Sat, 07 Oct 2017)
New Revision: 71542
grass/trunk/vector/v.in.ogr/v.in.ogr.html
v.in.ogr manual: add link to osmconf.ini
Modified: grass/trunk/vector/v.in.ogr/v.in.ogr.html
--- grass/trunk/vector/v.in.ogr/v.in.ogr.html 2017-10-08 06:35:32 UTC (rev 71541)
+++ grass/trunk/vector/v.in.ogr/v.in.ogr.html 2017-10-08 06:45:15 UTC (rev 71542)
@@ -323,8 +323,8 @@
<p>
Import of OSM data requires a configuration file, defined with the
OSM_CONFIG_FILE configuration option. In the data folder of the GDAL
-distribution, you can find a osmconf.ini file that can be customized to
-fit your needs. See
+distribution, you can find a <a href="https://svn.osgeo.org/gdal/trunk/gdal/data/osmconf.ini">osmconf.ini file</a>
+that can be customized to fit your needs. See
<a href="http://wiki.openstreetmap.org/wiki/Map_Features">OSM map features</a>
for keys and their values. You should set "other_tags=no" to
avoid problems with import or querying the imported vector. Once a
