[GRASS-SVN] r71543 - grass/trunk/vector/v.vect.stats
svn_grass at osgeo.org
Sun Oct 8 13:04:49 PDT 2017
Author: mmetz
Date: 2017-10-08 13:04:49 -0700 (Sun, 08 Oct 2017)
New Revision: 71543
grass/trunk/vector/v.vect.stats/main.c
v.vect.stats: add cats and where options for area and point input selection (#3420)
Modified: grass/trunk/vector/v.vect.stats/main.c
--- grass/trunk/vector/v.vect.stats/main.c 2017-10-08 06:45:15 UTC (rev 71542)
+++ grass/trunk/vector/v.vect.stats/main.c 2017-10-08 20:04:49 UTC (rev 71543)
@@ -82,7 +82,11 @@
*area_opt, /* area vector */
*point_type_opt, /* point type */
*point_field_opt, /* point layer */
+ *point_cats_opt, /* point cats */
+ *point_where_opt, /* point where */
*area_field_opt, /* area layer */
+ *area_cats_opt, /* area cats */
+ *area_where_opt, /* area where */
*method_opt, /* stats method */
*point_column_opt, /* point column for stats */
*count_column_opt, /* area column for point count */
@@ -92,6 +96,8 @@
char *fs;
struct Map_info PIn, AIn;
int point_type, point_field, area_field;
+ struct cat_list *acat_list = NULL;
+ struct cat_list *pcat_list = NULL;
struct line_pnts *Points;
struct line_cats *ACats, *PCats;
AREA_CAT *Area_cat;
@@ -148,11 +154,33 @@
point_field_opt = G_define_standard_option(G_OPT_V_FIELD);
point_field_opt->key = "points_layer";
point_field_opt->label = _("Layer number for points map");
+ point_field_opt->guisection = _("Selection");
+ point_cats_opt = G_define_standard_option(G_OPT_V_CATS);
+ point_cats_opt->key = "points_cats";
+ point_cats_opt->label = _("Category values for points map");
+ point_cats_opt->guisection = _("Selection");
+ point_where_opt = G_define_standard_option(G_OPT_DB_WHERE);
+ point_where_opt->key = "points_where";
+ point_where_opt->label = _("WHERE conditions of SQL statement without 'where' keyword for points map");;
+ point_where_opt->guisection = _("Selection");
area_field_opt = G_define_standard_option(G_OPT_V_FIELD);
area_field_opt->key = "areas_layer";
area_field_opt->label = _("Layer number for area map");
+ area_field_opt->guisection = _("Selection");
+ area_cats_opt = G_define_standard_option(G_OPT_V_CATS);
+ area_cats_opt->key = "areas_cats";
+ area_cats_opt->label = _("Category values for area map");
+ area_cats_opt->guisection = _("Selection");
+ area_where_opt = G_define_standard_option(G_OPT_DB_WHERE);
+ area_where_opt->key = "areas_where";
+ area_where_opt->label = _("WHERE conditions of SQL statement without 'where' keyword for area map");;
+ area_opt->guisection = _("Selection");
method_opt = G_define_option();
method_opt->key = "method";
method_opt->type = TYPE_STRING;
@@ -208,14 +236,11 @@
point_type = Vect_option_to_types(point_type_opt);
- point_field = atoi(point_field_opt->answer);
- area_field = atoi(area_field_opt->answer);
- if (print_flag->answer)
+ fs = NULL;
+ if (print_flag->answer) {
/* get field separator */
- fs = G_option_to_separator(fs_opt);
- else
- fs = NULL;
+ fs = G_option_to_separator(fs_opt);
/* check for stats */
if (method_opt->answer) {
@@ -252,6 +277,20 @@
if (Vect_open_old(&AIn, area_opt->answer, mapset) < 0)
G_fatal_error(_("Unable to open vector map <%s>"), area_opt->answer);
+ point_field = atoi(point_field_opt->answer);
+ pcat_list = NULL;
+ if (point_field > 0)
+ pcat_list = Vect_cats_set_constraint(&PIn, point_field,
+ point_where_opt->answer,
+ point_cats_opt->answer);
+ area_field = atoi(area_field_opt->answer);
+ acat_list = NULL;
+ if (area_field > 0)
+ acat_list = Vect_cats_set_constraint(&AIn, area_field,
+ area_where_opt->answer,
+ area_cats_opt->answer);
method = -1;
use_catno = 0;
@@ -426,6 +465,11 @@
if (ACats->n_cats <= 0)
continue;
+ && !Vect_cats_in_constraint(ACats, area_field, acat_list))
+ continue;
for (i = 0; i < ACats->n_cats; i++) {
if (ACats->field[i] == area_field) {
@@ -489,6 +533,10 @@
continue;
+ continue;
/* select points by box */
Vect_get_area_box(&AIn, area, &box);
box.T = PORT_DOUBLE_MAX;
@@ -507,6 +555,10 @@
if (!(ptype & point_type))
continue;
+ && !Vect_cats_in_constraint(PCats, point_field, pcat_list))
+ continue;
/* point in area */
if (Vect_point_in_area(Points->x[0], Points->y[0], &AIn, area, &box)) {
AREA_CAT *area_info, search_ai;
