[GRASS-SVN] r72613 - grass-addons/grass7/raster/r.subdayprecip.design
svn_grass at osgeo.org
Tue Apr 10 02:48:14 PDT 2018
Author: martinl
Date: 2018-04-10 02:48:14 -0700 (Tue, 10 Apr 2018)
New Revision: 72613
grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html
grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
r.subdayprecip.design: implement reduction for large areas
Modified: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html 2018-04-09 17:24:56 UTC (rev 72612)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html 2018-04-10 09:48:14 UTC (rev 72613)
@@ -14,6 +14,18 @@
<h2>NOTES</h2>
+By default areas above <b>area_size</b> limit are not processed
+(calculated value is set to -1 in such case). Processing of large
+areas can be enabled by specifying <b>-k</b> flag. In this case calculated
+avarage value for large areas is reduced by coefficient below.
+<pre>
+ k = exp(-0.08515989 * (x^2) - 0.001344925 * (x^4))
+ where x = log10(area_size_km2) - 0.9
+</pre>
+<p>
Subday design precipitation series are important for hydrological
modelling and soil erosion problems in a small catchment scale when
designing common measures for promoting water retention, landscape
Modified: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py 2018-04-09 17:24:56 UTC (rev 72612)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py 2018-04-10 09:48:14 UTC (rev 72613)
@@ -8,7 +8,7 @@
# PURPOSE: Computes subday design precipitation totals.
-# COPYRIGHT: (C) 2015 Martin Landa and GRASS development team
+# COPYRIGHT: (C) 2015-2018 Martin Landa and GRASS development team
# This program is free software under the GNU General
# Public License (>=v2). Read the file COPYING that
@@ -24,12 +24,12 @@
#%end
#%option G_OPT_V_MAP
-#% label: Vector map of location under analysis
+#% label: Name of input vector map of location under analysis
#%end
#%option G_OPT_R_INPUTS
#% key: return_period
-#% description: Rainfall raster maps of required return period
+#% description: Name of input rainfall raster maps of required return period
#% options: N2,N5,N10,N20,N50,N100
#%end
@@ -48,11 +48,18 @@
#% answer: 20
#%end
+#%flag
+#% key: k
+#% description: Process also large areas above area_size limit by applying reduction
+#%end
import os
import sys
+import math
import grass.script as grass
from grass.pygrass.modules import Module
+from grass.pygrass.vector import VectorTopo
from grass.exceptions import CalledModuleError
def coeff(name, rl):
@@ -120,6 +127,22 @@
return a, c
+def area_size_reduction(map_name, field_name, area_col_name):
+ vmap = VectorTopo(map_name)
+ vmap.open('rw')
+ cats = [] # TODO: do it better
+ for feat in vmap.viter('areas'):
+ if feat.attrs['cat'] not in cats:
+ x = math.log10(float(feat.attrs[area_col_name]) )- 0.9
+ k = math.exp(-0.08515989 * pow(x, 2) - 0.001344925 * pow(x, 4))
+ feat.attrs[field_name] *= k
+ cats.append(feat.attrs['cat'])
+ vmap.table.conn.commit()
+ vmap.close()
def main():
# check if the map is in the current mapset
mapset = grass.find_file(opt['map'], element='vector')['mapset']
@@ -151,7 +174,7 @@
where='{} > {}'.format(area_col_name, opt['area_size']),
stdout_=grass.PIPE)
large_areas = len(areas.outputs.stdout.splitlines())
- if large_areas > 0:
+ if large_areas > 0 and not flg['k']:
grass.warning('{} areas larger than size limit will be skipped from computation'.format(large_areas))
# extract multi values to points
@@ -208,9 +231,15 @@
column=field_name, query_column=expression)
if check_area_size:
- Module('v.db.update', map=opt['map'],
- column=field_name, value='-1',
- where='{} > {}'.format(area_col_name, opt['area_size']))
+ args = {}
+ if flg['k']:
+ area_size_reduction(opt['map'], field_name, area_col_name)
+ else:
+ Module('v.db.update', map=opt['map'],
+ column=field_name,
+ value='-1',
+ where='{} > {}'.format(area_col_name, opt['area_size']),
+ **args)
# remove unused column
Module('v.db.dropcolumn', map=opt['map'],
