[GRASS-SVN] r72614 - grass-addons/grass7/raster/r.subdayprecip.design
svn_grass at osgeo.org
Tue Apr 10 05:01:09 PDT 2018
Author: martinl
Date: 2018-04-10 05:01:08 -0700 (Tue, 10 Apr 2018)
New Revision: 72614
grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html
grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
r.subdayprecip.design: rename -k to -r flag
Modified: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html 2018-04-10 09:48:14 UTC (rev 72613)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.html 2018-04-10 12:01:08 UTC (rev 72614)
@@ -16,7 +16,7 @@
By default areas above <b>area_size</b> limit are not processed
(calculated value is set to -1 in such case). Processing of large
-areas can be enabled by specifying <b>-k</b> flag. In this case calculated
+areas can be enabled by specifying <b>-r</b> flag. In this case calculated
avarage value for large areas is reduced by coefficient below.
<pre>
Modified: grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py
--- grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py 2018-04-10 09:48:14 UTC (rev 72613)
+++ grass-addons/grass7/raster/r.subdayprecip.design/r.subdayprecip.design.py 2018-04-10 12:01:08 UTC (rev 72614)
@@ -49,8 +49,8 @@
#%end
#%flag
-#% key: k
-#% description: Process also large areas above area_size limit by applying reduction
+#% key: r
+#% description: Process also large areas above area_size limit by applying a reduction
#%end
import os
@@ -134,6 +134,8 @@
cats = [] # TODO: do it better
for feat in vmap.viter('areas'):
+ if not feat.attrs[field_name]:
+ continue
if feat.attrs['cat'] not in cats:
x = math.log10(float(feat.attrs[area_col_name]) )- 0.9
k = math.exp(-0.08515989 * pow(x, 2) - 0.001344925 * pow(x, 4))
@@ -174,7 +176,7 @@
where='{} > {}'.format(area_col_name, opt['area_size']),
stdout_=grass.PIPE)
large_areas = len(areas.outputs.stdout.splitlines())
- if large_areas > 0 and not flg['k']:
+ if large_areas > 0 and not flg['r']:
grass.warning('{} areas larger than size limit will be skipped from computation'.format(large_areas))
# extract multi values to points
@@ -232,7 +234,7 @@
if check_area_size:
args = {}
- if flg['k']:
+ if flg['r']:
area_size_reduction(opt['map'], field_name, area_col_name)
else:
Module('v.db.update', map=opt['map'],
