[GRASS-SVN] r73041 - grass/branches/releasebranch_7_4/scripts/v.db.addtable
svn_grass at osgeo.org
Fri Aug 3 14:23:24 PDT 2018
Author: mmetz
Date: 2018-08-03 14:23:24 -0700 (Fri, 03 Aug 2018)
New Revision: 73041
grass/branches/releasebranch_7_4/scripts/v.db.addtable/v.db.addtable.py
v.db.addtable: create unique index (backport trunk r72945)
Modified: grass/branches/releasebranch_7_4/scripts/v.db.addtable/v.db.addtable.py
--- grass/branches/releasebranch_7_4/scripts/v.db.addtable/v.db.addtable.py 2018-08-03 21:20:28 UTC (rev 73040)
+++ grass/branches/releasebranch_7_4/scripts/v.db.addtable/v.db.addtable.py 2018-08-03 21:23:24 UTC (rev 73041)
@@ -6,6 +6,7 @@
# AUTHOR(S): Markus Neteler
# Converted to Python by Glynn Clements
# Key column added by Martin Landa <landa.martin gmail.com>
+# Table index added by Markus Metz
# PURPOSE: interface to db.execute to creates and add a new table to given vector map
# COPYRIGHT: (C) 2005, 2007, 2008, 2011 by Markus Neteler & the GRASS Development Team
@@ -136,6 +137,16 @@
except CalledModuleError:
grass.fatal(_("Unable to create table <%s>") % table)
+ # create index, see db/driver/*/index.c
+ if driver != "dbf":
+ sql = "CREATE UNIQUE INDEX %s_%s ON %s (%s)" % (table, key, table, key)
+ try:
+ grass.run_command('db.execute',
+ database=database, driver=driver, sql=sql)
+ except:
+ grass.warning(_("Unable to create index on table <%s>") % table)
+ pass
# connect the map to the DB:
if schema:
table = '{schema}.{table}'.format(schema=schema, table=table)
