[GRASS-SVN] r73042 - grass/branches/releasebranch_7_4/vector/v.external
svn_grass at osgeo.org
Fri Aug 3 14:42:41 PDT 2018
Author: mmetz
Date: 2018-08-03 14:42:41 -0700 (Fri, 03 Aug 2018)
New Revision: 73042
grass/branches/releasebranch_7_4/vector/v.external/dsn.c
grass/branches/releasebranch_7_4/vector/v.external/main.c
v.external: OGR dsn and GRASS db connections are independent of each other (backport trunk r72979)
Modified: grass/branches/releasebranch_7_4/vector/v.external/dsn.c
--- grass/branches/releasebranch_7_4/vector/v.external/dsn.c 2018-08-03 21:23:24 UTC (rev 73041)
+++ grass/branches/releasebranch_7_4/vector/v.external/dsn.c 2018-08-03 21:42:41 UTC (rev 73042)
@@ -8,6 +8,12 @@
char *dsn;
+ dsn = G_store(opt_dsn);
+ return dsn;
+ /* OGR dsn and GRASS db connections are independent of each other */
if (G_strncasecmp(opt_dsn, "PG:", 3) == 0) {
/* PostgreSQL/PostGIS */
size_t i;
Modified: grass/branches/releasebranch_7_4/vector/v.external/main.c
--- grass/branches/releasebranch_7_4/vector/v.external/main.c 2018-08-03 21:23:24 UTC (rev 73041)
+++ grass/branches/releasebranch_7_4/vector/v.external/main.c 2018-08-03 21:42:41 UTC (rev 73042)
@@ -101,8 +101,12 @@
dsn = NULL;
+ /* disabling GRASS-PostGIS driver:
+ * TODO: a new fn that converts OGR dsn to PQ connection info,
+ * ignoring current GRASS db connection */
+ use_ogr = TRUE;
if (options.dsn->answer)
- dsn = get_datasource_name(options.dsn->answer, use_ogr);
+ dsn = G_store(options.dsn->answer);
if (flags.list->answer || flags.tlist->answer) {
/* list layers */
