[GRASS-SVN] r73043 - grass/branches/releasebranch_7_4/vector/v.in.ogr
svn_grass at osgeo.org
Fri Aug 3 14:43:56 PDT 2018
Author: mmetz
Date: 2018-08-03 14:43:56 -0700 (Fri, 03 Aug 2018)
New Revision: 73043
grass/branches/releasebranch_7_4/vector/v.in.ogr/main.c
v.in.ogr: OGR dsn and GRASS db connections are independent of each other (backport trunk r72979)
Modified: grass/branches/releasebranch_7_4/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_7_4/vector/v.in.ogr/main.c 2018-08-03 21:42:41 UTC (rev 73042)
+++ grass/branches/releasebranch_7_4/vector/v.in.ogr/main.c 2018-08-03 21:43:56 UTC (rev 73043)
@@ -455,7 +455,7 @@
dsn = NULL;
if (param.dsn->answer)
- dsn = get_datasource_name(param.dsn->answer, TRUE);
+ dsn = G_store(param.dsn->answer);
min_area = atof(param.min_area->answer);
snap = atof(param.snap->answer);
@@ -947,7 +947,7 @@
col_info = G_malloc(ncols_out * sizeof(struct grass_col_info));
- /* Create table */
+ /* Collect column names and types */
i_out = 0;
col_info[i_out].idx = i_out;
col_info[i_out].name = key_column[layer];
@@ -1109,7 +1109,7 @@
qsort(col_info, ncols_out, sizeof(struct grass_col_info),
cmp_col_idx);
- /* construct sql from column names and types */
+ /* Create table */
i = 0;
sprintf(buf, "create table %s (%s %s", Fi->table,
col_info[i].name, col_info[i].type);
