[GRASS-SVN] r73052 - grass-addons/grass7/raster/r.in.pdal
svn_grass at osgeo.org
Mon Aug 6 23:41:08 PDT 2018
Author: AnikaBettge
Date: 2018-08-06 23:41:08 -0700 (Mon, 06 Aug 2018)
New Revision: 73052
grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
r.in.pdal: add metadata (#3515)
Modified: grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
--- grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py 2018-08-06 14:13:33 UTC (rev 73051)
+++ grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py 2018-08-07 06:41:08 UTC (rev 73052)
@@ -159,18 +159,26 @@
p = grass.call(command_fp, stdout=fh)
fh.close()
if p != 0:
- # check to see if gdalwarp executed properly
+ # check to see if pdal info executed properly
os.remove(tmp_fp)
grass.fatal(_("pdal info broken..."))
- str1 = u'boundary'
- str2 = u'boundary_json'
- str3 = u'coordinates'
data = json.load(open(tmp_fp))
- coord = data[str1][str2][str3][0][0]
xy_in = ''
- for xy in coord:
- xy_in += str(xy[0]) + ',' + str(xy[1]) + '\n'
+ str1 = u'boundary'
+ try:
+ str2 = u'boundary_json'
+ str3 = u'coordinates'
+ coord = data[str1][str2][str3][0][0]
+ for xy in coord:
+ xy_in += str(xy[0]) + ',' + str(xy[1]) + '\n'
+ except:
+ coord_str = str(data[str1][str1])
+ coord = coord_str[coord_str.find('((')+2:coord_str.find('))')]
+ x_y = coord.split(', ')
+ for xy in x_y:
+ xy_in += xy.replace(' ', ',') + '\n'
tmp_xy = os.path.join(tempfile.gettempdir(), 'xy.txt')
f = open(tmp_xy,'w')
f.write(xy_in[:-1])
@@ -188,9 +196,14 @@
os.remove(tmp_xy)
grass.run_command('g.remove', flags='f', type='vector', name='footprint_line', quiet=True)
grass.run_command('g.remove', flags='f', type='vector', name='footprint_boundary', quiet=True)
- grass.message(_("Generating output vactor map <%s>...") % footprint)
+ # metadata
+ grass.run_command('v.support', map=footprint, comment='in ' + os.environ['CMDLINE'])
+ grass.message(_("Generating output vector map <%s>...") % footprint)
def main():
# parameters
infile = options['input']
raster_reference = options['raster_reference']
@@ -219,10 +232,10 @@
outdev = sys.stdout
# scan -s or shell_script_style -g:
- if scan: # or shell_script_style:
+ if scan:
if not grass.find_program('pdal', 'info --summary'):
grass.fatal(_("The pdal program is not in the path and executable. Please install first"))
- command_scan = ['pdal','info','--summary', infile]
+ command_scan = ['pdal', 'info', '--summary', infile]
tmp_scan = os.path.join(tempfile.gettempdir(), 'scan.txt')
fh = open(tmp_scan, 'wb')
p = grass.call(command_scan, stdout=fh)
@@ -229,7 +242,7 @@
fh.close()
summary = True
if p != 0:
- command_scan = ['pdal','info',infile]
+ command_scan = ['pdal', 'info', infile]
fh.close()
@@ -245,7 +258,7 @@
y_str = u'Y'
x_str = u'X'
z_str = u'Z'
- min_str = u'min'
+ min_str = u'min'
max_str = u'max'
n = str(data[str1][str2][y_str][max_str])
s = str(data[str1][str2][y_str][min_str])
@@ -265,12 +278,11 @@
t = str(data[str1][str2][str3][str4][u'maxz'])
b = str(data[str1][str2][str3][str4][u'minz'])
if not shell_script_style:
- print('north: ' + n + '\n' + 'south: ' + s + '\n' +
- 'west: ' + w + '\n' + 'east: ' + e + '\n' +
- 'top: ' + t + '\n' + 'bottom: ' + b)
+ grass.message(_("north: %s\nsouth: %s\nwest: %s\neast: %s\ntop: %s\nbottom: %s")
+ % (n,s,w,e,t,b))
else:
- print('n=' + n + ' ' + 's=' + s + ' ' + 'w=' + w + ' ' +
- 'e=' + e + ' ' + 't=' + t + ' ' + 'b=' + b)
+ grass.message(_("n=%s s=%s w=%s e=%s t=%s b=%s")
+ % (n,s,w,e,t,b))
elif footprint:
print 'footprint'
footprintToVectormap(infile, footprint)
@@ -294,10 +306,9 @@
formatReader = '' # from https://pdal.io/stages/readers.html
if infile_format.lower() == 'laz' or infile_format.lower() == 'las':
formatReader = 'readers.las'
- elif infile_format.lower() == 'pts': # nicht getestet
+ elif infile_format.lower() == 'pts': # not tested
formatReader = 'readers.pts'
else:
grass.run_command('g.remove', flags='f', type='vector', name='tiles', quiet=True)
grass.fatal(_("Format .%s is not supported.." % infile_format))
tmp_file_json = os.path.join(tempfile.gettempdir(), 'las2txt.json')
@@ -336,15 +347,23 @@
p2 = grass.call(command_pdal1,stdout=fh)
fh.close()
if p2 != 0:
+ # check to see if pdal pipeline executed properly
grass.fatal(_("pdal pipeline is broken..."))
p3 = grass.call(command_pdal2,stdout=outdev)
if p3 != 0:
+ # check to see if r.in.xyz executed properly
os.remove(tmp_xyz)
grass.fatal(_("r.in.xyz is broken..."))
+ # metadata
+ emptyHistroy = os.path.join(tempfile.gettempdir(), 'emptyHistroy.txt')
+ f = file(emptyHistroy, 'w')
+ f.close()
+ grass.run_command('r.support', map=outfile, source1=infile, description='generated by r.in.pdal', loadhistory=emptyHistroy)
+ grass.run_command('r.support', map=outfile, history=os.environ['CMDLINE'])
+ os.remove(emptyHistroy)
# Cleanup
grass.message(_("Cleaning up..."))
