[GRASS-SVN] r73053 - grass-addons/grass7/imagery/i.sentinel.mask
svn_grass at osgeo.org
Tue Aug 7 06:37:00 PDT 2018
Author: Robifag
Date: 2018-08-07 06:37:00 -0700 (Tue, 07 Aug 2018)
New Revision: 73053
grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.html
grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.py
Fixed a bug on input text file and small changes to the manual
Modified: grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.html
--- grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.html 2018-08-07 06:41:08 UTC (rev 73052)
+++ grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.html 2018-08-07 13:37:00 UTC (rev 73053)
@@ -67,7 +67,7 @@
Tha variables names (blue, green, red, nir, nir8a, swir11, swir12) have to be
written precisely like in the example above (e.g. not Blue, nor BLUE but blue),
-no spaces or special characters are permitted.
+no spaces, empty lines or special characters are permitted.
<p>
The final outputs are two different vector maps, one for clouds and one for
Modified: grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.py
--- grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.py 2018-08-07 06:41:08 UTC (rev 73052)
+++ grass-addons/grass7/imagery/i.sentinel.mask/i.sentinel.mask.py 2018-08-07 13:37:00 UTC (rev 73053)
@@ -202,18 +202,16 @@
if gscript.find_file(value,
element = 'vector',
mapset = mapset)['file']:
- gscript.fatal(('Temporary vector map <{}> \
- already exists.').format(value))
+ gscript.fatal(('Temporary vector map <{}> already exists.').format(value))
element = 'cell',
- gscript.fatal(('Temporary raster map <{}> \
+ gscript.fatal(('Temporary raster map <{}> already exists.').format(value))
# Input file
mtd_file = options['mtd_file']
bands = {}
- if options['input_file']=='':
+ if options['input_file'] == '':
bands['blue'] = options['blue']
bands['green'] = options['green']
bands['red'] = options['red']
@@ -222,6 +220,7 @@
bands['swir11'] = options['swir11']
bands['swir12'] = options['swir12']
else:
+ txt_bands = []
input_file = options['input_file']
for line in file(input_file):
a = line.split('=')
@@ -232,10 +231,14 @@
'nir8a',
'swir11',
'swir12' ]:
- gscript.fatal('Syntax error in the txt file. See the manual \
- for further information about the right syntax.')
+ gscript.fatal('Syntax error in the txt file. See the manual for further information about the right syntax.')
+ else:
+ txt_bands.append(a[0])
a[1] = a[1].strip()
bands[a[0]] = a[1]
+ if len(txt_bands) < 7:
+ gscript.fatal(('One or more bands are missing in the input text file.\n Only these bands have been found: {}').format(txt_bands))
d = 'double'
f_bands = {}
scale_fac = options['scale_fac']
@@ -245,6 +248,7 @@
cloud_mask = options['cloud_mask']
shadow_mask = options['shadow_mask']
+ # Check if all required input bands are specified in the text file
if (bands['blue'] == '' or
bands['green'] == '' or
bands['red'] == '' or
@@ -252,9 +256,9 @@
bands['nir8a'] == ''or
bands['swir11'] == '' or
bands['swir12'] == ''):
- gscript.fatal('All input bands (blue, green, red, nir, nir8a, swir11, \
- swir12) are required')
+ gscript.fatal('All input bands (blue, green, red, nir, nir8a, swir11, swir12) are required')
+ # Check if input bands exist
for key, value in bands.items():
if not gscript.find_file(value,
element = 'cell',
@@ -261,13 +265,12 @@
gscript.fatal(('Raster map <{}> not found.').format(value))
+ # Check input and output for shadow mask
if not flags["c"]:
if options['mtd_file']== '':
- gscript.fatal('Metadata file is required for shadow mask \
- computation. Please specified it')
+ gscript.fatal('Metadata file is required for shadow mask computation. Please specified it')
if options['shadow_mask']=='':
- gscript.fatal('Output name is required for shadow mask. \
- Please specified it')
+ gscript.fatal('Output name is required for shadow mask. Please specified it')
if flags["r"]:
gscript.use_temp_region()
@@ -274,11 +277,9 @@
gscript.run_command('g.region',
rast=bands.values(),
flags='a')
- gscript.message(_('--- The computational region has been temporarily \
- set to image max extent ---'))
+ gscript.message(_('--- The computational region has been temporarily set to image max extent ---'))
else:
- gscript.warning(_('All subsequent operations will be limited to the \
- current computational region'))
+ gscript.warning(_('All subsequent operations will be limited to the current computational region'))
if flags["s"]:
gscript.message(_('--- Start rescaling bands ---'))
@@ -410,8 +411,7 @@
# START shadows cleaning Procedure (remove shadows misclassification)
# Start shadow mask preparation
- gscript.message(_('--- Start removing misclassification from \
- the shadow mask ---'))
+ gscript.message(_('--- Start removing misclassification from the shadow mask ---'))
gscript.message(_('--- Data preparation... ---'))
gscript.run_command('v.centroids',
input=tmp["shadow_temp_mask"],
@@ -467,8 +467,7 @@
# Shift cloud mask using dE e dN
# Start reading mean sun zenith and azimuth from xml file to compute
#dE and dN automatically
- gscript.message(_('--- Reading mean sun zenith and azimuth from \
- MTD_TL.xml file to compute clouds shift ---'))
+ gscript.message(_('--- Reading mean sun zenith and azimuth from metadata file to compute clouds shift ---'))
xml_tree = et.parse(mtd_file)
root = xml_tree.getroot()
ZA = []
@@ -478,17 +477,14 @@
ZA.append (subelem.text)
z = float(ZA[0])
a = float(ZA[1])
- gscript.message(_('--- the mean sun Zenith is: \
- {:.3f} deg ---'.format(z)))
- gscript.message(_('--- the mean sun Azimuth is: \
- {:.3f} deg ---'.format(a)))
+ gscript.message(_('--- the mean sun Zenith is: {:.3f} deg ---'.format(z)))
+ gscript.message(_('--- the mean sun Azimuth is: {:.3f} deg ---'.format(a)))
# Stop reading mean sun zenith and azimuth from xml file to compute dE
#and dN automatically
# Start computing the east and north shift for clouds and the
#overlapping area between clouds and shadows at steps of 100m
- gscript.message(_('--- Start computing the east and north clouds \
- shift at steps of 100m of clouds height---'))
+ gscript.message(_('--- Start computing the east and north clouds shift at steps of 100m of clouds height---'))
H = 1000
dH = 100
HH = []
@@ -556,20 +552,17 @@
operator='intersects',
quiet=True)
- gscript.message(_('--- the estimated clouds height is: \
- {} m ---'.format(HH[index_maxAA])))
- gscript.message(_('--- the estimated east shift is: \
- {:.2f} m ---'.format(dE[index_maxAA])))
- gscript.message(_('--- the estimated north shift is: \
- {:.2f} m ---'.format(dN[index_maxAA])))
+ gscript.message(_('--- the estimated clouds height is: {} m ---'.format(HH[index_maxAA])))
+ gscript.message(_('--- the estimated east shift is: {:.2f} m ---'.format(dE[index_maxAA])))
+ gscript.message(_('--- the estimated north shift is: {:.2f} m ---'.format(dN[index_maxAA])))
else:
- gscript.warning(_('No shadow mask will be computed'))
+ if shadow_mask != '':
+ gscript.warning(_('No shadow mask will be computed'))
def cleanup():
if flags["r"]:
gscript.del_temp_region()
- gscript.message(_('--- The computational region has been reset to \
- the previous one---'))
+ gscript.message(_('--- The computational region has been reset to the previous one---'))
if flags["t"]:
gscript.message(_('--- No temporary files have been deleted ---'))
else:
