[GRASS-SVN] r73063 - grass-addons/grass7/raster/r.in.pdal
svn_grass at osgeo.org
Wed Aug 8 18:12:47 PDT 2018
Author: wenzeslaus
Date: 2018-08-08 18:12:47 -0700 (Wed, 08 Aug 2018)
New Revision: 73063
grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
r.in.pdal: greater PEP8 compliance using pylint
Fixing bad-continuation (wrong hanging indentation) and wrong-import-order.
Following pep8 tool (and PEP8), not pylint, on indent of closing parenthesis.
Modified: grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
--- grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py 2018-08-08 06:59:33 UTC (rev 73062)
+++ grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py 2018-08-09 01:12:47 UTC (rev 73063)
@@ -141,12 +141,13 @@
import os
import sys
+import json
+import gettext
import grass.script as grass
-import json
# i18N
-import gettext
gettext.install('grassmods', os.path.join(os.getenv("GISBASE"), 'locale'))
@@ -160,7 +161,7 @@
if not grass.find_program('pdal', 'info --boundary'):
grass.fatal(_(
- "pdal info --boundary is not in the path and executable"))
+ "pdal info --boundary is not in the path and executable"))
command_fp = ['pdal', 'info', '--boundary', infile]
tmp_fp = grass.tempfile()
if tmp_fp is None:
@@ -195,58 +196,51 @@
f = open(tmp_xy, 'w')
f.write(xy_in[:-1])
f.close()
- grass.run_command(
- 'v.in.lines',
- input=tmp_xy,
- output='footprint_line',
- separator='comma'
+ grass.run_command('v.in.lines',
+ input=tmp_xy,
+ output='footprint_line',
+ separator='comma'
grass.run_command('g.region', vector='footprint_line')
- 'v.type',
- input='footprint_line',
- out='footprint_boundary',
- from_type='line',
- to_type='boundary'
+ grass.run_command('v.type',
+ input='footprint_line',
+ out='footprint_boundary',
+ from_type='line',
+ to_type='boundary'
grass.run_command('v.centroids', input='footprint_boundary', out=footprint)
- 'v.db.addtable',
- map=footprint,
- columns='name varchar(50)'
- 'v.db.update',
- map=footprint,
- column='name',
- value=infile
+ grass.run_command('v.db.addtable',
+ map=footprint,
+ columns='name varchar(50)'
+ grass.run_command('v.db.update',
+ map=footprint,
+ column='name',
+ value=infile
# Cleaning up
grass.message(_("Cleaning up..."))
os.remove(tmp_fp)
os.remove(tmp_xy)
- 'g.remove',
- flags='f',
- type='vector',
- name='footprint_line',
- quiet=True
- 'g.remove',
- flags='f',
- type='vector',
- name='footprint_boundary',
- quiet=True
+ grass.run_command('g.remove',
+ flags='f',
+ type='vector',
+ name='footprint_line',
+ quiet=True
+ flags='f',
+ type='vector',
+ name='footprint_boundary',
+ quiet=True
# metadata
- 'v.support',
- map=footprint,
- comment='in ' + os.environ['CMDLINE']
+ grass.run_command('v.support',
+ map=footprint,
+ comment='in ' + os.environ['CMDLINE']
grass.message(_("Generating output vector map <%s>...") % footprint)
@@ -307,8 +301,7 @@
os.remove(tmp_scan)
grass.fatal(_(
"pdal cannot determine metadata " +
- "for unsupported format of <%s>")
- % infile)
+ "for unsupported format of <%s>") % infile)
data = json.load(open(tmp_scan))
if summary:
str1 = u'summary'
@@ -338,12 +331,10 @@
if not shell_script_style:
grass.message(_(
"north: %s\nsouth: %s\nwest: %s\neast: %s\ntop: %s\nbottom: %s"
- % (n, s, w, e, t, b))
+ ) % (n, s, w, e, t, b))
else:
- grass.message(_(
- "n=%s s=%s w=%s e=%s t=%s b=%s")
+ grass.message(_("n=%s s=%s w=%s e=%s t=%s b=%s")
+ % (n, s, w, e, t, b))
elif footprint:
footprint_to_vectormap(infile, footprint)
else:
@@ -352,12 +343,11 @@
if raster_file:
raster_reference = 'img'
- 'r.external',
- input=raster_file,
- flags='o',
- output=raster_reference
+ grass.run_command('r.external',
+ input=raster_file,
+ flags='o',
+ output=raster_reference
result = grass.find_file(name=raster_reference, element='raster')
if result[u'fullname'] == u'':
raster_reference = 'img.1'
@@ -365,20 +355,18 @@
# geometry to raster_reference
grass.run_command('g.region', vector='tiles', flags='p')
if raster_reference:
- 'g.region',
- vector='tiles',
- flags='ap',
- align=raster_reference
+ grass.run_command('g.region',
+ vector='tiles',
+ flags='ap',
+ align=raster_reference
# second pass: change raster resolution to final resolution while best
# effort aligning to pixel geometry
- 'g.region',
- vector='tiles',
- flags='ap',
- res=resolution
+ vector='tiles',
+ flags='ap',
+ res=resolution
# . pdal pipline laz2json (STDOUT) | r.in.xyz
bn = os.path.basename(infile)
@@ -391,13 +379,12 @@
elif infile_format.lower() == 'pts':
format_reader = 'readers.pts'
else:
- 'g.remove',
- flags='f',
- type='vector',
- name='tiles',
- quiet=True
+ flags='f',
+ type='vector',
+ name='tiles',
+ quiet=True
grass.fatal(_("Format .%s is not supported.." % infile_format))
tmp_file_json = grass.tempfile()
if tmp_file_json is None:
@@ -455,29 +442,26 @@
grass.fatal("Unable to create temporary files")
f = file(empty_histroy, 'w')
f.close()
- 'r.support',
- map=outfile,
- source1=infile,
- description='generated by r.in.pdal',
- loadhistory=empty_histroy
- 'r.support',
- map=outfile,
- history=os.environ['CMDLINE']
+ grass.run_command('r.support',
+ map=outfile,
+ source1=infile,
+ description='generated by r.in.pdal',
+ loadhistory=empty_histroy
+ map=outfile,
+ history=os.environ['CMDLINE']
os.remove(empty_histroy)
# Cleanup
- 'g.remove',
- flags='f',
- type='vector',
- name='tiles',
- quiet=True
+ flags='f',
+ type='vector',
+ name='tiles',
+ quiet=True
os.remove(tmp_file_json)
os.remove(tmp_xyz)
grass.message(_("Generating output raster map <%s>...") % outfile)
