[GRASS-SVN] r73064 - grass-addons/grass7/raster/r.in.pdal
svn_grass at osgeo.org
Wed Aug 8 18:34:20 PDT 2018
Author: wenzeslaus
Date: 2018-08-08 18:34:19 -0700 (Wed, 08 Aug 2018)
New Revision: 73064
grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
r.in.pdal: add using the computational region (GRASS default behavior)
Modified: grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
--- grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py 2018-08-09 01:12:47 UTC (rev 73063)
+++ grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py 2018-08-09 01:34:19 UTC (rev 73064)
@@ -139,6 +139,12 @@
#% description: In scan mode, print using shell script style
#%end
+#%flag
+#% key: e
+#% label: Use the extent of the input for the raster extent
+#% description: Set internally computational region extents based on the point cloud
+#%end
import os
import sys
import json
@@ -263,6 +269,7 @@
# flags
scan = flags['s']
shell_script_style = flags['g']
+ input_as_extent = flags['e']
# overwrite auf true setzen
os.environ['GRASS_OVERWRITE'] = '1'
@@ -338,35 +345,36 @@
elif footprint:
footprint_to_vectormap(infile, footprint)
else:
- # get region with pdal
- footprint_to_vectormap(infile, 'tiles')
+ if input_as_extent or raster_file or raster_reference:
+ # get region with pdal
+ footprint_to_vectormap(infile, 'tiles')
- if raster_file:
- raster_reference = 'img'
- grass.run_command('r.external',
- input=raster_file,
- flags='o',
- output=raster_reference
- result = grass.find_file(name=raster_reference, element='raster')
- if result[u'fullname'] == u'':
- raster_reference = 'img.1'
- # first pass: set region to extent of tiles while aligning pixel
- # geometry to raster_reference
- grass.run_command('g.region', vector='tiles', flags='p')
- if raster_reference:
+ if raster_file:
+ raster_reference = 'img'
+ grass.run_command('r.external',
+ input=raster_file,
+ flags='o',
+ output=raster_reference
+ result = grass.find_file(name=raster_reference, element='raster')
+ if result[u'fullname'] == u'':
+ raster_reference = 'img.1'
+ # first pass: set region to extent of tiles while aligning pixel
+ # geometry to raster_reference
+ grass.run_command('g.region', vector='tiles', flags='p')
+ if raster_reference:
+ vector='tiles',
+ flags='ap',
+ align=raster_reference
+ # second pass: change raster resolution to final resolution while best
+ # effort aligning to pixel geometry
vector='tiles',
flags='ap',
- align=raster_reference
+ res=resolution
- # second pass: change raster resolution to final resolution while best
- # effort aligning to pixel geometry
- vector='tiles',
- flags='ap',
- res=resolution
# . pdal pipline laz2json (STDOUT) | r.in.xyz
bn = os.path.basename(infile)
