[GRASS-SVN] r73180 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Sat Aug 25 09:50:51 PDT 2018
Author: martinl
Date: 2018-08-25 09:50:50 -0700 (Sat, 25 Aug 2018)
New Revision: 73180
grass/trunk/display/d.vect/area.c
grass/trunk/display/d.vect/d.vect.html
grass/trunk/display/d.vect/lines.c
d.vect with z height colors uses a random polygon point for height - patch to fix attached (see #934)
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c 2018-08-25 02:01:07 UTC (rev 73179)
+++ grass/trunk/display/d.vect/area.c 2018-08-25 16:50:50 UTC (rev 73180)
@@ -166,7 +166,9 @@
/* z height colors */
if (zcolors) {
- if (Rast_get_d_color(&Points->z[0], &red, &grn, &blu, zcolors) == 1)
+ double zval = (box.B + box.T) / 2; /* midpoint of area bounding box z */
+ G_debug(3, "area=%d -> zval=%f", area, zval);
+ if (Rast_get_d_color(&zval, &red, &grn, &blu, zcolors) == 1)
custom_rgb = TRUE;
else
custom_rgb = FALSE;
Modified: grass/trunk/display/d.vect/d.vect.html
--- grass/trunk/display/d.vect/d.vect.html 2018-08-25 02:01:07 UTC (rev 73179)
+++ grass/trunk/display/d.vect/d.vect.html 2018-08-25 16:50:50 UTC (rev 73180)
@@ -81,7 +81,10 @@
d.vect -c map=soils where="label='VBF'" display=shape attribute_column=label
</pre></div>
-<p>3D points, 3D lines and 3D polygons colorized according to z height:
+<p>3D points, 3D lines and 3D polygons colorized according to z height
+(for 3D lines and polygons a z height is computed by a midpoint of
+line/area bounding box):
<div class="code"><pre>
g.region raster=elevation.10m
r.random input=elevation.10m n=5000 vector=random3d -d
Modified: grass/trunk/display/d.vect/lines.c
--- grass/trunk/display/d.vect/lines.c 2018-08-25 02:01:07 UTC (rev 73179)
+++ grass/trunk/display/d.vect/lines.c 2018-08-25 16:50:50 UTC (rev 73180)
@@ -261,7 +261,11 @@
if (zcolors && (ltype & GV_POINTS)) {
+ struct bound_box box;
+ Vect_line_box(Points, &box);
+ double zval = (box.B + box.T) / 2; /* midpoint of line bounding box z */
+ G_debug(3, "line=%d -> zval=%f", line, zval);
custom_rgb = TRUE;
else
custom_rgb = FALSE;
