[GRASS-SVN] r73181 - grass/branches/releasebranch_7_4/display/d.vect
svn_grass at osgeo.org
Sat Aug 25 09:54:22 PDT 2018
Author: martinl
Date: 2018-08-25 09:54:22 -0700 (Sat, 25 Aug 2018)
New Revision: 73181
grass/branches/releasebranch_7_4/display/d.vect/d.vect.html
d.vect: explain z height for 3D lines/polygons, see #934
Modified: grass/branches/releasebranch_7_4/display/d.vect/d.vect.html
--- grass/branches/releasebranch_7_4/display/d.vect/d.vect.html 2018-08-25 16:50:50 UTC (rev 73180)
+++ grass/branches/releasebranch_7_4/display/d.vect/d.vect.html 2018-08-25 16:54:22 UTC (rev 73181)
@@ -81,7 +81,8 @@
d.vect -c map=soils where="label='VBF'" display=shape attribute_column=label
</pre></div>
-<p>3D points, 3D lines and 3D polygons colorized according to z height:
+<p>3D points, 3D lines and 3D polygons colorized according to z height
+(for 3D lines and polygons a z height is defined by a first vertex):
<div class="code"><pre>
g.region raster=elevation.10m
r.random input=elevation.10m n=5000 vector=random3d -d
