[GRASS-SVN] r73815 - grass-addons/grass7/raster/r.in.pdal
svn_grass at osgeo.org
Tue Dec 18 02:08:38 PST 2018
Author: AnikaBettge
Date: 2018-12-18 02:08:38 -0800 (Tue, 18 Dec 2018)
New Revision: 73815
grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
r.in.pdal addon: fix pdal summary use
Modified: grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
--- grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py 2018-12-18 09:08:22 UTC (rev 73814)
+++ grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py 2018-12-18 10:08:38 UTC (rev 73815)
@@ -2,45 +2,37 @@
-# MODULE: r.in.pdal
+# MODULE: r.in.pdal
# AUTHOR(S): Anika Bettge <bettge at mundialis.de>
# Thanks to Markus Neteler <neteler at mundialis.de> for help
-# Vaclav Petras <wenzeslaus at gmail com>
# PURPOSE: Creates a raster map from LAS LiDAR points using univariate statistics and r.in.xyz.
# COPYRIGHT: (C) 2018 by mundialis and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
-#%module
-#% description: Creates a raster map from LAS LiDAR points using univariate statistics and r.in.xyz.
-#% keyword: raster
-#% keyword: import
-#% keyword: LIDAR
-#% keyword: statistics
-#% keyword: conversion
-#%end
+#%Module
+#%description: Creates a raster map from LAS LiDAR points using univariate statistics and r.in.xyz.
+#%keyword: raster
+#%keyword: import
+#%keyword: LIDAR
+#%keyword: statistics
+#%keyword: conversion
+#%overwrite: yes
+#%End
-#%option G_OPT_F_BIN_INPUT
+#%option G_OPT_R_INPUT
#% key: input
#% description: LAS input file
#% required: yes
#%end
-#%option
-#% key: proj_in
-#% type: string
-#% label: SRS information for input as EPSG code or PROJ string
-#% description: Override input SRS using EPSG code (e.g. EPSG:3358) or PROJ string
-#% required: no
-#%end
#%option G_OPT_R_OUTPUT
#% key: output
#% description: Name for output raster map
@@ -55,7 +47,7 @@
#% required: no
#%end
-#%option G_OPT_R_INPUT
+#%option
#% key: raster_reference
#% label: Raster map to be used as pixel geometry reference
#% description: Raster map to align to, e.g. an orthophoto of the same region
@@ -62,7 +54,7 @@
#% required: no
#%end
+#%option
#% key: raster_file
#% label: External raster map to be used as pixel geometry reference
#% description: External raster map to align to, e.g. an orthophoto of the same region
@@ -95,9 +87,14 @@
#% required: no
#%end
-#%option G_OPT_R_TYPE
+#%option
+#% key: type
+#% type: string
+#% description: Type of raster map to be created / Storage type for resultant raster map
+#% options: CELL, FCELL, DCELL
#% answer: FCELL
#% required: no
+#% descriptions: CELL;Integer;FCELL;Single precision floating point;DCELL;Double precision floating point
#%end
#%option
@@ -142,21 +139,14 @@
#% description: In scan mode, print using shell script style
#%end
-#%flag
-#% key: e
-#% label: Use the extent of the input for the raster extent
-#% description: Set internally computational region extents based on the point cloud
-#%end
import os
import sys
-import json
-import gettext
import grass.script as grass
+import json
# i18N
+import gettext
gettext.install('grassmods', os.path.join(os.getenv("GISBASE"), 'locale'))
@@ -170,7 +160,7 @@
if not grass.find_program('pdal', 'info --boundary'):
grass.fatal(_(
- "pdal info --boundary is not in the path and executable"))
+ "pdal info --boundary is not in the path and executable"))
command_fp = ['pdal', 'info', '--boundary', infile]
tmp_fp = grass.tempfile()
if tmp_fp is None:
@@ -205,51 +195,58 @@
f = open(tmp_xy, 'w')
f.write(xy_in[:-1])
f.close()
- grass.run_command('v.in.lines',
- input=tmp_xy,
- output='footprint_line',
- separator='comma'
+ grass.run_command(
+ 'v.in.lines',
+ input=tmp_xy,
+ output='footprint_line',
+ separator='comma'
grass.run_command('g.region', vector='footprint_line')
- grass.run_command('v.type',
- input='footprint_line',
- out='footprint_boundary',
- from_type='line',
- to_type='boundary'
+ 'v.type',
+ input='footprint_line',
+ out='footprint_boundary',
+ from_type='line',
+ to_type='boundary'
grass.run_command('v.centroids', input='footprint_boundary', out=footprint)
- grass.run_command('v.db.addtable',
- map=footprint,
- columns='name varchar(50)'
- grass.run_command('v.db.update',
- map=footprint,
- column='name',
- value=infile
+ 'v.db.addtable',
+ map=footprint,
+ columns='name varchar(50)'
+ 'v.db.update',
+ map=footprint,
+ column='name',
+ value=infile
# Cleaning up
grass.message(_("Cleaning up..."))
os.remove(tmp_fp)
os.remove(tmp_xy)
- grass.run_command('g.remove',
- flags='f',
- type='vector',
- name='footprint_line',
- quiet=True
- flags='f',
- type='vector',
- name='footprint_boundary',
- quiet=True
+ 'g.remove',
+ flags='f',
+ type='vector',
+ name='footprint_line',
+ quiet=True
+ 'g.remove',
+ flags='f',
+ type='vector',
+ name='footprint_boundary',
+ quiet=True
# metadata
- grass.run_command('v.support',
- map=footprint,
- comment='in ' + os.environ['CMDLINE']
+ 'v.support',
+ map=footprint,
+ comment='in ' + os.environ['CMDLINE']
grass.message(_("Generating output vector map <%s>...") % footprint)
@@ -269,18 +266,12 @@
pth = options['pth']
trim = options['trim']
footprint = options['footprint']
- # user-supplied projection (overrides the actual one)
- user_provided_srs = options['proj_in']
# flags
scan = flags['s']
shell_script_style = flags['g']
- input_as_extent = flags['e']
- # reprojecting always
- # TODO: test if it is faster to skip it in the pipeline when
- # SRSs match, if faster, then get projection ahead of time
- # (which may be good even to tell user about reprojection happening)
- reprojection = True
+ # overwrite auf true setzen
+ os.environ['GRASS_OVERWRITE'] = '1'
# to hide non-error messages from subprocesses
if grass.verbosity() <= 2:
@@ -295,8 +286,8 @@
if scan:
if not grass.find_program('pdal', 'info --summary'):
grass.fatal(_(
- "The pdal program is not in the path "
- "and executable. Please install it first"))
+ "The pdal program is not in the path " +
+ "and executable. Please install first"))
command_scan = ['pdal', 'info', '--summary', infile]
tmp_scan = grass.tempfile()
if tmp_scan is None:
@@ -315,8 +306,9 @@
# check to see if pdal executed properly
os.remove(tmp_scan)
grass.fatal(_(
- "pdal cannot determine metadata "
- "for unsupported format of <%s>") % infile)
+ "pdal cannot determine metadata " +
+ "for unsupported format of <%s>")
+ % infile)
data = json.load(open(tmp_scan))
if summary:
str1 = u'summary'
@@ -326,12 +318,26 @@
z_str = u'Z'
min_str = u'min'
max_str = u'max'
- n = str(data[str1][str2][y_str][max_str])
- s = str(data[str1][str2][y_str][min_str])
- w = str(data[str1][str2][x_str][min_str])
- e = str(data[str1][str2][x_str][max_str])
- t = str(data[str1][str2][z_str][max_str])
- b = str(data[str1][str2][z_str][min_str])
+ try:
+ n = str(data[str1][str2][y_str][max_str])
+ s = str(data[str1][str2][y_str][min_str])
+ w = str(data[str1][str2][x_str][min_str])
+ e = str(data[str1][str2][x_str][max_str])
+ t = str(data[str1][str2][z_str][max_str])
+ b = str(data[str1][str2][z_str][min_str])
+ except:
+ ymin_str = u'miny'
+ xmin_str = u'minx'
+ zmin_str = u'minz'
+ ymax_str = u'maxy'
+ xmax_str = u'maxx'
+ zmax_str = u'maxz'
+ n = str(data[str1][str2][ymax_str])
+ s = str(data[str1][str2][ymin_str])
+ w = str(data[str1][str2][xmin_str])
+ e = str(data[str1][str2][xmax_str])
+ t = str(data[str1][str2][zmax_str])
+ b = str(data[str1][str2][zmin_str])
else:
str1 = u'stats'
str2 = u'bbox'
@@ -346,43 +352,47 @@
if not shell_script_style:
grass.message(_(
"north: %s\nsouth: %s\nwest: %s\neast: %s\ntop: %s\nbottom: %s"
- ) % (n, s, w, e, t, b))
+ % (n, s, w, e, t, b))
else:
- grass.message(_("n=%s s=%s w=%s e=%s t=%s b=%s")
- % (n, s, w, e, t, b))
+ grass.message(_(
+ "n=%s s=%s w=%s e=%s t=%s b=%s")
elif footprint:
footprint_to_vectormap(infile, footprint)
else:
- if input_as_extent or raster_file or raster_reference:
- # get region with pdal
- footprint_to_vectormap(infile, 'tiles')
+ # get region with pdal
+ footprint_to_vectormap(infile, 'tiles')
- if raster_file:
- raster_reference = 'img'
- grass.run_command('r.external',
- input=raster_file,
- flags='o',
- output=raster_reference
- result = grass.find_file(name=raster_reference, element='raster')
- if result[u'fullname'] == u'':
- raster_reference = 'img.1'
- # first pass: set region to extent of tiles while aligning pixel
- # geometry to raster_reference
- grass.run_command('g.region', vector='tiles', flags='p')
- if raster_reference:
- vector='tiles',
- flags='ap',
- align=raster_reference
- # second pass: change raster resolution to final resolution while best
- # effort aligning to pixel geometry
- vector='tiles',
- flags='ap',
- res=resolution
+ if raster_file:
+ raster_reference = 'img'
+ 'r.external',
+ input=raster_file,
+ flags='o',
+ output=raster_reference
+ result = grass.find_file(name=raster_reference, element='raster')
+ if result[u'fullname'] == u'':
+ raster_reference = 'img.1'
+ # first pass: set region to extent of tiles while aligning pixel
+ # geometry to raster_reference
+ grass.run_command('g.region', vector='tiles', flags='p')
+ if raster_reference:
+ 'g.region',
+ vector='tiles',
+ flags='ap',
+ align=raster_reference
+ # second pass: change raster resolution to final resolution while best
+ # effort aligning to pixel geometry
+ 'g.region',
+ vector='tiles',
+ flags='ap',
+ res=resolution
# . pdal pipline laz2json (STDOUT) | r.in.xyz
bn = os.path.basename(infile)
@@ -395,12 +405,13 @@
elif infile_format.lower() == 'pts':
format_reader = 'readers.pts'
else:
- flags='f',
- type='vector',
- name='tiles',
- quiet=True
+ 'g.remove',
+ flags='f',
+ type='vector',
+ name='tiles',
+ quiet=True
grass.fatal(_("Format .%s is not supported.." % infile_format))
tmp_file_json = grass.tempfile()
if tmp_file_json is None:
@@ -408,17 +419,6 @@
data = {}
data['pipeline'] = []
data['pipeline'].append({'type': format_reader, 'filename': infile})
- if reprojection:
- location_srs = grass.read_command('g.proj', flags='j')
- # making use of universal newlines
- location_srs = " ".join(location_srs.splitlines())
- reproj_filter = {
- "type": "filters.reprojection",
- "out_srs": location_srs
- if user_provided_srs:
- reproj_filter.update({"in_srs": user_provided_srs})
- data['pipeline'].append(reproj_filter)
'type': 'writers.text',
'format': 'csv',
@@ -469,26 +469,29 @@
grass.fatal("Unable to create temporary files")
f = file(empty_histroy, 'w')
f.close()
- grass.run_command('r.support',
- map=outfile,
- source1=infile,
- description='generated by r.in.pdal',
- loadhistory=empty_histroy
- map=outfile,
- history=os.environ['CMDLINE']
+ 'r.support',
+ map=outfile,
+ source1=infile,
+ description='generated by r.in.pdal',
+ loadhistory=empty_histroy
+ 'r.support',
+ map=outfile,
+ history=os.environ['CMDLINE']
os.remove(empty_histroy)
# Cleanup
- flags='f',
- type='vector',
- name='tiles',
- quiet=True
+ 'g.remove',
+ flags='f',
+ type='vector',
+ name='tiles',
+ quiet=True
os.remove(tmp_file_json)
os.remove(tmp_xyz)
grass.message(_("Generating output raster map <%s>...") % outfile)
