[GRASS-SVN] r73818 - grass/branches/releasebranch_7_6/vector/v.out.ogr
svn_grass at osgeo.org
Thu Dec 20 10:50:55 PST 2018
Author: mmetz
Date: 2018-12-20 10:50:55 -0800 (Thu, 20 Dec 2018)
New Revision: 73818
grass/branches/releasebranch_7_6/vector/v.out.ogr/main.c
v.out.ogr: fix #3714, segfault with -n (backport trunk r73817)
Modified: grass/branches/releasebranch_7_6/vector/v.out.ogr/main.c
--- grass/branches/releasebranch_7_6/vector/v.out.ogr/main.c 2018-12-20 18:50:07 UTC (rev 73817)
+++ grass/branches/releasebranch_7_6/vector/v.out.ogr/main.c 2018-12-20 18:50:55 UTC (rev 73818)
@@ -128,6 +128,7 @@
Centroids, Boundaries and Kernels always have to be exported
explicitly, using the "type=" option.
+ field = 0;
if (!flags.new->answer) {
/* open input vector (topology required) */
Vect_set_open_level(2);
@@ -189,10 +190,9 @@
G_warning(_("Unable to determine input map's vector feature type(s)."));
+ field = Vect_get_field_number(&In, options.field->answer);
- field = Vect_get_field_number(&In, options.field->answer);
/* check output feature type */
otype = Vect_option_to_types(options.type);
ftype = Vect_option_to_types(options.otype);
