[GRASS-SVN] r73817 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Thu Dec 20 10:50:07 PST 2018
Author: mmetz
Date: 2018-12-20 10:50:07 -0800 (Thu, 20 Dec 2018)
New Revision: 73817
grass/trunk/vector/v.out.ogr/main.c
v.out.ogr: fix #3714, segfault with -n, fix indentation
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2018-12-18 20:05:11 UTC (rev 73816)
+++ grass/trunk/vector/v.out.ogr/main.c 2018-12-20 18:50:07 UTC (rev 73817)
@@ -128,6 +128,7 @@
Centroids, Boundaries and Kernels always have to be exported
explicitly, using the "type=" option.
+ field = 0;
if (!flags.new->answer) {
/* open input vector (topology required) */
Vect_set_open_level(2);
@@ -189,10 +190,9 @@
G_warning(_("Unable to determine input map's vector feature type(s)."));
+ field = Vect_get_field_number(&In, options.field->answer);
- field = Vect_get_field_number(&In, options.field->answer);
/* check output feature type */
otype = Vect_option_to_types(options.type);
ftype = Vect_option_to_types(options.otype);
@@ -678,86 +678,90 @@
if (create_field) {
Ogr_field = OGR_Fld_Create(GV_KEY_COLUMN, OFTInteger);
- OGR_L_CreateField(Ogr_layer, Ogr_field, 0);
+ if (OGR_L_CreateField(Ogr_layer, Ogr_field, 0) != OGRERR_NONE)
+ G_fatal_error(_("Unable to create column <%s>"),
+ GV_KEY_COLUMN);
OGR_Fld_Destroy(Ogr_field);
doatt = 0;
- else {
- Driver = db_start_driver_open_database(Fi->driver, Fi->database);
- if (!Driver)
- G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ else {
+ Driver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (!Driver)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
Fi->database, Fi->driver);
- db_set_string(&dbstring, Fi->table);
- if (db_describe_table(Driver, &dbstring, &Table) != DB_OK)
- G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
+ db_set_string(&dbstring, Fi->table);
+ if (db_describe_table(Driver, &dbstring, &Table) != DB_OK)
+ G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
- ncol = db_get_table_number_of_columns(Table);
- G_debug(2, "ncol = %d", ncol);
- colctype = G_malloc(ncol * sizeof(int));
- colname = G_malloc(ncol * sizeof(char *));
- keycol = -1;
- for (i = 0; i < ncol; i++) {
- Column = db_get_table_column(Table, i);
- colname[i] = G_store(db_get_column_name(Column));
- colsqltype = db_get_column_sqltype(Column);
- colctype[i] = db_sqltype_to_Ctype(colsqltype);
- colwidth = db_get_column_length(Column);
- G_debug(3, "col %d: %s sqltype=%d ctype=%d width=%d",
- i, colname[i], colsqltype, colctype[i], colwidth);
+ ncol = db_get_table_number_of_columns(Table);
+ G_debug(2, "ncol = %d", ncol);
+ colctype = G_malloc(ncol * sizeof(int));
+ colname = G_malloc(ncol * sizeof(char *));
+ keycol = -1;
+ for (i = 0; i < ncol; i++) {
+ Column = db_get_table_column(Table, i);
+ colname[i] = G_store(db_get_column_name(Column));
+ colsqltype = db_get_column_sqltype(Column);
+ colctype[i] = db_sqltype_to_Ctype(colsqltype);
+ colwidth = db_get_column_length(Column);
+ G_debug(3, "col %d: %s sqltype=%d ctype=%d width=%d",
+ i, colname[i], colsqltype, colctype[i], colwidth);
- switch (colctype[i]) {
- case DB_C_TYPE_INT:
- ogr_ftype = OFTInteger;
- break;
- case DB_C_TYPE_DOUBLE:
- ogr_ftype = OFTReal;
- break;
- case DB_C_TYPE_STRING:
- ogr_ftype = OFTString;
- break;
- case DB_C_TYPE_DATETIME:
- break;
- G_debug(2, "ogr_ftype = %d", ogr_ftype);
+ switch (colctype[i]) {
+ case DB_C_TYPE_INT:
+ ogr_ftype = OFTInteger;
+ break;
+ case DB_C_TYPE_DOUBLE:
+ ogr_ftype = OFTReal;
+ break;
+ case DB_C_TYPE_STRING:
+ ogr_ftype = OFTString;
+ break;
+ case DB_C_TYPE_DATETIME:
+ break;
+ G_debug(2, "ogr_ftype = %d", ogr_ftype);
- strcpy(key1, Fi->key);
- G_tolcase(key1);
- strcpy(key2, colname[i]);
- G_tolcase(key2);
- if (strcmp(key1, key2) == 0)
- keycol = i;
- G_debug(2, "%s x %s -> %s x %s -> keycol = %d", Fi->key,
- colname[i], key1, key2, keycol);
+ strcpy(key1, Fi->key);
+ G_tolcase(key1);
+ strcpy(key2, colname[i]);
+ G_tolcase(key2);
+ if (strcmp(key1, key2) == 0)
+ keycol = i;
+ G_debug(2, "%s x %s -> %s x %s -> keycol = %d", Fi->key,
+ colname[i], key1, key2, keycol);
- if (flags.nocat->answer &&
- strcmp(Fi->key, colname[i]) == 0)
- /* skip export of 'cat' field */
- continue;
+ if (flags.nocat->answer &&
+ strcmp(Fi->key, colname[i]) == 0)
+ /* skip export of 'cat' field */
+ continue;
- if (flags.append->answer) {
- Ogr_field = OGR_L_GetLayerDefn(Ogr_layer);
- if (OGR_FD_GetFieldIndex(Ogr_field, colname[i]) > -1)
- /* skip existing fields */
- continue;
- else
- G_warning(_("New attribute column <%s> added to the table"),
+ if (flags.append->answer) {
+ Ogr_field = OGR_L_GetLayerDefn(Ogr_layer);
+ if (OGR_FD_GetFieldIndex(Ogr_field, colname[i]) > -1)
+ /* skip existing fields */
+ continue;
+ else
+ G_warning(_("New attribute column <%s> added to the table"),
colname[i]);
- Ogr_field = OGR_Fld_Create(colname[i], ogr_ftype);
- if (ogr_ftype == OFTString && colwidth > 0)
- OGR_Fld_SetWidth(Ogr_field, colwidth);
+ Ogr_field = OGR_Fld_Create(colname[i], ogr_ftype);
+ if (ogr_ftype == OFTString && colwidth > 0)
+ OGR_Fld_SetWidth(Ogr_field, colwidth);
+ colname[i]);
- OGR_Fld_Destroy(Ogr_field);
- if (keycol == -1)
- G_fatal_error(_("Key column <%s> not found"), Fi->key);
+ OGR_Fld_Destroy(Ogr_field);
+ if (keycol == -1)
+ G_fatal_error(_("Key column <%s> not found"), Fi->key);
Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
