[GRASS-SVN] r73831 - grass/trunk/lib/python/ctypes/ctypesgencore/parser
Tue Dec 25 05:31:54 PST 2018
Author: martinl
Date: 2018-12-25 05:31:54 -0800 (Tue, 25 Dec 2018)
New Revision: 73831
Added:
   grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py
missing lextab is causing problem on travis-ci, ignore svn property kept active
Added: grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py	                        (rev 0)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py	2018-12-25 13:31:54 UTC (rev 73831)
@@ -0,0 +1,8 @@
+# lextab.py. This file automatically created by PLY (version 2.2). Don't edit!
+_lextokens    = {'PP_END_DEFINE': None, 'DIV_ASSIGN': None, 'AND_OP': None, 'PERIOD': None, 'PTR_OP': None, 'PP_MACRO_PARAM': None, 'OTHER': None, 'IDENTIFIER': None, 'PP_STRINGIFY': None, 'XOR_ASSIGN': None, 'PP_DEFINE_NAME': None, 'ELLIPSIS': None, 'INC_OP': None, 'GE_OP': None, 'LEFT_ASSIGN': None, 'MUL_ASSIGN': None, 'RIGHT_ASSIGN': None, 'SUB_ASSIGN': None, 'LPAREN': None, 'PP_IDENTIFIER_PASTE': None, 'PP_DEFINE': None, 'OR_ASSIGN': None, 'ADD_ASSIGN': None, 'HEADER_NAME': None, 'LE_OP': None, 'LEFT_OP': None, 'PP_NUMBER': None, 'DEC_OP': None, 'RIGHT_OP': None, 'MOD_ASSIGN': None, 'STRING_LITERAL': None, 'EQ_OP': None, 'OR_OP': None, 'AND_ASSIGN': None, 'CHARACTER_CONSTANT': None, 'PP_DEFINE_MACRO_NAME': None, 'NE_OP': None, 'NEWLINE': None}
+_lexreflags   = 0
+_lexliterals  = ''
+_lexstateinfo = {'DEFINE': 'exclusive', 'INITIAL': 'inclusive'}
+_lexstatere   = {'DEFINE': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|\\*=|\\|=|\\+=|>>=|\\^=|<<=|\\)|-=|<%|<<|%>|\\+|>>|<=|/=|->|!=|&&|\\*|\\[|\\?|--|>=|\\.|:>|&=|==|<:|%=|\\||\\^|/|:|{|~|,|>|-|%|}|;|!|=|&|]|<))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t
 _DEFINE_pp_param_op>(\\#\\#)|(\\#))', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])], 'INITIAL': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|\\*=|\\|=|\\+=|>>=|\\^=|<<=|\\)|-=|<%|<<|%>|\\+|>>|<=|/=|->|!=|&&|\\*|\\[|\\?|--|>=|\\.|:>|&=|==|<:|%=|\\||\\^|/|:|{|~|,|>|-|%|}|;|!|=|&|]|<))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t
 _ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_INITIAL_newline>\\n)|(?P<t_INITIAL_pp_define>\\#define)', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_INITIAL_newline', 'INITIAL_newline'), ('t_INITIAL_pp_define', 'INITIAL_pp_define')])]}
+_lexstateignore = {'DEFINE': ' \t\x0b\x0c\r', 'INITIAL': ' \t\x0b\x0c\r'}
+_lexstateerrorf = {'DEFINE': 't_DEFINE_error', 'INITIAL': 't_INITIAL_error'}
