[GRASS-SVN] r73832 - grass/trunk/gui/wxpython/modules
svn_grass at osgeo.org
Tue Dec 25 06:38:36 PST 2018
Author: martinl
Date: 2018-12-25 06:38:35 -0800 (Tue, 25 Dec 2018)
New Revision: 73832
grass/trunk/gui/wxpython/modules/extensions.py
wxGUI: install extension dialog - hide repo settings (not used and misleading for user)
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py 2018-12-25 13:31:54 UTC (rev 73831)
+++ grass/trunk/gui/wxpython/modules/extensions.py 2018-12-25 14:38:35 UTC (rev 73832)
@@ -54,14 +54,14 @@
self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
- self.repoBox = StaticBox(
- parent=self.panel, id=wx.ID_ANY, label=" %s " %
- _("Repository (leave empty to use the official one)"))
+ # self.repoBox = StaticBox(
+ # parent=self.panel, id=wx.ID_ANY, label=" %s " %
+ # _("Repository (leave empty to use the official one)"))
self.treeBox = StaticBox(
_("List of extensions - double-click to install"))
- self.repo = TextCtrl(parent=self.panel, id=wx.ID_ANY)
+ # self.repo = TextCtrl(parent=self.panel, id=wx.ID_ANY)
# modelBuilder loads data into tree model
self.modelBuilder = ExtensionTreeModelBuilder()
@@ -101,19 +101,19 @@
continue
self.options[name] = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
label=desc)
- defaultUrl = '' # default/official one will be used when option empty
- self.repo.SetValue(
- task.get_param(
- value='url').get(
- 'default',
- defaultUrl))
+ # defaultUrl = '' # default/official one will be used when option empty
+ # self.repo.SetValue(
+ # task.get_param(
+ # value='url').get(
+ # 'default',
+ # defaultUrl))
self.statusbar = self.CreateStatusBar(number=1)
- self.btnFetch = Button(parent=self.panel, id=wx.ID_ANY,
- label=_("&Fetch"))
- self.btnFetch.SetToolTip(_("Fetch list of available modules "
- "from GRASS Addons SVN repository"))
+ # self.btnFetch = Button(parent=self.panel, id=wx.ID_ANY,
+ # label=_("&Fetch"))
+ # self.btnFetch.SetToolTip(_("Fetch list of available modules "
+ # "from GRASS Addons SVN repository"))
self.btnClose = Button(parent=self.panel, id=wx.ID_CLOSE)
self.btnInstall = Button(parent=self.panel, id=wx.ID_ANY,
label=_("&Install"))
@@ -124,7 +124,7 @@
self.btnHelp.SetToolTip(_("Show g.extension manual page"))
self.btnClose.Bind(wx.EVT_BUTTON, lambda evt: self.Close())
- self.btnFetch.Bind(wx.EVT_BUTTON, self.OnFetch)
+ # self.btnFetch.Bind(wx.EVT_BUTTON, self.OnFetch)
self.btnInstall.Bind(wx.EVT_BUTTON, self.OnInstall)
self.btnHelp.Bind(wx.EVT_BUTTON, self.OnHelp)
self.tree.selectionChanged.connect(self.OnItemSelected)
@@ -138,14 +138,14 @@
def _layout(self):
"""Do layout"""
sizer = wx.BoxSizer(wx.VERTICAL)
- repoSizer = wx.StaticBoxSizer(self.repoBox, wx.VERTICAL)
- repo1Sizer = wx.BoxSizer(wx.HORIZONTAL)
- repo1Sizer.Add(self.repo, proportion=1,
- flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL, border=1)
- repo1Sizer.Add(self.btnFetch, proportion=0,
- repoSizer.Add(repo1Sizer,
- flag=wx.EXPAND)
+ # repoSizer = wx.StaticBoxSizer(self.repoBox, wx.VERTICAL)
+ # repo1Sizer = wx.BoxSizer(wx.HORIZONTAL)
+ # repo1Sizer.Add(self.repo, proportion=1,
+ # flag=wx.ALL | wx.ALIGN_CENTER_VERTICAL, border=1)
+ # repo1Sizer.Add(self.btnFetch, proportion=0,
+ # repoSizer.Add(repo1Sizer,
+ # flag=wx.EXPAND)
findSizer = wx.BoxSizer(wx.HORIZONTAL)
findSizer.Add(self.search, proportion=1)
@@ -166,10 +166,10 @@
flag=wx.RIGHT, border=5)
btnSizer.Add(self.btnInstall, proportion=0)
- sizer.Add(repoSizer, proportion=0,
+ # sizer.Add(repoSizer, proportion=0,
+ # flag=wx.ALL | wx.EXPAND, border=3)
+ sizer.Add(findSizer, proportion=0,
- sizer.Add(findSizer, proportion=0,
- flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=3)
sizer.Add(treeSizer, proportion=1,
sizer.Add(optionSizer, proportion=0,
@@ -198,8 +198,8 @@
else:
flags.append('--%s' % key)
- return ['g.extension'] + flags + ['extension=' + name,
- 'url=' + self.repo.GetValue().strip()]
+ # 'url=' + self.repo.GetValue().strip()]
+ return ['g.extension'] + flags + ['extension={}'.format(name) ]
def OnFetch(self, event):
"""Fetch list of available extensions"""
@@ -213,7 +213,7 @@
try:
self.thread.Run(
callable=self.modelBuilder.Load,
- url=self.repo.GetValue().strip(),
+ url='', # self.repo.GetValue().strip(),
ondone=lambda event: self._fetchDone())
except GException as e:
self._fetchDone()
