[GRASS-SVN] r72212 - in grass-addons/grass7/imagery: . i.pysptools.unmix
Tue Feb 6 14:31:51 PST 2018
Author: sbl
Date: 2018-02-06 14:31:51 -0800 (Tue, 06 Feb 2018)
New Revision: 72212
Added:
   grass-addons/grass7/imagery/i.pysptools.unmix/
   grass-addons/grass7/imagery/i.pysptools.unmix/Makefile
   grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.html
   grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.py
New addon i.pysptools.unmix
Added: grass-addons/grass7/imagery/i.pysptools.unmix/Makefile
--- grass-addons/grass7/imagery/i.pysptools.unmix/Makefile	                        (rev 0)
+++ grass-addons/grass7/imagery/i.pysptools.unmix/Makefile	2018-02-06 22:31:51 UTC (rev 72212)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = i.pysptools.unmix
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/imagery/i.pysptools.unmix/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.html
--- grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.html	                        (rev 0)
+++ grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.html	2018-02-06 22:31:51 UTC (rev 72212)
@@ -0,0 +1,104 @@
+<em>i.pysptools.unmix</em> extracts endmembers from imagery group and performs
+spectral unmixing using
+<a href="https://pysptools.sourceforge.io/">pysptools</a>.
+<p>
+The module is a wrapper around the <b>pysptools</b> Python library, that integrates
+its functionality for
+<a href="https://pysptools.sourceforge.io/eea.html">Endmember Extraction</a>
+and <a href="https://pysptools.sourceforge.io/abundance_maps.html">Spectral
+Unmixing</a> into GRASS GIS.
+</p>
+<p>
+It requires that the Python libraries <b>pysptools</b> and <b>scikit-learn</b>
+are installed.
+</p>
+<p>
+Supported algorithms for
+are:
+<ul>
+<li><i>NFINDR</i>: N-FINDR endmembers induction algorithm after Winter (1999),
+that also makes use of an Automatic Target Generation Process (ATGP) (Plaza &
+Chang 2006). (<i>Default</i>)</li>
+<li><i>FIPPI</i>: Fast Iterative Pixel Purity Index after Chang (2006)</li>
+<li><i>PPI</i>: Pixel Purity Index</li>
+</ul>
+</p>
+<p>
+<a href="https://pysptools.sourceforge.io/abundance_maps.html">Spectral Unmixing</a>
+ are:
+<ul>
+<li><i>FCLS</i>: Fully Constrained Least Squares (FCLS): Estimates endmember
+abundance per pixel with the constraint that values are non-negative and sum up
+to one per pixel (<i>Default</i>)</li>
+<li><i>UCLS</i>: Unconstrained Least Squares (UCLS): Estimates endmember
+abundance per pixel in an unconstrained way</li>
+<li><i>NNLS</i>: Non-negative Constrained Least Squares (NNLS): Estimates endmember
+abundance per pixel with the constraint that values are non-negative</li>
+</ul>
+</p>
+<h2>NOTES</h2>
+<p>
+Number of endmembers to extract (<i>endmember_n</i>) is supposed to be lower
+than the number of bands in the imagery group. Only the <i>PPI</i> method can
+extract more endmembers than there are bands in the imagery group.
+</p>
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+# List bands
+bands=`g.list type=raster pattern=lsat7_2002* separator=','`
+# Create imagery group
+i.group group=lsat_2002 input="$bands"
+# Extract Endmembers and perform spectral unmixing using pysptools
+i.pysptools.unmix input=lsat_2002 endmembers=endmembers endmember_n=5 \
+output=spectrum.txt prefix=lsat_spectra --v
+# Compare to result from i.spec.unmix
+i.spec.unmix group=lsat7_2002 matrix=sample/spectrum.dat result=lsat7_2002_unmix \
+error=lsat7_2002_unmix_err iter=lsat7_2002_unmix_iterations
+</pre></div>
+<h2>REQUIREMENTS</h2>
+<ul>
+  <li><a href="https://pypi.python.org/pypi/pysptools">pysptools library</a></li>
+  <li><a href="https://pypi.python.org/pypi/scikit-learn">scikit-learn library</a></li>
+</ul>
+<h2>REFERENCES</h2>
+<p>
+Chang, C.-I. 2006: A fast iterative algorithm for implementation of pixel
+purity index. Geoscience and Remote Sensing Letters, IEEE, 3(1): 63-67.
+</p>
+<p>
+Plaza, A. & Chang, C.-I. 2006: Impact of Initialization on Design of
+Endmember Extraction Algorithms. Geoscience and Remote Sensing,
+IEEE Transactions. 44(11): 3397-3407.
+</p>
+<p>
+Winter, M. E. 1999: N-FINDR: an algorithm for fast autonomous spectral
+end-member determination in hyperspectral data. Presented at the
+Imaging Spectrometry V, Denver, CO, USA, (3753): 266-275.
+</p>
+<h2>SEE ALSO</h2>
+<em>
+<a href="i.spec.unmix.html">i.spec.unmix</a>
+</em>
+<h2>AUTHORS</h2>
+Stefan Blumentrath, <a href="http://www.nina.no">
+Norwegian Institute for Nature Research (NINA), Oslo, Norway</a><br>
+Zofie Cimburova, <a href="http://www.nina.no">
Property changes on: grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.py
--- grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.py	                        (rev 0)
+++ grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.py	2018-02-06 22:31:51 UTC (rev 72212)
@@ -0,0 +1,346 @@
+#!/usr/bin/env python
+MODULE:    i.pysptools.unmix
+AUTHOR(S): Stefan Blumentrath < stefan.blumentrath AT nina.no>
+           Zofie Cimburova < zofie.cimburova AT nina.no>
+PURPOSE:   Extract endmembers from imagery group and perform spectral unmixing
+           using pysptools
+           Depemds on pysptools and scikit-learn
+COPYRIGHT: (C) 2018 by the GRASS GIS Development Team,
+                           Norwegian Institute for Nature Research (NINA)
+           This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+#%module
+#% description: Extract endmembers from imagery group and perform spectral unmixing using pysptools
+#% keyword: imagery
+#% keyword: endmember
+#% keyword: spectral unmixing
+#%end
+#%option G_OPT_I_GROUP
+#% key: input
+#% description: Input imagery group
+#% required : yes
+#%end
+#%option G_OPT_F_OUTPUT
+#% key: output
+#% guisection: output
+#% description: Text file storing endmember information for i.spec.unmix
+#% required : no
+#%end
+#%option
+#% key: prefix
+#% description: Prefix for resulting raster maps
+#% required : no
+#%end
+#%option G_OPT_V_OUTPUT
+#% key: endmembers
+#% description: Vector map representing identified endmembers
+#% required : no
+#%end
+#%option
+#% key: endmember_n
+#% type: integer
+#% description: Number of endmembers to identify
+#% required: yes
+#%end
+#%option
+#% key: extraction_method
+#% type: string
+#% description: Method for endmember extraction
+#% options: FIPPI,PPI,NFINDR
+#% answer: NFINDR
+#%end
+#%option
+#% key: unmixing_method
+#% type: string
+#% description: Algorithm for spectral unmixing
+#% options: FCLS,UCLS,NNLS
+#% answer: FCLS
+#%end
+#%option
+#% key: maxit
+#% type: integer
+#% description: Maximal number of iterations for endmember extraction (default=3*number of bands)
+#% required: no
+#%end
+#%flag
+#% key: n
+#% description: Do not use Automatic Target Generation Process (ATGP)
+#%end
+#%rules
+#% required: output,prefix
+#%end
+import os
+import sys
+import numpy as np
+from grass.pygrass import raster as r
+from grass.pygrass.utils import getenv
+import grass.script as gs
+if not "GISBASE" in os.environ.keys():
+    gs.message("You must be in GRASS GIS to run this program.")
+    sys.exit(1)
+def get_rastertype(raster):
+    if type(raster[0,0]) != np.float32 and type(raster[0,0]) != np.float64:
+        map_type = u'INTEGER'
+    else:
+        map_type = u'REAL'
+    return map_type
+def mask_rasternd(raster):
+        mask = raster != -2147483648
+    else:
+        mask = np.isnan(raster) == False
+    return mask
+def main():
+    try:
+        import pysptools.eea as eea
+    except ImportError:
+        gs.fatal(_("Cannot import pysptools \
+                      (https://pypi.python.org/pypi/pysptools) library."
+                      " Please install it (pip install pysptools)"
+                      " or ensure that it is on path"
+                      " (use PYTHONPATH variable)."))
+    try:
+        # sklearn is a dependency of used pysptools functionality
+        import sklearn
+        gs.fatal(_("Cannot import sklearn \
+                      (https://pypi.python.org/pypi/scikit-learn) library."
+                      " Please install it (pip install scikit-learn)"
+    # Parse input options
+    input = options['input']
+    output = options['output']
+    prefix = options['prefix']
+    endmember_n = int(options['endmember_n'])
+    endmembers = options['endmembers']
+    maxit = int(options['maxit'])
+    extraction_method = options['extraction_method']
+    unmixing_method = options['unmixing_method']
+    atgp_init = True if not flags['n'] else False
+    # List maps in imagery group
+    try:
+        maps = gs.read_command('i.group', flags='g', group=input,
+                               quiet=True).rstrip('\n').split('\n')
+    except:
+        pass
+    # Validate input
+    # q and maxit can be None according to manual, but does not work in curtrent pysptools version
+    if endmember_n <= 0:
+        gs.fatal('Number of endmembers has to be > 0')
+        """if (extraction_method == 'PPI' or
+            extraction_method == 'NFINDR'):
+            gs.fatal('Extraction methods PPI and NFINDR require endmember_n >= 2')
+        endmember_n = None"""
+    if maxit <= 0:
+        maxit = 3 * len(maps)
+    if endmember_n > len(maps) + 1:
+        gs.warning('More endmembers ({}) requested than bands in \
+                   input imagery group ({})'.format(endmember_n, len(maps)))
+        if extraction_method != 'PPI':
+            gs.fatal('Only PPI method can extract more endmembers than number \
+                     of bands in the imagery group')
+    if not atgp_init and extraction_method != 'NFINDR':
+        gs.verbose('ATGP is only taken into account in \
+                   NFINDR extraction method...')
+    # Get metainformation from input bands
+    band_types = {}
+    img = None
+    n = 0
+    gs.verbose('Reading imagery group...')
+    for m in maps:
+        map = m.split('@')
+        # Build numpy stack from imagery group
+        raster = r.raster2numpy(map[0], mapset=map[1])
+        if raster == np.float64:
+            raster = float32(raster)
+            gs.warning('{} is of type Float64.\
+                        Float64 is currently not supported.\
+                        Reducing precision to Float32'.format(raster))
+        # Determine map type
+        band_types[map[0]] = get_rastertype(raster)
+        # Create cube and mask from GRASS internal NoData value
+        if n == 0:
+            img = raster
+            # Create mask from GRASS internal NoData value
+            mask = mask_rasternd(raster)
+        else:
+            img = np.dstack((img, raster))
+            mask = np.logical_and((mask_rasternd(raster)), mask)
+        n = n + 1
+    # Read a mask if present and give waringing if not
+    # Note that otherwise NoData is read as values
+    gs.verbose('Checking for MASK...')
+    try:
+        MASK = r.raster2numpy('MASK', mapset=getenv('MAPSET')) == 1
+        mask = np.logical_and(MASK, mask)
+        MASK = None
+    except:
+        pass
+    if extraction_method == 'NFINDR':
+    # Extract endmembers from valid pixels using NFINDR function from pysptools
+        gs.verbose('Extracting endmembers using NFINDR...')
+        nfindr = eea.NFINDR()
+        E = nfindr.extract(img, endmember_n, maxit=maxit, normalize=False,
+                           ATGP_init=atgp_init, mask=mask)
+    elif extraction_method == 'PPI':
+    # Extract endmembers from valid pixels using PPI function from pysptools
+        gs.verbose('Extracting endmembers using PPI...')
+        ppi = eea.PPI()
+        E = ppi.extract(img, endmember_n, numSkewers=10000, normalize=False,
+                        mask=mask)
+    elif extraction_method == 'FIPPI':
+    # Extract endmembers from valid pixels using FIPPI function from pysptools
+        gs.verbose('Extracting endmembers using FIPPI...')
+        fippi = eea.FIPPI()
+        """if not maxit and not endmember_n:
+            E = fippi.extract(img, q=None, normalize=False, mask=mask)
+        if not maxit:
+            E = fippi.extract(img, q=endmember_n, normalize=False, mask=mask)
+        if not endmember_n:
+            E = fippi.extract(img, q=int(), maxit=maxit, normalize=False,
+                              mask=mask)
+        else:
+            E = fippi.extract(img, q=endmember_n, maxit=maxit, normalize=False,
+                              mask=mask)"""
+                          mask=mask)
+    # Write output file in format required for i.spec.unmix addon
+    if output:
+        gs.verbose('Writing spectra file...')
+        n = 0
+        with open(output, 'w') as o:
+            o.write('# Channels: {}\n'.format('\t'.join(band_types.keys())))
+            o.write('# Wrote {} spectra line wise.\n#\n'.format(endmember_n))
+            o.write('Matrix: {0} by {1}\n'.format(endmember_n, len(maps)))
+            for e in E:
+                o.write('row{0}: {1}\n'.format(n, '\t'.join([str(i) for i in  e])))
+                n = n + 1
+    # Write vector map with endmember information if requested
+    if endmembers:
+        gs.verbose('Writing vector map with endmembers...')
+        from grass.pygrass import utils as u
+        from grass.pygrass.gis.region import Region
+        from grass.pygrass.vector import Vector
+        from grass.pygrass.vector import VectorTopo
+        from grass.pygrass.vector.geometry import Point
+        # Build attribute table
+        # Deinfe columns for attribute table
+        cols = [(u'cat',       'INTEGER PRIMARY KEY')]
+        for b in band_types.keys():
+            cols.append((b.replace('.','_'), band_types[b]))
+        # Get region information
+        reg = Region()
+        # Create vector map
+        new = Vector(endmembers)
+        new.open('w', tab_name=endmembers, tab_cols=cols)
+        cat = 1
+        for e in E:
+            # Get indices
+            idx = np.where((img[:,:]==e).all(-1))
+            # Numpy array is ordered rows, columns (y,x)
+            if len(idx[0]) == 0 or len(idx[1]) == 0:
+                gs.warning('Could not compute coordinated for endmember {}. \
+                            Please consider rescaling your data to integer'.format(cat))
+                cat = cat + 1
+                continue
+            coords = u.pixel2coor((idx[1][0], idx[0][0]), reg)
+            point = Point(coords[1] + reg.ewres / 2.0,
+                          coords[0] - reg.nsres / 2.0)
+            # Get attributes
+            n = 0
+            attr = []
+                if band_types[b] == u'INTEGER':
+                    attr.append(int(e[n]))
+                else:
+                    attr.append(float(e[n]))
+                n = n + 1
+            # Write geometry with attributes
+            new.write(point, cat=cat,
+                      attrs=tuple(attr))
+            cat = cat + 1
+        # Close vector map
+        new.table.conn.commit()
+        new.close(build=True)
+    if prefix:
+        # Run spectral unmixing
+        import pysptools.abundance_maps as amaps
+        if unmixing_method == 'FCLS':
+            fcls = amaps.FCLS()
+            result = fcls.map(img, E, normalize=False, mask=mask)
+        elif unmixing_method == 'NNLS':
+            nnls = amaps.NNLS()
+            result = nnls.map(img, E, normalize=False, mask=mask)
+        elif unmixing_method == 'UCLS':
+            ucls = amaps.UCLS()
+            result = ucls.map(img, E, normalize=False, mask=mask)
+        # Write results
+        for l in range(endmember_n):
+            rastname = '{0}_{1}'.format(prefix, l + 1)
+            r.numpy2raster(result[:,:,l], 'FCELL', rastname)
+# Run the module
+if __name__ == "__main__":
+    options, flags = gs.parser()
+    sys.exit(main())
Property changes on: grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.py
   + text/x-python
   + native
