[GRASS-SVN] r72213 - grass-addons/grass7/imagery/i.pysptools.unmix
svn_grass at osgeo.org
Wed Feb 7 13:28:54 PST 2018
Author: sbl
Date: 2018-02-07 13:28:54 -0800 (Wed, 07 Feb 2018)
New Revision: 72213
grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.html
fix some html tags
Modified: grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.html
--- grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.html 2018-02-06 22:31:51 UTC (rev 72212)
+++ grass-addons/grass7/imagery/i.pysptools.unmix/i.pysptools.unmix.html 2018-02-07 21:28:54 UTC (rev 72213)
@@ -17,6 +17,7 @@
Supported algorithms for
<a href="https://pysptools.sourceforge.io/eea.html">Endmember Extraction</a>
are:
+</p>
<ul>
<li><i>NFINDR</i>: N-FINDR endmembers induction algorithm after Winter (1999),
that also makes use of an Automatic Target Generation Process (ATGP) (Plaza &
@@ -24,11 +25,11 @@
<li><i>FIPPI</i>: Fast Iterative Pixel Purity Index after Chang (2006)</li>
<li><i>PPI</i>: Pixel Purity Index</li>
</ul>
-</p>
<p>
<a href="https://pysptools.sourceforge.io/abundance_maps.html">Spectral Unmixing</a>
are:
+</p>
<ul>
<li><i>FCLS</i>: Fully Constrained Least Squares (FCLS): Estimates endmember
abundance per pixel with the constraint that values are non-negative and sum up
@@ -38,7 +39,6 @@
<li><i>NNLS</i>: Non-negative Constrained Least Squares (NNLS): Estimates endmember
abundance per pixel with the constraint that values are non-negative</li>
</ul>
-</p>
<h2>NOTES</h2>
