[GRASS-SVN] r72251 - in grass/trunk/raster: r.external r.in.gdal
svn_grass at osgeo.org
Sat Feb 17 05:33:51 PST 2018
Author: mmetz
Date: 2018-02-17 05:33:50 -0800 (Sat, 17 Feb 2018)
New Revision: 72251
grass/trunk/raster/r.external/proj.c
grass/trunk/raster/r.in.gdal/main.c
grass/trunk/raster/r.in.gdal/proj.c
r.in.gdal/r.external: add test if OGR spatial reference is NULL
Modified: grass/trunk/raster/r.external/proj.c
--- grass/trunk/raster/r.external/proj.c 2018-02-16 13:34:23 UTC (rev 72250)
+++ grass/trunk/raster/r.external/proj.c 2018-02-17 13:33:50 UTC (rev 72251)
@@ -39,9 +39,10 @@
OGRSpatialReferenceH hSRS;
hSRS = OSRNewSpatialReference(wkt);
- GPJ_osr_to_grass(cellhd, &proj_info, &proj_units, hSRS, 0);
+ if (hSRS != NULL)
+ GPJ_osr_to_grass(cellhd, &proj_info, &proj_units, hSRS, 0);
- if (!OSRIsProjected(hSRS) && !OSRIsGeographic(hSRS)) {
+ if (!hSRS || (!OSRIsProjected(hSRS) && !OSRIsGeographic(hSRS))) {
G_important_message(_("Input contains an invalid SRS. "
"WKT definition:\n%s"), wkt);
@@ -59,7 +60,7 @@
if (authname && *authname && strcmp(authname, "EPSG") == 0) {
authcode = OSRGetAuthorityCode(hSRS, authkey);
if (authcode && *authcode) {
- G_debug(0, "found EPSG:%s", authcode);
+ G_debug(1, "found EPSG:%s", authcode);
proj_epsg = G_create_key_value();
G_set_key_value("epsg", authcode, proj_epsg);
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2018-02-16 13:34:23 UTC (rev 72250)
+++ grass/trunk/raster/r.in.gdal/main.c 2018-02-17 13:33:50 UTC (rev 72251)
@@ -472,11 +472,6 @@
check_projection(&cellhd, hDS, parm.outloc->answer, flag_c->answer,
flag_o->answer, flag_j->answer);
- if (GDALGetRasterCount(hDS) > 1) {
- G_message(_("Importing %d raster bands..."),
- GDALGetRasterCount(hDS));
/* Set the active window to match the available data. */
@@ -576,6 +571,11 @@
n_bands++;
+ if (GDALGetRasterCount(hDS) > 1 && n_bands != 1) {
+ G_message(_("Importing %d raster bands..."),
+ (n_bands > 1 ? n_bands : GDALGetRasterCount(hDS)));
if ((GDALGetRasterCount(hDS) > 1 && n_bands != 1)
|| GDALGetGCPCount(hDS) > 0)
force_imagery = TRUE;
Modified: grass/trunk/raster/r.in.gdal/proj.c
--- grass/trunk/raster/r.in.gdal/proj.c 2018-02-16 13:34:23 UTC (rev 72250)
+++ grass/trunk/raster/r.in.gdal/proj.c 2018-02-17 13:33:50 UTC (rev 72251)
@@ -39,9 +39,10 @@
+ if (hSRS != NULL)
@@ -59,7 +60,7 @@
